No injector pulse 02 Ram 1500 - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 3 Old 05-30-2012, 09:52 AM Thread Starter
Bustedknuckle12
Ok i hope im posting this in the right place.. I have an 02 Dodge Ram 1500. It came with a 318 that was swapped to a 360. I used the 360 flex plate when we swapped them out. Here's my problem.. i have no injector pulse what so ever. I have replaced the crank sensor, cam sensor, asd relay, i've tested signal to pcm from cam sensor, from crank sensor. i've moved, added and cleaned grounds. i've test every wire going into the pcm. everything says it should get a pulse to the injectors.. nothing. i have spark from the coil, i have 50 psi fuel pressure. i can connect my scanner to the obd2 and test fire each injector thru the scanner. i've replaced the pcm also. i've even went as far as pullin my durango nose to nose with the truck and tested the truck then the durango.. everything appeared to be the same or so close it shouldn't matter.. what am i missing.. please help.. i've been working on this thing for well over a month and at this point im lost. i've tested and replaced everything i know to... help help help please.
Bustedknuckle12 is offline
post #2 of 3 Old 05-31-2012, 08:21 PM Thread Starter
Bustedknuckle12
Really?
Please I know I'm new to this forum and no body likes the newbie questions. I get it, I'm sure out of all the self proclaimed experts on this forum some one has an idea of what be causing my problem. Anything, at this point I wanna pull the engine and put it in my Durango just to hear it run without me pouring gas down the intake
post #3 of 3 Old 05-31-2012, 10:44 PM
dmcelhannon
Admin - David Mack
dmcelhannon's Avatar
Quoted: 270 Post(s)
Welcome to DT!
I do not believe it's because you're a newbie. I'll bump the thread to the top so folks can see it.
dmcelhannon is offline
03 ram 1500 injector adaptors - i need I'LLSMOQ 3G Dodge Ram Performance Talk 2 10-06-2010 02:09 PM
Pulse at 50MPH DR06 3G Dodge RAM - General Talk 1 06-23-2008 09:07 AM
2003 Ram 1500 Injector Choice-HELP?? I'LLSMOQ 3G Dodge Ram Performance Talk 18 11-23-2007 09:17 PM
no injector pulse on 03 dodge ram fathead32 3G Dodge RAM - General Talk 0 10-23-2007 09:39 PM
Speed pulse or ABS pulse Squid 3G Dodge RAM - General Talk 7 10-10-2005 09:27 PM
