New project - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 68 Old 06-14-2009, 12:17 AM Thread Starter
RustyPW08
Moab Tested
RustyPW08's Avatar
Talking New project
OK, I got a drawing and some 1.5" OD, .120" wall DOM tubing. And a trip to the tube bender on Monday. I wanted to do this before Moab, but didn't have the cash on hand because of Moab. Since I didn't go, and now I got cash. I decided to go ahead with this project.
I also have another project waiting to go, but my parts didn't come in yet. I'll keep yinz posted.
PWOC #53
2008 POWER WAGON RC
Sequentially Number #08-1505,
Inferno Red, Automatic
Mods to the PW;
Nerffed Mopar RockRails, Wheel Well Liners, Bushwacker Pocket Fender Flairs, Extang Tonneau Cover, Garvmin dezl 560LMT GPS, Power Wagon Winch Kit, Line X Ultra Bed Liner, PIAA Headlight Bulbs, PIAA 580 Driving Lights (135 watt), PIAA 520 Fog Lights (135 watt), PIAA 520 ATP Off-Road Lights (135 watt), Locker Bypass, Modifed Rockcrusher Diff Covers, Mopar Utility Bed Rails and Tool Box, Warn Winch Wireless Remote Control, "el-cheapo" Inclinometer, Airaid CAI, Winch TPS Bypass, Had 35" Cooper STT's now 35" Toyo's, Mopar Spare Tire Lock, 'T' Steering Linkage, Modifed PSC Steering Brace, P3 Brake Controller, Modifed Fusion "mall crawler" rear bumper, PIAA 1500 Back-Up Lights, 1Ton HEMI Tranny Cooler, Leer 100XR Bed Cap, Factory Tow Mirrors, CenterLine Rims 17x9-5.25 BS, Mag-Hytec Tranny Pan, AutoMeter Gauges, PSC Extreme Hydro Assist Steering, Carli Track Bar, Carli Ball-Joints, Dynatrac FreeSpin Hubs, Snorkel, RCV Axles, EBC Pads & Rotors, Aluminess Front Bumper, BIG Pul-Pal and it's own body bag!, 60" Extreme Hi-lift Jack, and more riggin' equipment, Carli Long Travel Air Bags, Bilstein 7100 Shocks - Carli Valving, MORE STUFF COMIN', TTI headers, Somebody's long arm, 7.2L MOTOR
Mods to me; Ti hip replacement. Zerk fitting in knee. Now it's gets greased more than some guys front drive shafts. I've been Used, Abused and Recycled!
Survivor of The Cold War,
Heaven's Gate, The Grand Conjunction, The Pleiadeans Landings, Y2K, The Winch Mob Banning, The Mayan Apocalypse, and some other covert stuff. Future ISIS killer!
"Moab '10, '12, '14",
"Rausch Creek-Spring, Fall '11, Spring '12, Summer '13, Summer '14"
RUSS
RustyPW08 is offline
Quote Quick Reply
post #2 of 68 Old 06-14-2009, 08:46 AM
RAM MAN
Originating Member
RAM MAN's Avatar
protection for the bottom of the truck ?
Good luck on your project.
RAM MAN is offline
post #3 of 68 Old 06-14-2009, 10:22 AM
TwinStick
Bumper or Rock Sliders ???
08' PowerWagon w/6-speed manual G-56. 05' 30' toyhauler camper.(10,500lbs)
Hellwig LoadPro 35 bolt on 4 leaf helper springs.
No honey, I'm NOT done buying shit for the truck yet !!!
PurpleCrainium Diff Guards
K&N air filter --- WeatherGuard 20" black bed toolbox.
winch TPC bypass
Dual battery set up w/2 Sears DieHard Platinums-Gp 65 under hood-Gp 31 Marine deep cycle in bed toolbox w/plug-n-play set up. Custom 2000/4000w inverter set up w/quick connect. Triple bike mounts above the bed- custom made by me.
Crapload of recovery gear-always subject to adding more.
Fab Four rear bumper. Soon to be- a BuckStop Baja front bumper.--Temporarily on hold, see reason below.
Installed: Borgeson #000951 steering shaft. PSC steering brace(notched for PW by Rusty-thanks bud). Carli HD CroMo adjustable track bar. Carli CroMo control arms. Carli HD upper & lower balljoints x 2 sets (replaced under warrenty) & triple sealed u-joints in front axle shafts & rear driveshaft. Moog HD tierod ends x 4. Running total is now $4800. Yup, now i'm broke !!!
What, you ask, is the difference between a Dodge Ram and a PowerWagon ?? PW frame part # 55398868AC---Reg 2500 #55398813AC
About 2" taller, 12,000lb winch w/mounting brace between framerails,electronic disconnecting swaybar(for awsome articulation),electronic locking axles front & rear(for true 4-wheel drive),tow pkg, fully skidplated,forged one piece Alcoa rims w/internal beadlock lips,larger diameter(one ton) axleshaft in rear,160 amp alt,HD battery,4.56 gears,low range electronic recalibration of gas pedal sensitivity,more but thinner leafs in rear spring pack(for better articulation), 33" BFG All-Terrain tires. 78.016:1 crawl ratio. All for $6100.00 more! Oh yeah, almost forgot-Bilstein shocks. Gear ratios: 1st 6.29:1 2nd 3.48:1 3rd 2.10:1 4th 1.38:1 5th 1.0:1 6th .79:1.. Rev 5.74:1.
TwinStick is offline
post #4 of 68 Old 06-14-2009, 10:43 AM
powderwagon
powderwagon's Avatar
Quoted: 1 Post(s)
Sweet looking idea for rock rails... Definately keep the updates going.
2006 Powerwagon QC
Patriot Blue
A.R.E Shell
Smoked Clearance Lights
Yakima in-track Ski Rack
EZ-Down Tailgate assist
35" Toyo m/t...Siped
powderwagon is offline
post #5 of 68 Old 06-14-2009, 03:44 PM Thread Starter
RustyPW08
Moab Tested
RustyPW08's Avatar
Talking
Look in my sign for an idea.
PWOC #53
2008 POWER WAGON RC
Mods to the PW;
RUSS
post #6 of 68 Old 06-15-2009, 12:04 AM
OCEAN
OCEAN's Avatar
your garage is way cleaner than mine!
OCEAN is offline
post #7 of 68 Old 06-15-2009, 02:18 PM Thread Starter
RustyPW08
Moab Tested
RustyPW08's Avatar
The only thing that get parked in the garage is the bikes. The garage door is only 6ft high. The garage became my work shop with a large outside door. LOL The floor is getting all chipped up from the kick stand on the bikes. And it's only 3 years old. 2 part epoxy mix.
PWOC #53
2008 POWER WAGON RC
Mods to the PW;
RUSS
post #8 of 68 Old 06-23-2009, 10:45 AM Thread Starter
RustyPW08
Moab Tested
RustyPW08's Avatar
Talking Up date
OK, I got the tubing bent. I wanted 60deg bends. The guy I took the tubing to, said that he could do it. Since he does rollcages. I got a call from him. Said he can't bend it to 60deg without kinking. So I ended up with 45 deg bends. He said that the thickest DOM tubing he has bent is .090. He's never try .120. Now he has. I fitted and tack welded everything at home, and drove to work so that I could tig weld everything up. Talk about a LLOONNGG day. I still have to paint them yet. I believe now that I can pick the PW up with a High Lift jack using the nerf bars. Enjoy the
PWOC #53
2008 POWER WAGON RC
Mods to the PW;
RUSS
post #9 of 68 Old 06-23-2009, 10:50 AM Thread Starter
RustyPW08
Moab Tested
RustyPW08's Avatar
Talking More pic's
More
PWOC #53
2008 POWER WAGON RC
Mods to the PW;
RUSS
post #10 of 68 Old 06-23-2009, 10:57 AM Thread Starter
RustyPW08
Moab Tested
RustyPW08's Avatar
Talking
For sale. A pair of Carr side steps for rock rails.
PWOC #53
2008 POWER WAGON RC
Mods to the PW;
RUSS
post #11 of 68 Old 06-23-2009, 01:17 PM
danny.p.watts
RedMan
danny.p.watts's Avatar
Send a message via MSN to danny.p.watts
Originally Posted by RustyPW08 View Post
More
Nice job with the welds , I am looking to do the same thing, how much did you pay for the metal? If you don't mind giving up that info.
Power Wagon Registry #47
- SCT Tuner by
- front and rear rock ready bumpers (hand made out of 1/4" wall 4X6 tubing)
- Thuren suspension and steering upgrade (springs, shocks, shackles, and heim joints)
- stock 4gen tires (for now)_- Snorkel
- Rock Rails_____________________- CB Radio
- RockCrusher Front Diff Cover_____- Tool box and all necessary tools
- diff locker by-pass_____________ - Flow Mast Series 40 Dual Exhaust
- Illuminated Ram Hood Emblem_____- Rocker Panels Hurculined
- H2 Wheels w/moded hubcaps_____- Power Wagon Winch Strap
- Solar Battery Maintainer_________-
- Hide-Away Gun rack_____________- 4 Off road lights
Wife's ride "Faith" 2014 Charger RT Max
danny.p.watts is offline
post #12 of 68 Old 06-23-2009, 01:38 PM Thread Starter
RustyPW08
Moab Tested
RustyPW08's Avatar
Talking
Thanks. I got the DOM tubing from Metal Depot. 2, 10ft pieces and 1, 4ft piece was $229 with shipping. Had the be shipped by freight. Too long for UPS. Didn't need the 4ft piece. Now I got a nice cheater bar.
PWOC #53
2008 POWER WAGON RC
Mods to the PW;
RUSS
post #13 of 68 Old 06-23-2009, 01:42 PM Thread Starter
RustyPW08
Moab Tested
RustyPW08's Avatar
Talking More pic's
More
PWOC #53
2008 POWER WAGON RC
Mods to the PW;
RUSS
post #14 of 68 Old 06-23-2009, 02:56 PM
powderwagon
Quoted: 1 Post(s)
ooooohhhhh, that's damn good looking. Nice work. Now let's see a pic of it being used with a high-lift jack and drug over some rocks
2006 Powerwagon QC
Patriot Blue
A.R.E Shell
post #15 of 68 Old 06-23-2009, 03:18 PM
SchroederMP
living life
SchroederMP's Avatar
Send a message via Yahoo to SchroederMP
Looks professional man! Great job! Def looks great on your wagon!
2005 CTD 4x4-5" Turbo back exhaust, Icebox CAI, Smarty, AirDog, built tranny, leveled, Linex Rockers
1993 Dodge Stealth 3.0L 5sp-Project/Gas Saver
SchroederMP is offline
post #16 of 68 Old 06-23-2009, 05:51 PM Thread Starter
RustyPW08
Moab Tested
RustyPW08's Avatar
Talking
I don't have to worry about shopping carts hitting it, and somebody openning doors on it. When I'm mall crawling. LOL
PWOC #53
2008 POWER WAGON RC
Mods to the PW;
RUSS
post #17 of 68 Old 06-23-2009, 06:52 PM
tmthunder
tmthunder's Avatar
Russ that looks awesome! Great job. Might have to look into doing that if I end up working with you in the near future again.
2010 Plum Crazy SRT8 Challenger Loaded, Hurst shifted 6-speed, CAI, Strut Tower Brace, Predator tuned, 180T-stat
2005 QC Power Wagon Silver Metalic loaded.
MAC CAI, SRT-10 A-Pillar w/ISSPRO Trans temp, 315/70/17 BFG KO's on H2 wheels, Rock Rails, Power Wagon Winch kit, KC Daylighters behind the grill, Back Rack, Magnaflow Y-pipe and MagnaPak muffler, Predator tuned
tmthunder is offline
post #18 of 68 Old 06-23-2009, 07:06 PM
crash1369
我愛貓
crash1369's Avatar
those are nice, i think the 45 bends are probably better then 60 anyway. they look good like that and I think it will help repel and surprises better
"At no point during your rambling, incoherent response did you ever come close to anything that could be considered a rational thought. We are all now dumber for having listened to it. I award you no points, and may god have mercy on your soul."
crash1369 is offline
post #19 of 68 Old 06-23-2009, 07:33 PM Thread Starter
RustyPW08
Moab Tested
RustyPW08's Avatar
Talking
I charge by the beer! LOL I got a"FEW" hours in this. You figure, there is 20 joint welds. I did the tig welding in the shop if those pic's look familiar. LOL
Hey, you want to buy a power plant? LOL We're up for sale. They won't tell us who the 3 bidders are. Management (Bill) told us we are going to know this week if we are sold or not. LOL
PWOC #53
2008 POWER WAGON RC
Mods to the PW;
RUSS
post #20 of 68 Old 06-23-2009, 10:40 PM
TwinStick
Looks awsome. Great job. I think the 45 deg bends are better, as things will slide around them better, than a 60 deg bend.
That is exactly what I was thinking of doing when money and time allow.
winch TPC bypass
New Project Jcturner03 2G Dodge RAM - 4X4 Talk 8 01-26-2009 01:22 PM
My new project Lmopar69 1918-1947 Dodge Trucks 4 08-19-2008 10:49 PM
New Project lordfeyr 3G Dodge RAM - General Talk 78 03-24-2008 03:20 PM
