anyone build a 390 stroker? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 4 Old 05-02-2019, 12:45 AM Thread Starter
reek
Quoted: 13 Post(s)
I have 3 vehicles in need of fresh motors. I'm probably going to go ATK 408 stroker for my 72 D100. My wife's chevelle will probably end up with an LS. I'll be working overtime until next Christmas to get this done. So, that puts me with the dilemma of what to do with my 73 d100. it will be my daily driver and not a weekend toy like the other two. I have a good 318 magnum block to work with. I could get the bottom end done at a local machine shop and build a 390 stroker. this would save me money and give me a bit more oomph than putting a 318 back in the truck.
I've not found much on the magnum 390 stroker. anyone build one? any pros / cons if I'm considering this 'budget' build? any help or info appreciated.
reek is offline
Quote Quick Reply
post #2 of 4 Old 05-04-2019, 08:10 AM
Moparite
Moparite's Avatar
Quoted: 397 Post(s)
I don't see the logic of spending the money on a stroker kit to gain 72 CI. A 360M should be the starting point. Depending on what you call "budget' build" the stroker kit cam/lifters and new heads machining isn't exactly what i consider "budget".
Moparite is offline
post #3 of 4 Old 05-04-2019, 09:49 PM Thread Starter
reek
Quoted: 13 Post(s)
pretty much what a lot have said. not much of a budget build I know. but I have a good block in possession and I'll be building it over some time. Just looking for input on the build more than reasoning why. although it could be argued, the why part is in the "cons" list of the build.
reek is offline
post #4 of 4 Old 05-05-2019, 08:03 AM
Moparite
Moparite's Avatar
Quoted: 397 Post(s)
It's only 30 Ci difference away from the 360. I think another option would be to find a low mile 360 and put that in. Here is a pic of the cam lobes on a 360 with 200K(at least that's what i was told). I took apart 318 and found the same thing worn cam lobes. A low mile block shouldn't have this problem witch will save you money on replacing the cam/lifters. Don't know if you looked for replacement cams for the magnum motors or not but what you will find is either the well known cam manufactures(comp cams) or engine tech witch offers a oe replacement. Who makes engine tech parts??? Never heard of them before and i am not putting some Chinese made crap in my engine.
Moparite is offline
Monsoon Mikes 2017 Ram 1500 Big Horn Build MonsoonMike Vehicle Build Threads 13 02-22-2019 01:49 PM
408 storker build mullinax05 2G Dodge Ram Performance Talk 136 01-19-2019 04:10 PM
408 Stroker Exhaust RedneckMarine98 2G Dodge Ram Performance Talk 5 08-27-2018 06:18 PM
SOLD 2005 Dodge Ram QC 392 Stroker kurupt17 For Sale - Dodge Trucks 0 08-25-2017 06:43 PM
Found My Build Sheet MTP0ckets 1972-1987 Dodge Ram Trucks (D, W-series) 2 06-05-2017 01:21 PM
