2006 Charger RT Daytona 5.7L needs new engine. Compatibility question - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 3 Old 01-10-2018, 04:23 PM Thread Starter
Daytona1177
Quoted: 1 Post(s)
Long story short, we have a 06 Charger RT Daytona with a 5.7L engine that we’ve been told needs a new engine. Wandering if an 5.7 L engine coming out of a 2016 Dodge Challenger RT would be comparable. Reason I ask is we have access to the engine coming out of a car that was totaled out, all damage being in the rear of the car so engine and tranny etc are in tact . Please any and all advise if this could work would be greatly appreciated.
Daytona1177 is offline
post #2 of 3 Old 01-10-2018, 04:24 PM Thread Starter
Daytona1177
Quoted: 1 Post(s)
I meant wandering if it would be compatible ....
post #3 of 3 Old 01-31-2018, 11:13 AM
HemiLonestar
Red Trucker
HemiLonestar's Avatar
Quoted: 60 Post(s)
Short answer no. Long answer, the '16 engine has VVT and a different crank wheel, not to mention different tuning, etc. Your PCM is not designed to run that engine. So in order to even try you would need:
1. Harness alterations
2. PCM swap with trying to find someone to flash modules correctly so they talk to the car and engine correctly
3. There may be accessory drive differences
4. Eagle intake has the fuel inlet on the opposite side so you would need the crossover line to mate it with your existing fuel system
5. Probably more things I haven't listed
Can it be done? Yes. Are you going to really pay for it (probably more than it's worth)? Also yes. Much easier route (if you're trying to get it back on the road) is get the engine rebuilt, buy a rebuild (most times these come with warranties) of find a used 05-08 5.7 from a 300, Magnum or Charger. Truck engines from 03-08 can be used but they require front cover, oil pan, etc changes to drop them in an LX.
03 Hemi Ram, 05 Magnum R/T, 06 Charger R/T
HemiLonestar is offline
Code list slingin_mudd 3G Dodge RAM - General Talk 0 08-27-2017 08:39 PM
