Electrical draw (informational) - found an issue I have been chasing for 6 months - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 4 Old 08-21-2019, 08:44 PM Thread Starter
ElkCon
For 6 months my van exhibited a very strange draw condition...
I tried many things to find it with no luck until one day one of the fuses blew...then I found the issue.
Here is some background. I dont drive the van very much in the winter, so it would just be outside waiting for spring. I would go out every few days and start it, run it and drive it if the roads were dry.
In the dead of winter, one cold day it didnt start, so I wrote it off as severe cold and maybe a crappy battery. I would charge the battery and it would start and hold its charge for days. Then when I got it going in the spring, I found that the battery would be totally dead a few days per month.
I tried to diagnois it a few times with different results each time.
Sometimes there ammeter would so .2 A of a draw...sometimes there was less than that and then sometimes there was more than that.
I couldn't find it. I should have thought about disconnecting the TV, Wii and TV tuner but I never did. I had put in other accessories too like a CB, sub amp and auxiliary fan so I tested those on occasion along with the fuse box and never found anything definitive.
In the midspring, I bought a new battery hoping it would fix it. It worked for a couple of months, but then the draw came back. I was perplexed and again, I should have been thinking about the other accessories. For a time during the summer, I was just putting my battery tender on it at night and that got me through.
Last week, I finally was given a clue. The TV fuse blew. What is strange is that it is a 15A fuse - quite hefty for a small 10in TV. So I started to disconnect the TV. That was a good pain in the ass. I had to take town the shelving system/TV mount, which is all wood, to get to TV supply line.
When I got the TV out, I heard something rolling around inside the TV. It didnt sound like just a small piece of plastic, it was a piece of metal.
I opened the TV and found that one of the metal mounting brackets that holds the tube into the TV case had broken off. It was about the size of a half dollar.
So, as soon as I unhooked the TV the draw was gone. I repaired the TV and it worked just fine. Evidently, that bracket would bounce around inside the TV and lay on the circuit board a certain way, causing a draw. Then I would drive it, the bracket would move, and the draw would be gone...
It was strange but true...I am so glad that it is gone
ElkCon is offline
Quote Quick Reply
post #2 of 4 Old 08-25-2019, 07:40 AM
alloro
Elder User
Quoted: 35 Post(s)
Those types of intermittent issues are beyond frustrating. I'm glad to hear you found and fixed it.
alloro is offline
post #3 of 4 Old 08-25-2019, 06:34 PM Thread Starter
ElkCon
Thanks alloro. I'm really happy now
Just ordered a LCD for it!
ElkCon is offline
post #4 of 4 Old 08-27-2019, 08:04 PM
Mikey13
1973 Dodge B100
Mikey13's Avatar
Persistence can be frustrating but usually pays off, not only with a fix but sometimes you can tell yourself "damn I'm good"...
Mikey13 is offline
