Diff Fluid Change at Dealer? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 30 Old 06-24-2011, 05:08 AM Thread Starter
MiamiDave
MiamiDave's Avatar
Quoted: 1 Post(s)
Good morning, I am having my diffs, transfer, and trans changed tomorrow, and was wondering specifically what fluids are unique to the PW. I hear it does not need anything special for the lockers, though the rear is limited slip (until locked)?
I just want to make sure I am getting my money's worth, and they do everything correctly.
MD Quote: "A Power Wagon is never stuck, just occasionally, and briefly, stopped."
2011 Silver PW, red stripe delete and rear PW sticker option (by me), Diamondback Heavy Duty bed cover, Carli front diff protector/Purple Cranium full Spider Guard real diff protector, 315/70 Goodyear Duratracs all around (including spare in stock location)
MiamiDave is offline
Quote Quick Reply
post #2 of 30 Old 06-24-2011, 06:25 AM
VA__Wagon Man
Don't Follow Me....
VA__Wagon Man's Avatar
When they change your diff fluid they will pump it and refill. They won't take the cover off and clean your magnets. They probably don't know it has magnets. I'd stay back there and watch it. Just tell them there's stuff in your truck that you can't leave unattended. I stay with mine all the time.
My cousin is bringing his PW out to my house on Monday if you'd be interested in following him out. We're going to install his CB and put his front Carli Diff protector on.
'05 Silver Power Wagon: # 869 All Stock except for: Custom Rear Bed Clearance Mod, Custom High Clearance Hitch, Custom Front and Rear Tubular Bumpers, Airflow 3rd Gen Snorkel, Diablo Sport Predator 93 Octane Performance Tune, Performance Trans Tune+Quick Adjust, Muff- 40 Series Flow Master-Dumped, Mopar Rock Rails (that I'm going to get RUSTY to nerf for me)
Factory: Warn 12,000lb Winch(M15,000lb internals and gears) with Thermal Bypass completed, 4.56 Locking front and rear Diffs, Sway-bar disconnect, Uprgraded " T " steering linkage,
Tubular lower control arms, Fully Skid plated with fore and aft bars, 315/70 R17 Firestone Destination Mud Terrains, Rhino lined bed with hard cover, Leather Two Tone Black with Gray Inlayed interior, Satalite Radio, CB Radio, heated seats and mirrors, K&N Drop in Filter, Carli Front Diff Protector, 100 Watt off road lights and Factory Fogs behind the grill, RockCrusher Rear Diff Protector, Bilstein 5100's with rear Custom Valving, Pit Slave Winch Strap, CajunPW PNP Locker By-Pass installed and ready to rock!
lots of plans-notso lotso money
P0wer Wag0n Reg1stry Member
Check out my You Tube Channel:
Follow Me, I'll Pull You Out......
Rausch Creek 2010 Fall Run
Rausch Creek 2011 Spring Run
Rausch Creek 2011 Fall Run
Rausch Creek 2012 Spring Run (June-Join in!)
"There is no hunting, like the hunting of man, and those who have hunted armed men long enough, and liked it, never cared for anything else thereafter." --Earnest Hemmingway--
VA__Wagon Man is offline
post #3 of 30 Old 06-24-2011, 08:34 AM
crawler#976
crawler#976's Avatar
They should be using 75W90 Synthetic.
The cover needs to come off, and the magnets need to be cleaned, both front and rear.
Where the wiring terminates there should be a black blob of particles just to the left of the plug. It looks similar to a set of distributor points - except they are much bigger.
Print the photo, take it to them, and insist it be done.
Sarchasm : The gulf between the author of sarcastic wit and the person who doesn't get it.
crawler#976 is offline
post #4 of 30 Old 06-24-2011, 08:56 AM
CajunPW
Power Wagon #1605
CajunPW's Avatar
I know someone posted the specs of the gaps on the locker magents...who knows who that was? I think mine need to be adjusted some
2005 White Power Wagon #1605 aka Double Stuff
Current Mods:
CajunPW Locker Bypass Harness// CajunPW Winch Thermal Bypass// Warn 16.5ti Winch// Power Wagon Winch Accessory Kit// Blingy 20's with Interco M-16 Swampers
Coming Soon:
H2 Wheels// 315/70-17 Tires (Not sure which ones
)// Carli Extreme Duty Ball Joints (on order)// Carli Chromoly Control Arms// All Spicer U-Joints// Thuren Trackbar// 08.5+ Steering// Thuren Resi Shocks// Snorkle// DT Profab Steering Brace// Nerfed Rock Rails
and I am sure someone will help me spend more money
Contact me for your very own Power Wagon Locker Bypass and Winch Thermal Bypass
CajunPW is offline
post #5 of 30 Old 06-24-2011, 09:19 AM
GunniPWguy
CHRISTINE
GunniPWguy's Avatar
Here ya go... https://www.dodgetalk.com/forums/show...=1#post4051043
2005 BLACK POWER WAGON
Power Wagon Owners Club #155
Currently Sporting: 35 x 12.5 x 17 Cooper Discoverer STT's DT Profab Steering Brace, Gibson superflow catback single exhaust system, Locker Bypass, Moog ball joints (see how long they last), T-steering upgrade w/ Bilstein 5100 steering damper, Power everything, Heated leather seats, (keeps the better half happy
) 6-CD changer, Infinity premium audio, Rear window defrost, Bilstein 5100 shocks, Customized H2 alloy wheels, Original rock rails with family friendly steps welded on, Hi-lift extreme jack, Tool box along with all the essential PW gear. New winch cable, Winch TPS bypass, Cardan joint grease zerk discovery.
The list is morphing.
Beer is just water that has reached its full potential!
GunniPWguy is offline
post #6 of 30 Old 06-24-2011, 10:50 AM Thread Starter
MiamiDave
MiamiDave's Avatar
Quoted: 1 Post(s)
So no friction modifiers, even for the rear?
Anyone have a closeup of the actual magnets?
post #7 of 30 Old 06-24-2011, 10:58 AM
crawler#976
No modifiers. The PW has a helical gear limited slip. not a clutch driven limited slip.
post #8 of 30 Old 06-24-2011, 11:00 AM
CajunPW
Power Wagon #1605
CajunPW's Avatar
Originally Posted by Gunniguy View Post
Thanks!
I think im gonna service the rear again and this time adjust the magnets and after that I will do the front, but this time I will use my Makita 1/4" impact driver lol...there is just too many damn bolts for me
Current Mods:
Coming Soon:
CajunPW is offline
post #9 of 30 Old 06-24-2011, 11:24 AM
atvanish
atvanish's Avatar
You must be behaving or too busy to play - I haven't seen any pics of that new toy stuck yet!
2006 Power Wagon QC w/ 35" BFG KM2's, Rhino Lined Bed, B&W turnover hitch, nerfs, TSC toolbox & ventvisors...
atvanish is offline
post #10 of 30 Old 06-24-2011, 12:28 PM
CajunPW
Power Wagon #1605
CajunPW's Avatar
A little of both really..lol
Plus it's hard to get stuck in dust I did manage to go out last weekend to a retreat center and do some hog hunting and I managed to play around in the mud volleyball pit, but it was only 6" of water and very little mud
Current Mods:
Coming Soon:
CajunPW is offline
post #11 of 30 Old 06-24-2011, 03:31 PM Thread Starter
MiamiDave
MiamiDave's Avatar
Quoted: 1 Post(s)
You know, my lockers were slow the first two times, quicker the second time, but now lock instantly (both) from even a dead stop.
Should I even have them open the pumpkins to clean the magnets? I'm afraid it will do more harm than good from all off the horror stories?
post #12 of 30 Old 06-24-2011, 03:44 PM
CajunPW
Power Wagon #1605
CajunPW's Avatar
How many miles do you have on your truck?
Current Mods:
Coming Soon:
CajunPW is offline
post #13 of 30 Old 06-24-2011, 06:20 PM Thread Starter
MiamiDave
MiamiDave's Avatar
Quoted: 1 Post(s)
1100 miles ...
post #14 of 30 Old 06-24-2011, 06:41 PM
flattire
1100 miles?
Maintenence is good but I would save my money at this time. Wait until it is really needed.
flattire is offline
post #15 of 30 Old 06-24-2011, 09:10 PM
CajunPW
Power Wagon #1605
CajunPW's Avatar
Yeah, with 1100 miles I would spend money on a locker bypass
Current Mods:
Coming Soon:
CajunPW is offline
post #16 of 30 Old 06-24-2011, 10:22 PM
RustyPW08
Moab Tested
RustyPW08's Avatar
Talking
Here you go.
1st pic is unlocked.
2nd pic is locked. Look at the distance between the sensor and magnet in each pic. And look at the ring on the carrier.
PWOC #53
2008 POWER WAGON RC
Sequentially Number #08-1505,
Inferno Red, Automatic
Mods to the PW;
Nerffed Mopar RockRails, Wheel Well Liners, Bushwacker Pocket Fender Flairs, Extang Tonneau Cover, Garvmin dezl 560LMT GPS, Power Wagon Winch Kit, Line X Ultra Bed Liner, PIAA Headlight Bulbs, PIAA 580 Driving Lights (135 watt), PIAA 520 Fog Lights (135 watt), PIAA 520 ATP Off-Road Lights (135 watt), Locker Bypass, Modifed Rockcrusher Diff Covers, Mopar Utility Bed Rails and Tool Box, Warn Winch Wireless Remote Control, "el-cheapo" Inclinometer, Airaid CAI, Winch TPS Bypass, Had 35" Cooper STT's now 35" Toyo's, Mopar Spare Tire Lock, 'T' Steering Linkage, Modifed PSC Steering Brace, P3 Brake Controller, Modifed Fusion "mall crawler" rear bumper, PIAA 1500 Back-Up Lights, 1Ton HEMI Tranny Cooler, Leer 100XR Bed Cap, Factory Tow Mirrors, CenterLine Rims 17x9-5.25 BS, Mag-Hytec Tranny Pan, AutoMeter Gauges, PSC Extreme Hydro Assist Steering, Carli Track Bar, Carli Ball-Joints, Dynatrac FreeSpin Hubs, Snorkel, RCV Axles, EBC Pads & Rotors, Aluminess Front Bumper, BIG Pul-Pal and it's own body bag!, 60" Extreme Hi-lift Jack, and more riggin' equipment, Carli Long Travel Air Bags, Bilstein 7100 Shocks - Carli Valving, MORE STUFF COMIN', TTI headers, Somebody's long arm, 7.2L MOTOR
Mods to me; Ti hip replacement. Zerk fitting in knee. Now it's gets greased more than some guys front drive shafts. I've been Used, Abused and Recycled!
Survivor of The Cold War,
Heaven's Gate, The Grand Conjunction, The Pleiadeans Landings, Y2K, The Winch Mob Banning, The Mayan Apocalypse, and some other covert stuff. Future ISIS killer!
"Moab '10, '12, '14",
"Rausch Creek-Spring, Fall '11, Spring '12, Summer '13, Summer '14"
RUSS
RustyPW08 is offline
post #17 of 30 Old 06-24-2011, 10:33 PM
CajunPW
Power Wagon #1605
CajunPW's Avatar
Isn't that just the locker sensor?
Current Mods:
Coming Soon:
CajunPW is offline
post #18 of 30 Old 06-24-2011, 10:54 PM
RustyPW08
Moab Tested
RustyPW08's Avatar
Wink
Yeah. The magnet doesn't move. The sensor does. The magnet is the one you adjust for distance. It's mounted on the bearing cap (left). The sensor is mounted on the locker ring (right). It moves back and forth with the locker engagement.
PWOC #53
2008 POWER WAGON RC
Mods to the PW;
RUSS
post #19 of 30 Old 06-24-2011, 10:56 PM
CajunPW
Power Wagon #1605
CajunPW's Avatar
Originally Posted by RustyPW08 View Post
Yeah. The magnet doesn't move. The sensor does. The magnet is the one you adjust for distance. It's mounted on the bearing cap (left). The sensor is mounted on the locker ring (right). It moves back and forth with the locker.
That's what I thought, but when I changed my rear diff fluid I recall my magnets being further apart...I betcha that's why my RR locker and SERV 4WD light comes on from time to time
Current Mods:
Coming Soon:
CajunPW is offline
post #20 of 30 Old 06-24-2011, 11:07 PM
RustyPW08
Moab Tested
RustyPW08's Avatar
Wink
To check your sensor distance. You have to have the locker engaged. Easy enough to do. Jack the rear up. Remove diff cover. Engage locker by-pass. engage rear locker. If it doesn't engage. Just turn one rear wheel easy until it engages. Check your distance. Should be 0.210". If not, adjust it. I would use a stainless feeler gauge so it doesn't stick to the magnet.
PWOC #53
2008 POWER WAGON RC
Mods to the PW;
RUSS
Gears, Diff fluid and tranny fluid change...advice specific to dodge problem areas? Baut Baut 3G Dodge RAM - General Talk 6 04-29-2011 07:27 AM
diff fluid change sunburst08 3G Dodge RAM - Drivetrain Talk 1 02-25-2011 01:27 PM
Diff Fluid Change ? kubihibi 3G Dodge Dakota - Drivetrain Talk 1 01-19-2007 04:08 PM
Diff Fluid Change RamMan2002 3G Dodge RAM - Drivetrain Talk 2 09-24-2006 11:16 AM
Tranny oil/filter change & Diff fluid change in '03 2500 4x4 Ram w/ Hemi TitansFan 3G Dodge RAM - Drivetrain Talk 4 07-10-2006 10:39 PM
