Does the 1999 model have an access panel for belt service? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 2 Old 06-17-2019, 02:23 AM Thread Starter
RamCruzer
RamCruzer's Avatar
Question Does the 1999 model have an access panel for belt service?
[/SIZE]
Does the 1999 Grand Caravan have a fender well access panel to give easier access to the lower pulleys for belt replacement ?
TIA
RamCruzer is offline
Quote Quick Reply
post #2 of 2 Old 06-18-2019, 09:45 PM
slcsoundguy
slcsoundguy's Avatar
Greetings. Yes, there is a drive belt splash shield. Jack up your vehicle and remove the right front tire. There you'll see the removable splash shield that when removed will give you access to change the belt(s).
If it sounds good, it is good!
2003 Grand Caravan CeeVee
1991 Dodge Ram B250
slcsoundguy is offline
Tags
access panel , crank pulley , fender well. , passenger side , serpentine belt
