list of part to buy for 1988 dodge w150 TBI to Carb swap - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 2 Old 03-17-2019, 05:39 PM Thread Starter
Markbadhorse
I need to know what to buy to swap a carb on to a 1988 dodge w150 318 3 speed auto. I can to the technical stuff myself but I need a list of stuff to buy
Thanks
Markbadhorse is offline
Quote Quick Reply
post #2 of 2 Old 03-20-2019, 04:01 PM
I8AHEMI
Quoted: 6 Post(s)
You can check out my 88 d100 build thread - I did the swap. The list kinda depends on which direction you are going with but if it’s the same motor - at least - carb/linkage/intake/distributor/ignition box and wires/ voltage reg/ fuel pressure reg/ depending on intake - there will be other little stuff like fittings/plugs/thermostat and housing? /Gaskets. What’s the condition of the rest of the motor bay ? Might as well replace hoses /clamps/ vac lines while your there if they are old.
I8AHEMI is offline
Rims for 2008 caravan....question Brendak 5th Gen Caravan Talk (08-Up) 0 09-23-2016 08:10 PM
