Diode Dynamics: SL1 LED Headlights for Dodge Ram! USA Made! See Install Video! - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 18 Old 02-23-2018, 05:16 PM Thread Starter
Diode Dynamics
Sponsor
Diode Dynamics's Avatar
Quoted: 1 Post(s)
Arrow Diode Dynamics: SL1 LED Headlights for Dodge Ram! USA Made! See Install Video!
SL1 LED Headlight for Dodge Ram
Diode Dynamics is pleased to offer the USA-made SL1 LED headlight for Dodge Ram applications.
SL1 LED Headlight. If you're looking to improve your visibility at night, you've probably seen many options available for LED upgrades. There's plenty of LED bulbs on the market, but they all have their shortcomings. They're too big to install, have no hotspot in the beam pattern, or they simply stop working after just a few months. With its compact size, optically correct output, thermally-modeled cooling, and boost-mode electrical circuit, the SL1 LED finally provides a true upgrade in performance.
Street Legal Output. Don't be fooled by high lumen numbers or "projector specific" bulbs. Your car's headlights are designed to focus light. If the light source is out of focus, it doesn't matter how bright it is - you won't have a focused hotspot of light to shine down the road - just more glare. To correct this, the SL1 LED headlight bulb was engineered with advanced optical design software, to perfectly match filament location. This allows the SL1 LED to focus light just like an original bulb, preserving the focus and hotspot, with no added glare. It produces a functional beam pattern on the road, in compliance with photometric standards, for a safe, functional output, which we call Street Legal.
Tested to Perform. We test the SL1 bulb in factory headlamps, and measure the entire beam pattern using specialized equipment. It's an elaborate affair: a headlight is mounted to a computer-controlled rotating head called a goniometer. Light shines down a tunnel, where a sensor collects data as the headlight is rotated. The entire beam pattern is mapped, and we compare the total output to the original halogen, confirming that the SL1 bulb shines more light in the hotspot, without adding extra glare on the road. The test results speak for themselves: in most lamps, like the 2015 F-150 Halogen lamp below, there is 30-70% more light in the critical hotspot, with no added glare or spread of light. With optical engineering, testing, and validation in the application, we can assure correct optical performance.
Staying Cool. You may have seen bulbs that use large straps for cooling, or fans that just make noise. These bulbs run hot, resulting in degradation of output after a few months. When it comes to cooling, proper engineering is required to efficiently remove heat from the bulb. In the SL1, a copper core board, thermal phase-change material, and thermally-modeled zinc casting get heat to the base, where base fins release it, designed for aerodynamic performance in conjunction with the flow rate and pressure of the Sunon bearingless microfan. The result is a highly-effective and reliable cooling system, keeping the bulb running at maximum potential.
Fitment. With its patent-pending design, the SL1 LED fits where other bulbs won't, without cutting or modification. There's no hanging metal straps, just a compact bulb that plugs right in, with a nylon-reinforced shroud. Only slightly larger than a standard halogen bulb, it fits behind dust caps and in tight spaces. The base sizes are keyed for exact applications, not one-size-fits-all, and the compact driver easily tucks away.
Reliability. Every part of the SL1 LED was designed for reliability, from the high-temperature teflon wire, to the zinc castings, to the reinforced plastics. The compact driver uses a unique boost-mode circuit, which prevents thermal imbalance in the LEDs, and has transient protection for long life in automotive circuits. Finally, the SL1 bulb was put through its paces in our environmental testing chambers - where the bulb successfully performed through dozens of thermal cycles, from -40 through 150 degrees Celsius. The SL1 will keep performing for years, and is backed by a three year warranty.
Experience. After over a decade in business, Diode Dynamics is the most trusted name in automotive LED lighting. Unlike every other LED distributor, we manufacture and engineer products ourselves in the United States, for high quality and fast time-to-market of the newest and brightest LED technologies. We pride ourselves in offering only quality LED products, that will exceed your expectations.
Specifications
Measured Lumens: 1630 (per bulb)
Color Temp (CCT): 5700K Power (watts): 20.2
Operating Voltage: 5-16V
Current (amps @ 13.2V): 1.58 Polarity:
Polarity Specific LED Emitter: Luxeon Z ES
Connector(s): OEM-Size Plug and Play
Driver Features: External, Waterproof, Constant Current
Materials: Copper PCB, PP-TD30 Base, Zinc Heatsink
Cooling: Active, Mag-Lev Microfan
Compliance Ratings: FMVSS108 Beam Pattern, SAE J575 Durability Test
Click To Order Your Dodge Ram LED Headlight Replacements:
Diode Dynamics SL1 Low Beam LED Headlight for 2009-2018 Dodge Ram (non-projector)
Diode Dynamics SL1 Low Beam LED Headlight for 2013-2015 Dodge Ram (projector)
Diode Dynamics SL1 High Beam LED Headlight for 2009-2018 Dodge Ram
*Diode Dynamics Anti-Flicker Modules are required for these applications*
If you have any questions, please don't hesitate to post, PM, email [email protected]
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Diode Dynamics is offline
Quote Quick Reply
post #2 of 18 Old 03-02-2018, 11:40 AM Thread Starter
Diode Dynamics
Sponsor
Quoted: 1 Post(s)
How to Install 2013-2015 Dodge Ram Headlight LEDs (Projector) | Diode Dynamics
post #3 of 18 Old 03-21-2018, 04:24 PM Thread Starter
Diode Dynamics
Sponsor
Quoted: 1 Post(s)
Customer Submitted Image with SL1 Installed in a 2015 3500 Laramie:
post #4 of 18 Old 04-11-2018, 11:46 AM Thread Starter
Diode Dynamics
Sponsor
Quoted: 1 Post(s)
Diode Dynamics | About Us
post #5 of 18 Old 04-20-2018, 03:41 PM Thread Starter
Diode Dynamics
Sponsor
Quoted: 1 Post(s)
Engineering | The Diode Difference | Diode Dynamics
post #6 of 18 Old 05-17-2018, 09:18 AM Thread Starter
Diode Dynamics
Sponsor
Quoted: 1 Post(s)
Behind the LEDs: Trevor Dobbins
post #7 of 18 Old 05-17-2018, 12:59 PM Thread Starter
Diode Dynamics
Sponsor
Quoted: 1 Post(s)
Originally Posted by Loki223 View Post
Any real world in use shots yet? not just up against the wall? the one thread i've seen was with projectors and were less then favorable, i'd love to see some road pictures
Diode Dynamics SL1 LED Headlights installed in a Dodge Ram Quad Reflector Headlight provided by authorized dealer & Dodge Ram lighting expert, RetroShop
SL1 LED Low-beam:
SL1 LED High-beam:
post #8 of 18 Old 08-30-2018, 10:13 AM Thread Starter
Diode Dynamics
Sponsor
Quoted: 1 Post(s)
Do LED Headlights Work In Projector Headlight Housings? Diode Dynamics SL1 Review
Headlight Revolution
post #9 of 18 Old 04-23-2019, 01:30 PM Thread Starter
Diode Dynamics
Sponsor
Quoted: 1 Post(s)
Don't forget to shoot us a PM for FREE USPS shipping on any U.S order!
Jake H.
Diode Dynamics
post #10 of 18 Old 05-17-2019, 04:17 PM Thread Starter
Diode Dynamics
Sponsor
Quoted: 1 Post(s)
LED Focus: What you need to know!
Are you looking to make the switch from halogen to LED headlight bulbs? Before you do, check out this video to ensure you choose the best one.
Good optical focus means more light further down the road where you need without any glare. We put together this video to highlight what to look for when choosing an LED headlight bulb for your vehicle. Check it out! And don't forget to shoot us a PM for free USPS shipping on any U.S order!
Jake H.
Diode Dynamics
post #11 of 18 Old 05-24-2019, 03:12 PM Thread Starter
Diode Dynamics
Sponsor
Quoted: 1 Post(s)
post #12 of 18 Old 05-29-2019, 10:37 AM Thread Starter
Diode Dynamics
Sponsor
Quoted: 1 Post(s)
Think having LED headlight bulbs shine light 360-degrees is a good idea? Think again! Check out this video to see why!
post #13 of 18 Old 06-03-2019, 04:31 PM Thread Starter
Diode Dynamics
Sponsor
Quoted: 1 Post(s)
Don't forget to shoot us a PM for FREE USPS shipping on ANY U.S order!
Jake H.
Diode Dynamics
post #14 of 18 Old 06-04-2019, 11:26 AM Thread Starter
Diode Dynamics
Sponsor
Quoted: 1 Post(s)
How hot an LED headlight bulb gets has a BIG impact on how bright it will be over time and how long it will last. Check out this video to see if your headlights are getting too hot!
post #15 of 18 Old 06-21-2019, 02:33 PM Thread Starter
Diode Dynamics
Sponsor
Quoted: 1 Post(s)
In our latest video, we answer one of the most popular questions about headlight upgrades: Which is better, HID or LED? Check it out!
Jake H.
Diode Dynamics
post #16 of 18 Old 07-01-2019, 03:15 PM Thread Starter
Diode Dynamics
Sponsor
Quoted: 1 Post(s)
Don't forget to shoot us a PM for free USPS shipping on any U.S order!
Click Here To Shop Now
Jake H.
Diode Dynamics
post #17 of 18 Old 07-05-2019, 04:48 PM Thread Starter
Diode Dynamics
Sponsor
Quoted: 1 Post(s)
July 4th sale! 20% off all diode dynamics products!
Jake H.
Diode Dynamics
post #18 of 18 Old 07-09-2019, 01:01 PM Thread Starter
Diode Dynamics
Sponsor
Quoted: 1 Post(s)
Measuring Headlight Output | Diode Dynamics
How are headlight output patterns measured at the factory level? How do you test to see if a headlight is meeting SAE and DOT beam pattern requirements? Here at Diode Dynamics, we've invested in a goniometer to accurately measure and map the entire beam pattern and ensure our products are adding light output without adding extra glare.
Check out the video to see how it works!
Click Here to learn more about our SL1 LED Headlight Bulbs
Jake H.
Diode Dynamics
Diode Dynamics: SL1 LED Headlights for Dodge Charger! USA Made! See Install Video! Diode Dynamics Diode Dynamics 12 07-09-2019 12:59 PM
2013-2017 Dodge Ram RGBWA Multicolor & Switchback LED Boards! See Installed Pictures! Diode Dynamics Diode Dynamics 17 07-05-2019 04:40 PM
Dodge Challenger Fog Light LED Bulbs! USA Made SLF! Match OEM-HIDs & Halo DRLs! Diode Dynamics Diode Dynamics 24 07-05-2019 04:27 PM
Diode Dynamics Universal RGBW™ Multicolor LED Demon Eyes! USA Made! Diode Dynamics Diode Dynamics 31 07-05-2019 04:25 PM
Diode Dynamics: Dodge Charger Reverse/Backup LED Bulbs! Plug & Play Install! Diode Dynamics Diode Dynamics 2 07-05-2019 04:23 PM
