Belt squeal with a/c on??Summit pulley &gatorback belt/6rib - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 9 Old 06-08-2011, 04:24 PM Thread Starter
hawk02
Quoted: 1 Post(s)
Unhappy Belt squeal with a/c on??Summit pulley &gatorback belt/6rib
Just started using my ac this year and when the clutch engages it squeals like crazy when i take off for a few seconds then it is ok. the belt is a new one when i put on the summit pulley(i have the gatorback one they listed for it), the tensioner seemed a little weak so i just put on an oem mopper one, seems a little better but still squeals. the ac clutch seems a little stiff when you turn it by hand, not sure what it should feel like for comparison. with the truck running with the ac clutch engaged the belt looks like its flopping around between the alt pulley and the tensioner pulley, and then no movement with the ac off. sorry for the long post but wanted to make sure i gave everyone all the facts so hopefully someone can help, thanks as always guys.
hawk02 is offline
post #2 of 9 Old 06-08-2011, 06:40 PM
MikeHTally
Got 2 Hemis
MikeHTally's Avatar
Quoted: 62 Post(s)
Does sound a bit like the compressor is dragging too much, but I don't have any idea whether it should be easy or harder to turn the pulley by hand. The tensioner should move a fair bit with all the accessories engaged.
MikeHTally is offline
post #3 of 9 Old 06-08-2011, 07:04 PM Thread Starter
hawk02
Quoted: 1 Post(s)
my buddy said it could possibly be a bad or old belt that i got when i ordered my pulley, if it was sitting around for a while it could have "glazed" itself after installation or stretched. he said i should try a new belt before i diagnose it as the compressor. i did a search and there was a gates belt listed that was 3/4 of an inch shorter than the goodyear and i think it was also a 7 rib instead of 6 rib. anyone know anything about this, the # is K070976.
hawk02 is offline
post #4 of 9 Old 06-09-2011, 06:40 PM Thread Starter
hawk02
Quoted: 1 Post(s)
Bump for anymore info? Doing a new belt this weekend, not Goodyear.
hawk02 is offline
post #5 of 9 Old 06-09-2011, 06:55 PM
TheSatinPumpkin
Low N Slow
TheSatinPumpkin's Avatar
I think chefred runs the Gates K070976.
TheSatinPumpkin is offline
post #6 of 9 Old 06-10-2011, 07:29 AM Thread Starter
hawk02
Quoted: 1 Post(s)
Yeah I saw that but I think he also has the od alternator pulley. Will that belt still fit with the stock alt pulley?
hawk02 is offline
post #7 of 9 Old 06-10-2011, 03:15 PM Thread Starter
hawk02
Quoted: 1 Post(s)
hawk02 is offline
post #8 of 9 Old 06-10-2011, 05:26 PM
MADBRAD
MADBRAD
MADBRAD's Avatar
Maybe its the pulley. Sometimes the finish is too smooth and the belt has no traction. Try taking some sand paper or scotch brite to rough it up a little or worst case have it sand blasted. Cheap fix that may work!
MADBRAD
2006 Ram 1500 SLT 4x4 Regular cab short bed/ MDS HEMI
steel 17s painted black /265 70 17 BFG Rugged Terrain tires/3.55 LSD
tow hooks /front suspension skid plate
3" cat back Flowmaster original 40
dechromed/debadged
black grille/black bumpers
Truxedo Truxsport
Belltech drop shackles
personalized "MADBRAD" license plates
MADBRAD is offline
post #9 of 9 Old 06-10-2011, 06:59 PM Thread Starter
hawk02
Quoted: 1 Post(s)
Thanks
hawk02 is offline
Belt squeal Bushmaster150 1973-1993 Dodge RamCharger 4 01-24-2009 10:47 AM
Belt Schematic? Belt Part #? Whine From Belt. DurtyJ 3G Dodge RAM - General Talk 4 01-16-2008 06:02 PM
does your 3.0 belt FALL OFF or SQUEAL? We have the fix..... MiDnIgHtRuMbLeR Dodge Caravan General Talk 0 12-22-2006 09:57 AM
Belt Squeal tuneboy 3G Dodge RAM - General Talk 8 08-08-2006 05:53 PM
Fan belt squeal coachholland 1G Dodge Durango General Talk 12 11-26-2004 12:40 PM
