Severe Vibration at slow speeds - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 2 Old 04-24-2019, 02:41 PM Thread Starter
TheNerd
I have a 2003 1500 hemi 5.7 4x4 when I take off from a light or a stop sign I get a Vibration so bad it shakes the whole truck. I had carx look at it and they said I need a new rear end when they took the drive shaft off and turned the rearend by hand they said they can feel ruffness. Would it really be the rear end.
TheNerd is offline
Quote Quick Reply
post #2 of 2 Old 04-30-2019, 10:40 PM
Dtnel78
It could be possible but I'd get a 2nd opinion as a rear end on a vehicle can be expensive even if you swap it or even rebuild it yourself.
Was this shop you took it to a driveline, transmission TYPE shop or just a general shop?
Sometimes if it's a pinion bearing and hasn't went completely south you may get by replacing the bearing, race and seal and flushing the rear differential oil which if you don't know the history you can flush the rear differential.
If you want to see if you have shavings in the rear differential yourself or even learn how to check U-Joint or drivetrain let YouTube be your friend.
There's a YouTube channel called 1road or OneRoad, can't remember which way he spells it but he's got a video about changing the rear differential fluid and he's a rookie. That would be a good start if you suspect or want to check or flush it yourself.
Sent from my SM-N960U using Tapatalk
Dtnel78 is offline
Vibration In Transfer Case SamDodgeTexas 2G Dodge RAM - Drivetrain Talk 3 01-28-2018 09:48 AM
Vibration Mystery - 04 Ram 1500 Jason Harris 3G Dodge RAM - General Talk 7 10-09-2017 02:49 PM
05 Durango Vibration silentblinder 2G Dodge Durango General Talk 1 10-02-2017 05:40 PM
Driveline vibration? Or rear diff problem? 05ramqc 3G Dodge RAM - Drivetrain Talk 3 07-01-2017 06:51 PM
Groaning when turning at slow speed forward or reverse Bismarck 3G Dodge RAM - Drivetrain Talk 3 06-12-2017 06:58 AM
