2003 Quad Cab 1500 4.7 Engine Suggestions - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 3 Old 07-26-2017, 11:37 PM Thread Starter
Revvv
Last year the engine in my Ram died at about 250,000 miles. Long story short, it dropped the lower radiator hose and ran hot before the computer and guages could register. The engine ran hot enough to melt the catalytic converter and almost completely clog the exhaust.
I did not check anything like I should have. I refilled the engine with coolant and it struggled to fire. It acted as if the engine was hydrolocked. I pulled the plugs and everything was fine. I fired it up again and drove it home. The engine ran hot as I pulled into my driveway. It was a 30 minute ride.
I pulled the dipstick and found a bad milkshake. It also smelled like rotten eggs due to the clogged exhaust. I pulled the heads and decided to stop there. The heads were destroyed (but they were surprisingly not warped).
I am certain the short block is a total loss after sitting for a year with the residue of oil and coolant. Plus I left the pistons open to the elements.
Now I am looking for a long block 4.7 to get the truck going again. Any suggestions would be appreciated. I just want to drop another engine between the fenders without a lot of headaches. That means I am staying with the 4.7 engine.
The salvage yards in my area are useless, and so far I am not finding any crate engines, or reman long blocks that are not $2000 and up, plus a core.
I need suggestions guys. I am tired of driving my old Mustang. I have no room, and I can't do anything I need to with that little car.
Sent from my SM-G930V using Tapatalk
Revvv is offline
post #2 of 3 Old 07-27-2017, 10:46 AM
HemiLonestar
Red Trucker
HemiLonestar's Avatar
Quoted: 62 Post(s)
You don't have a zip code so I can't help you any further, but have you tried Ebay or car-part.com? Car-part will give you listing with price and distance from you. You will not find a reman for the price range you are looking for, but there should be some decent enough used ones out there.
03 Hemi Ram, 05 Magnum R/T, 06 Charger R/T
HemiLonestar is offline
post #3 of 3 Old 08-30-2017, 11:55 PM Thread Starter
Revvv
30814 is my zip
Revvv is offline
Lift Suggestions 07 Ram 1500 4x4 Bakerfish1717 3G Dodge RAM - General Talk 0 02-15-2017 01:24 PM
2004 Ram 1500 Quad Cab 4x4 Glove Box Switch rinkrat98 3G Dodge RAM - Interior/Exterior Talk 2 11-14-2016 09:20 AM
2001 1500 2wd cab swap to 1999 2500 4x4 echo5 2G Dodge RAM - General Talk 0 11-03-2016 05:49 PM
RAM 2013 1500 ST Crew Cab : Replacement for stock shocks? Cainlord 4G Dodge RAM - 4X4 Talk 1 10-03-2016 03:11 PM
2002 Dodge Ram 1500, Quad Cab, SB, SLT - Not Running - $3999 ruprectgern For Sale - Dodge Trucks 0 09-21-2016 05:21 PM
