Wagon 1 is down... - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 13 Old 03-14-2012, 05:40 PM Thread Starter
MSparks909
MSparks909's Avatar
Wagon 1 is down...
Well it's always something with these PW's ain't it? Water pump decided that it had endured enough torture over it's life. It started squealing really badly on my latest 700 mile jaunt. I could pop the hood with the engine idling and watch the fan moving back and forth as it spun. I dropped it off at the local dodge dealership to get the water pump worked on (I would do it but I just had shoulder/bicep surgery a week ago and won't be turning wrenches for a while). I'm also having them replace the front driveshaft u-joints as well while it's in the shop. They are starting to get squeaky. Nothing major and hopefully the next water pump will last another 75K.
06 Black QC G56, 76K miles and counting...
Thuren coils, tracbar, control arms, shackles, draglink, limit straps, towers, Stage 3 front King 2.5's, DBL Bypass rear King 2.5's, Carli leaf springs, Carli upper & lower BJ's and diff cover, PSC notched steering brace, 08.5 "T" linkage, PSC Extreme Duty Steering Box, Borgeson Lower Steering Shaft, Magnaflow muffler, Airaid Intake, American Racing ATX Thug 17x8.5, Yokohama Geolander AT/S 37x12.50x17, Rockcrusher rear diff cover, Airflow snorkel (fitted to Airaid full intake), Magnaflow y-pipe & Flowmaster Super 44 muffler, Go Recon Super White cab lights, EBC slotted rotors/Yellowstuff pads, winch thermal bypass & locker bypass, Pit Slave-modded SmartBar, greasable front u-joints, tint, JL Audio 12" subwoofer & JL Audio 500W amp with adjustable bass knob
Upcoming Mods:
Flowtech Headers, Line-X rocker panels/fender flares, eBay black mesh grill, DIY blacked-out headlights, Diablosport programmer, chopped rocker panels, tube bumpers F/R, Rigid Industries LED lightbar, axle truss, stiffer shock valving, VH tire carrier, Mastercraft Baja RS seats, Filtermag, Go Pro HERO 2
MSparks909 is offline
Quote Quick Reply
post #2 of 13 Old 03-14-2012, 06:30 PM
coder
coder's Avatar
I'm at 75k and thought I would replace mine just to be safe. But when I saw everything that was involved, I said no thanks.
From the 2006 Dodge DR Ram Truck Manual:
5.7L ENGINE
1. Disconnect negative battery cable.
2. Drain coolant.
3. Remove serpentine belt.
4. Remove fan clutch assembly.
5. Remove coolant fill bottle.
6. Disconnect washer bottle wiring and hose.
7. Remove fan shroud assembly.
8. Remove A/C compressor and generator brace.
9. Remove idler pulleys.
10. Remove belt tensioner assembly.
11. Remove upper and lower radiator hoses.
12. Remove heater hoses.
13. Remove water pump mounting bolts and remove pump.
Then reverse everything and put it back on.
2007 Quad Cab Power Wagon
Suspension: Carli 3" Hemi Coils | Carli Control Arms | Carli King 2.5 Pin-Tops | Carli Stainless Steel Damper | Synergy 1" Rear Shackle
Performance: Magnaflow Muffler | Magnaflow Y-Pipe
Wheels/Tires: Toyo ATII's 35x12.5x17
Steering/Drivetrain/Axles: Carli Front Diff Guard | Dynatrac Ball Joints | Redhead Steering Gear
Miscellaneous: EBC Front Slotted Dimpled Rotors | Line-X Bedliner | Locker Bypass Switch | Mopar Rock Rails | DieHard Platinum Battery G65 | Performance Friction Brake Pads | Weathertech Digital Fit Mats | Winch Thermal Protection Bypass
coder is offline
post #3 of 13 Old 03-14-2012, 07:06 PM
WHITEYBLACKPW
WHITEYBLACKPW's Avatar
That's one repair you won't be doing at the shady tree garage! (repairs on the trail)
WHITEYBLACKPW is offline
post #4 of 13 Old 03-14-2012, 09:37 PM Thread Starter
MSparks909
MSparks909's Avatar
Yeah right? I'm glad it's getting replaced. I thought it was an idler pulley or tensioner pulley on its way out so I pulled the belt off to spin each pulley by hand and they were all pretty smooth even though I have done quite a few high speed puddle runs which usually kill the idlers pretty quickly...I put my hand on the fan to rest it (bad shoulder) and the fan moved back about 1/2". I shook it back and forth a couple of times and that's how I deduced it was the pump. Go figure...the truck was running so good too! It's always something. I guess I'll call up and see if they can do an alignment too. Hasn't been aligned in the last 55K.
Upcoming Mods:
post #5 of 13 Old 03-14-2012, 11:20 PM
MSCH2112
Bushwacker!
MSCH2112's Avatar
Send a message via Yahoo to MSCH2112
wow...brings back memories. i did this once on my 97' ram on the trail. it really sucked.
mike
2012 Power Wagon LARAMIE Pkg. w/ 12k Warn winch, Nav, Sunroof, Leer Topper, AMP boards, Spray on-bedliner-rockers-flares
Support Search and Rescue-GET LOST
High-Lift Jack w/ lots of tow ropes and winch tools
2009 Victory Jackpot Cory Ness Edition!
SOLD 2005 Power Wagon Quad w/ 12k Warn winch, loaded incl. leather, rockrails, nav, sunroof, 9.5 ti Warn winch in the rear, Gibson Headers and catback, Pace-Edwards full metal elec. bed cover and elec. tailgate lock, PIAA driving lights behind grill.
MSCH2112 is offline
post #6 of 13 Old 03-15-2012, 02:41 AM
TwinStick
Whats the total bill for that ???
08' PowerWagon w/6-speed manual G-56. 05' 30' toyhauler camper.(10,500lbs)
Hellwig LoadPro 35 bolt on 4 leaf helper springs.
No honey, I'm NOT done buying shit for the truck yet !!!
PurpleCrainium Diff Guards
K&N air filter --- WeatherGuard 20" black bed toolbox.
winch TPC bypass
Dual battery set up w/2 Sears DieHard Platinums-Gp 65 under hood-Gp 31 Marine deep cycle in bed toolbox w/plug-n-play set up. Custom 2000/4000w inverter set up w/quick connect. Triple bike mounts above the bed- custom made by me.
Crapload of recovery gear-always subject to adding more.
Fab Four rear bumper. Soon to be- a BuckStop Baja front bumper.--Temporarily on hold, see reason below.
Installed: Borgeson #000951 steering shaft. PSC steering brace(notched for PW by Rusty-thanks bud). Carli HD CroMo adjustable track bar. Carli CroMo control arms. Carli HD upper & lower balljoints x 2 sets (replaced under warrenty) & triple sealed u-joints in front axle shafts & rear driveshaft. Moog HD tierod ends x 4. Running total is now $4800. Yup, now i'm broke !!!
What, you ask, is the difference between a Dodge Ram and a PowerWagon ?? PW frame part # 55398868AC---Reg 2500 #55398813AC
About 2" taller, 12,000lb winch w/mounting brace between framerails,electronic disconnecting swaybar(for awsome articulation),electronic locking axles front & rear(for true 4-wheel drive),tow pkg, fully skidplated,forged one piece Alcoa rims w/internal beadlock lips,larger diameter(one ton) axleshaft in rear,160 amp alt,HD battery,4.56 gears,low range electronic recalibration of gas pedal sensitivity,more but thinner leafs in rear spring pack(for better articulation), 33" BFG All-Terrain tires. 78.016:1 crawl ratio. All for $6100.00 more! Oh yeah, almost forgot-Bilstein shocks. Gear ratios: 1st 6.29:1 2nd 3.48:1 3rd 2.10:1 4th 1.38:1 5th 1.0:1 6th .79:1.. Rev 5.74:1.
TwinStick is offline
post #7 of 13 Old 03-15-2012, 10:15 AM Thread Starter
MSparks909
MSparks909's Avatar
$499 for pump and labor...ouch. But it's better than neglecting it and overheating it later down the road.
Upcoming Mods:
post #8 of 13 Old 03-15-2012, 11:07 PM
TwinStick
No doubt, it certainly is.
winch TPC bypass
post #9 of 13 Old 03-19-2012, 06:15 PM
VA__Wagon Man
Don't Follow Me....
VA__Wagon Man's Avatar
Sorry to hear about your troubles. Speedy recovery to ya with your surger. I just replaced mine last year......it was nt actually that bad. The worst was having to heat the fan nut with a torch to get it loose. Other than that, piece of cake. The noise is what gave it away for me too
'05 Silver Power Wagon: # 869 All Stock except for: Custom Rear Bed Clearance Mod, Custom High Clearance Hitch, Custom Front and Rear Tubular Bumpers, Airflow 3rd Gen Snorkel, Diablo Sport Predator 93 Octane Performance Tune, Performance Trans Tune+Quick Adjust, Muff- 40 Series Flow Master-Dumped, Mopar Rock Rails (that I'm going to get RUSTY to nerf for me)
Factory: Warn 12,000lb Winch(M15,000lb internals and gears) with Thermal Bypass completed, 4.56 Locking front and rear Diffs, Sway-bar disconnect, Uprgraded " T " steering linkage,
Tubular lower control arms, Fully Skid plated with fore and aft bars, 315/70 R17 Firestone Destination Mud Terrains, Rhino lined bed with hard cover, Leather Two Tone Black with Gray Inlayed interior, Satalite Radio, CB Radio, heated seats and mirrors, K&N Drop in Filter, Carli Front Diff Protector, 100 Watt off road lights and Factory Fogs behind the grill, RockCrusher Rear Diff Protector, Bilstein 5100's with rear Custom Valving, Pit Slave Winch Strap, CajunPW PNP Locker By-Pass installed and ready to rock!
lots of plans-notso lotso money
P0wer Wag0n Reg1stry Member
Check out my You Tube Channel:
Follow Me, I'll Pull You Out......
Rausch Creek 2010 Fall Run
Rausch Creek 2011 Spring Run
Rausch Creek 2011 Fall Run
Rausch Creek 2012 Spring Run (June-Join in!)
"There is no hunting, like the hunting of man, and those who have hunted armed men long enough, and liked it, never cared for anything else thereafter." --Earnest Hemmingway--
VA__Wagon Man is offline
post #10 of 13 Old 03-19-2012, 10:16 PM Thread Starter
MSparks909
MSparks909's Avatar
Thanks. Been doing passive shoulder exercises for about a week now. Going to start doing isometric stuff in another week or so and more stretching. I'm young hopefully I'll bounce back quick! I'm just glad it's fixed now and I don't have to worry about it for hopefully another 75K.
Upcoming Mods:
post #11 of 13 Old 03-19-2012, 11:52 PM
RustyPW08
Moab Tested
RustyPW08's Avatar
Talking
You or the PW? LOL
PWOC #53
2008 POWER WAGON RC
Sequentially Number #08-1505,
Inferno Red, Automatic
Mods to the PW;
Nerffed Mopar RockRails, Wheel Well Liners, Bushwacker Pocket Fender Flairs, Extang Tonneau Cover, Garvmin dezl 560LMT GPS, Power Wagon Winch Kit, Line X Ultra Bed Liner, PIAA Headlight Bulbs, PIAA 580 Driving Lights (135 watt), PIAA 520 Fog Lights (135 watt), PIAA 520 ATP Off-Road Lights (135 watt), Locker Bypass, Modifed Rockcrusher Diff Covers, Mopar Utility Bed Rails and Tool Box, Warn Winch Wireless Remote Control, "el-cheapo" Inclinometer, Airaid CAI, Winch TPS Bypass, Had 35" Cooper STT's now 35" Toyo's, Mopar Spare Tire Lock, 'T' Steering Linkage, Modifed PSC Steering Brace, P3 Brake Controller, Modifed Fusion "mall crawler" rear bumper, PIAA 1500 Back-Up Lights, 1Ton HEMI Tranny Cooler, Leer 100XR Bed Cap, Factory Tow Mirrors, CenterLine Rims 17x9-5.25 BS, Mag-Hytec Tranny Pan, AutoMeter Gauges, PSC Extreme Hydro Assist Steering, Carli Track Bar, Carli Ball-Joints, Dynatrac FreeSpin Hubs, Snorkel, RCV Axles, EBC Pads & Rotors, Aluminess Front Bumper, BIG Pul-Pal and it's own body bag!, 60" Extreme Hi-lift Jack, and more riggin' equipment, Carli Long Travel Air Bags, Bilstein 7100 Shocks - Carli Valving, MORE STUFF COMIN', TTI headers, Somebody's long arm, 7.2L MOTOR
Mods to me; Ti hip replacement. Zerk fitting in knee. Now it's gets greased more than some guys front drive shafts. I've been Used, Abused and Recycled!
Survivor of The Cold War,
Heaven's Gate, The Grand Conjunction, The Pleiadeans Landings, Y2K, The Winch Mob Banning, The Mayan Apocalypse, and some other covert stuff. Future ISIS killer!
"Moab '10, '12, '14",
"Rausch Creek-Spring, Fall '11, Spring '12, Summer '13, Summer '14"
RUSS
RustyPW08 is offline
post #12 of 13 Old 03-20-2012, 12:29 PM
VA__Wagon Man
Don't Follow Me....
Originally Posted by RustyPW08 View Post
You or the PW? LOL
^^ same thing popped into my head when I read that! haha
post #13 of 13 Old 03-28-2012, 12:13 AM Thread Starter
MSparks909
MSparks909's Avatar
Bringinggg the thread back to the top. I think I know why my water pump failed. For about a year I have been topping off my coolant in the overflow tank with the Prestone 50/50 mix "mixes with all types & all colors" coolant. After some research I found out that that Prestone mix is an OAT coolant, and Mopar specifies an HOAT coolant...mixing the two can cause severe cooling system problems such as cavitation, pitting, erosion, sludge, etc.
Ford ran a test in which an engine/radiator designed for HOAT coolant was filled with OAT coolant and ran for 300 hours. The water pump and backing plate was severely damaged by cavitation corrosion. Now I wasn't running a straight 100% OAT fill, but I had been diluting the HOAT coolant fill for some time and I believe that was one of the leading factors to my failed water pump. I had the coolant flushed at Dodge @ the 30 & 60K mile marks. Truck currently has 75K on it and fresh HOAT coolant from when Dodge replaced the water pump. I'll probably flush it again @ 90K just to be safe and then again at 120K. And now I know that when I have to top off to use ONLY Zerex G-05 Coolant.
Save yourself the time, trouble and money in the long run and use the appropriate coolant. Wish I would have known the difference between OAT and HOAT coolants when I bough that Prestone stuff...lesson learned.
Here's a link to the Zerex that I'm talking about.
http://www.valvoline.com/products/br.../antifreeze/42
Upcoming Mods:
Power Wagon? We don't need no stinkin' Power Wagon verdesardog 3G Ram Power Wagon Talk 210 01-01-2012 01:50 PM
old Power Wagon paint on NEW Power Wagon RAM MAN Concept/Modified Vehicle Talk 21 01-14-2010 03:43 PM
2010 Dodge Ram Power Wagon Pictures (as seen on 3rd Gen Power Wagon Forum) 04Ram2500Hemi 4G Dodge RAM - 4X4 Talk 6 07-28-2009 10:51 PM
pics of town wagon, power wagon finefiftynine 1957-1966 Power Giant, Town Wagon and Panel 28 10-23-2007 05:07 PM
