Auto Headlight Flickering - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 11 Old 07-31-2016, 09:53 PM Thread Starter
Novia
Quoted: 9 Post(s)
Hello, is there anyone meet the flickering issue with your LED Headlights?
I order an LEDs for my 2009 dodge journey but it start flickering after one week, so anyone know whats wrong with the LEDs. Any idea will be very appreciated, thanks!
Novia is offline
post #2 of 11 Old 08-01-2016, 02:22 PM
DodgeCares
Dodge Cares
DodgeCares's Avatar
Quoted: 41 Post(s)
It flickers consistently? Have you had the opportunity to take it into a certified dealer? - Kevin T, Social Connect Team
DodgeCares is offline
post #3 of 11 Old 08-01-2016, 11:10 PM Thread Starter
Novia
Quoted: 9 Post(s)
Thanks for the reply.
My lights will turn off then come back on periodically. Checked out the alternator and battery both are fine, My frd working in 4S told me to buy a pair so called "capacitors" to have try. Just order one pair on Amazon, hoping these solve my issue with my LEDs.
Novia is offline
post #4 of 11 Old 08-02-2016, 10:00 PM Thread Starter
Novia
Quoted: 9 Post(s)
Waiting for the capacitors...any ideas are welcome to post here
Novia is offline
post #5 of 11 Old 08-07-2016, 12:42 AM
badblackram
badblackram's Avatar
Quoted: 3 Post(s)
Yes your friend is right. you need a pair of capacitors. The reason is the computer is sending pulse signals to your lights to make sure they are functioning properly. The flickering is the pulses sent by the computer. The capacitor works by leveling out the pulse into a steady current. Think of it as a filter.
2006 Ram 1500
4.7L- Gibson S/S ceramic shorties
Flex-a-lite 183 e-fan kit
Catless w/ 12279 magnaflow
Apm ram air hood w/ ram air intake
Painted grille, bumper, & handles
Painted headlights w/ Retrofitted morimoto projectors
Power slot rotors
Diablo Sport Trinity with Hemifever tune
2/5 McGaughy's drop kit
4.56 motive gears & Detroit Truetrac
Nitto 420s 285/50r20
badblackram is offline
post #6 of 11 Old 08-07-2016, 11:31 PM Thread Starter
Novia
Quoted: 9 Post(s)
Nice explain, make it easy to understand, thx.
Searching capacitors on amazon, some vendor mention "resistor" also with same function to solve flickering issue. So is there any difference between the two or these parts are in same work?
Novia is offline
post #7 of 11 Old 08-08-2016, 12:17 AM
badblackram
Quoted: 3 Post(s)
Resitors provide a draw. Much like a bulb. Once you install hid/led bulbs they will have less draw than a halogen bulb. Some computer systems will detect a bulb out. There is probably a threshold set and most leds and hid systems draw less current than a halogen bulb. So a resistor is used to up the current draw to that of a 50/55w halogen bulb. Therefore tricking the computer.
I dont think your journey requires them but it would not hurt to use them. Just remember, if you do get them, since they draw current they will get extremely hot and will melt plastic and even burn you.
2006 Ram 1500
Power slot rotors
post #8 of 11 Old 08-08-2016, 09:53 PM Thread Starter
Novia
Quoted: 9 Post(s)
So what about the resistor and capacitor combined together to use? I just receive my order from amazon but haven't installed.
Here's the link of my orderhttps://www.amazon.com/dp/B01DG9X0BM...ing=UTF8&psc=1
This photo is from the list, vendor mention lots of parts including capacitors, resistor, etc. Guess these parts combined to draw less current and mimic the original bulbs.
Keep on post after connected.
Novia is offline
post #9 of 11 Old 08-08-2016, 10:16 PM
badblackram
Quoted: 3 Post(s)
Hmm not sure about those. I always use separate components. I know if it really had a true load resistor that plastic housing will be melting within minutes. The description doesnt describe what the components are rated for so its hard to say. The capacitor looks normal though.
I always use The Retrofit Source for my lighting. They have some nice stuff.
Sent from my SM-G925R7 using Tapatalk
2006 Ram 1500
Power slot rotors
post #10 of 11 Old 08-15-2016, 11:23 PM Thread Starter
Novia
Quoted: 9 Post(s)
Got these decoders about one week to have a check.
Awesome decoder, it do works well, my bulbs without any flickering more.
The decoders consist of capacitor, resistor etc, it have some heat after one hour working but it's ok for me, not too hot.
Here're two pics before and after installing the decoder.
Novia is offline
post #11 of 11 Old 08-16-2016, 08:50 PM
badblackram
Quoted: 3 Post(s)
Glad they worked out for you.
2006 Ram 1500
Power slot rotors
Headlights flickering..... ch47keeper 1G Dodge Durango General Talk 2 10-24-2011 11:48 AM
headlight auto shut off after 8 minutes jimbobway69 3G Dodge RAM - General Talk 23 07-06-2010 11:11 AM
Flickering lights Braty23jl 1G Dodge Durango - Interior/Exterior 0 03-29-2007 04:48 PM
Auto headlight switch question Dale Wood Dodge Magnum SRT-8 Talk 2 10-31-2006 03:45 PM
All lights flickering on and off!!! donniedurango 1G Dodge Durango General Talk 2 07-06-2006 08:20 PM
