torque converter problems?
955 views 1 reply 2 participants last post by  six pack
#1 ·
Hi,
i am new to this site and i have to say it is really cool!
but anyway, i have a 1997 dodge 1500 4x4 w/ a 318 and a 46re tranny. the pickup itself has 101 clicks, but the tranny is a rebuild right from DC and it has 36k on it. the overall performance of the transmission is good but my converter locks and unlocks way too easy. at around 60-80 is when its at its worst, and i usually cant keep it in od when going down the freeway. my tires are stock size and 3.55 gearing. a couple guys i know say you can put a different valve in the tranny to give it more pressure. i am kind of brain dead when it comes to electronic trannys the 727 is more my cup of tea.
any help would be appreciated
HAPPY NEW YEAR!!
thnx
jet
#2 ·
The overdrive is controlled electronically by the PCM. Engine load(vacuum, throttle opening) is what determines if the controlled needs to shift out of O/D or Lock-up.
You may have engine performance issues that are causing your excessive shifting, things like a plugged catalytic converter will
exhibit symptoms like this.
Take it to a good repair facility that is familiar with the product and get them to check it out for you.
Hope this helps:)
