Pure Performance Long Arm Suspension - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 3 Old 12-14-2009, 12:19 AM Thread Starter
Skyd Ram
DodgeTalk Sponsor
Skyd Ram's Avatar
8LUG Truck Gear is proud to announce the new Long Arm Suspension Systems from:
Pure Performance has just upped the ante by introducing a bunch of new long arm suspension systems for the 03-up Dodge Ram 2500/3500!
Starting at $1999
All of the systems feature their new long arm 4 link design which is a full featured long arm system with the industries strongest components and best design by far!
The lower control arms made from 2" solid alloy steel, upper control arms made of 1 5/8" solid alloy steel. The control arms feature a massive 1” shank, 2 ” head, ” wall thickness chromoly, rebuild-able spherical joint at the axle that takes up all the twisting found from high demands off-road while at the frame, they utilize the industry’s largest control arm bushing to provide a nice, smooth, quiet, in cab ride quality.
The long arms connect to two high clearance bolt in sub-frame cross members made from ” thick laser cut steel and are precision welded. The arms themselves are moved inboard of the frame to provide as much tire sweep clearance as possible.
All hard parts are backed by the Pure Performance exclusive Abuse Proof life time guarentee!
System Benefits:
•Better ride quality and handling.
•Completely bolt in long arm mounts.
•Better off road ability..
•Adjustable and serviceable upper and lower control arms.
These systems are available in 6" and 8" heights with a variety of options.
These range from conventional front coil/rear block systems all the way up to front and rear coilover conversions.
Check them all out at:
Products > Suspension > 5-6 inch lift kits
And:
Products > Suspension > 8 inch lifts
* We are offering these suspensions at an introductory rate of 15% off of MAP to DodgeTalk members until 1/31/2010. Just enter the coupon code "PURE15" after adding you system to the cart to calculate your special price.
[/SIGPIC]2014 CCSB 2500 Laramie 6.7 Cummins
Pure Performance/BMF/Toyo Equipped
2005 RCLB Power Wagon 5.7 Hemi
Bilstein/Toyo
Official DodgeTalk Supporter
Authorized Dealer for:
Carli Suspension/Pure Performance Suspension/Bilstein Shocks
Dynatrac Products/BMF Wheels/MBRP Exhaust/AFE intakes and Exhaust/Smarty tuners
/H&S Performance/Flo Pro Exhaust/Edge Products
Call us Toll Free at: 888-886-2480
Skyd Ram is offline
post #2 of 3 Old 12-28-2009, 01:43 PM Thread Starter
Skyd Ram
DodgeTalk Sponsor
Skyd Ram's Avatar
Only a few more days left for this deal!
Bilstein/Toyo
Skyd Ram is offline
post #3 of 3 Old 01-29-2010, 06:54 AM Thread Starter
Skyd Ram
DodgeTalk Sponsor
Skyd Ram's Avatar
This was extended until the end of January. There are a fre days left.
Bilstein/Toyo
Skyd Ram is offline
Installed - Pure Performance Long Arm 4 Link Upgrade on a 06 Dodge 2500 4x4 Top Gun Customz 3G Dodge RAM - 4X4 Talk 2 09-22-2009 03:44 PM
Pure Performance Desert Race vs Spirson suspension systems. ProjecT 9 3G Dodge RAM - 4X4 Talk 44 08-13-2009 08:43 AM
Rock Krawler/Pure Performance Long Arm Kit - BRAND NEW HEMI450HP For Sale - Truck Parts 4 07-20-2009 01:37 PM
Rockcrawler or pure performance long arm kit? hemiblues 3G Dodge Ram Performance Talk 5 02-21-2008 07:02 PM
