Transmission or axle - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 5 Old 11-20-2014, 08:20 AM Thread Starter
jeknotts
The problem happened about a month ago. I was driving home from work and stopped at a red light and when it turned green i pressed the gas, but the car would not go. Luckily no other vehicles were around so I could coast it to the shoulder. I have no gears, its like the tires are not connected to the transmission and are in permanent neutral. When switch from D to P i can hear the transmission grind as if I was switching it while I was driving so the shifting part of the transmission seems to be working fine. I read somewhere that if a axle broke that it would not allow the car to move? I was hoping you guys would have an easy fix for this as a new transmission is not an option. When I press the gas peddle while in drive my speedometer also moves as if I was moving.
jeknotts is offline
Quote Quick Reply
post #2 of 5 Old 11-20-2014, 08:42 AM
89gtcs
Quoted: 16 Post(s)
That is a problem with your transmission. Scan for trouble codes and post them here.
2006 Dodge Ram 1500 QCSB SLT 4x4 5.7 Hemi: 154,000 miles
| 275/60/20 Cooper Discoverer ATP | 1-ton HD trans cooler | SRT A-pillar/Aeroforce Interceptor gauge | 3" MBRP exhaust | JetStream air scoop
89gtcs is offline
post #3 of 5 Old 11-20-2014, 09:12 AM Thread Starter
jeknotts
I don't have a scanner but using key on/off method gives me 11,12,32, and 55.
jeknotts is offline
post #4 of 5 Old 11-20-2014, 09:30 AM
89gtcs
Quoted: 16 Post(s)
None of those seem to refer to the transmission...interesting. I would investigate those separately. You can google them and pull up the definitions.
Some things to check:
1. shifter linkage - is it connected? is there excessive slop? May need adjustment.
2. Does the car roll in N, R and D? Does it stay still in Park? Make sure you're in the gear you think you're in
3. Check trans fluild level. Low/no fluid can cause behavior like that. If fluid is there, is it burnt?
4. If you lift up the car and spin the wheels, do they spin freely? Check for broken CV shafts and listen for drivetrain noise
Also, specs on your car would help - I don't see anything specific in this thread.
89gtcs is offline
post #5 of 5 Old 03-19-2019, 09:56 PM
ralphael101
Was it your axle/CV joint?
ralphael101 is offline
New Transmission fluid, gasket & pan - now transmission dead Benabi 2G Dodge Durango General Talk 13 11-20-2012 06:03 PM
Swap a 1500 single wheel axle for a 3500 dually axle? oefootball_70 3G Dodge RAM - Drivetrain Talk 8 05-18-2009 05:37 PM
left front axle seal leak 2500 dana m60 axle FIREMANJEFF 2G Dodge RAM - Drivetrain Talk 1 04-19-2008 11:22 PM
2500 Rear axle vs. 3500 rear axle?? fymn69 3G Dodge RAM - Drivetrain Talk 1 12-23-2006 07:54 AM
swapping my 2000 axle for a 91-96 dakota axle. daksport2000 2G Dodge Dakota General Talk 3 09-20-2003 11:41 AM
