06 Mega w/ infinity sound - factory amp parasitic drain - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 5 Old 09-17-2019, 03:08 PM Thread Starter
VisionxOrb
Quoted: 1 Post(s)
have an 06 mega with Factory infinity system along with a pioneer avic and the corresponding PAC radio interface. Everything had been working well for years but then the system developed a parasitic drain with the factory amp. If I leave the fuse out for the amp, I can leave the truck parked for a month and still start. with the fuse in battery will be dead in 2 days. It has a constant 2amp drain.
Is there anything I can look at to fix it or?
2006 dodge Mineral Gray Megacab 4x4 1500 w/ hemi
Rock Krawler/Thuren hybred 5.5" xfactor lift, Diamo 17 Karats 18x10 w/ 5"bs, Dick Cepek FCII 325/65r18
Pioneer avic-D3 w/ bluetooth, Ipod, Sirius and IR illuminated backup cam
Carli minileaf pack, thuren extended shackles, Defiant Steering sector shaft stabalizer, Thuen trackbar, Custom thuren 5.5" springs, Thuren shockmounts, FOA 2.5" custom valved shocks, Thuren Bumpstops.
MB quart QSC 3way comps, 2 TC Sounds TC2+ 10s in a Foxacoustics megacab box
VisionxOrb is offline
Quote Quick Reply
post #2 of 5 Old 09-17-2019, 07:44 PM
guyonearth
Quoted: 32 Post(s)
Well, that's a pretty specialized electronics question, but off the top of my head I'd say it's probable you've developed a short in the amp section, either a stuck (or fused) internal relay, or a shorted capacitor.
guyonearth is offline
post #3 of 5 Old 09-18-2019, 02:12 PM Thread Starter
VisionxOrb
Quoted: 1 Post(s)
Thanks, I wasn't sure if there was a common problem somewhere that causes the amp not to go to sleep.
post #4 of 5 Old 09-25-2019, 07:46 PM
guyonearth
Quoted: 32 Post(s)
That's also a possibility, but I'd think you'd have to have a stuck or shorted relay for that to occur. Without knowing anything about the amp it's hard to say. It might be switched by 5 cent transistor that's gone bad, too.
post #5 of 5 Old 10-03-2019, 10:57 AM
Mikey13
1973 Dodge B100
Mikey13's Avatar
Good Job Troubleshooting!
Possible another audio component that is powered on the same circuit?
but sounds like you found the problem.
Mikey13 is offline
