Diode Dynamics: Dodge Charger Reverse/Backup LED Bulbs! Plug & Play Install! - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 3 Old 06-17-2015, 10:04 AM Thread Starter
Diode Dynamics
Sponsor
Diode Dynamics's Avatar
Quoted: 1 Post(s)
Arrow Diode Dynamics: Dodge Charger Reverse/Backup LED Bulbs! Plug & Play Install!
Dodge Charger Reverse/Backup Light LED
At Diode Dynamics, we carry a full line of LED bulbs, including three different levels of brightness for your Dodge Charger's reverse light or backup light bulb (921 / 3156).
Diode Dynamics offers the brightest, highest-quality bulbs on the market, which we have designed in St. Louis, Missouri. Your order will ship same day, and we're here if you need us for support and service. Every bulb carries with it a three-year limited warranty.
Your purchase includes two LED bulbs for perfect fitment in your Dodge Charger model year selection.
Diode Dynamics: 2006-2010 Dodge Charger Backup/Reverse Light
Diode Dynamics: 2011-2014 Dodge Charger Backup/Reverse Light
Bulb Design
921 Bulb Size:
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
HP36: Full 360 degree illumination with 36 High-Power Samsung LEDs. Aluminum base for optimum heatsinking, and non-polar design for easy installation.
XP50: Each of the four sides of this bulb contains two 5W-rated chips, and the top is fitted with two more under a projector lens. Housed in an aluminum casing with textured finish for maximum heatsinking properties.
3156 Bulb Size:
SMD27: 27 three-chip 5050-size Epistar SMDs arranged in 180 degrees. Six radial panels of three chips, and a forward-facing six-chip panel. Main body material is PCB.
HP11: Four side-firing 1.5W-rated Osram LED chips, and one 5W-rated LED chip on top, which is projected by a lens for maximum effective brightness. The bulb is housed in a machined aluminum casing, which provides superior heat diffusion for long life.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
Bulb Fitment:
2006-2010 Dodge Charger Model Years (921) use a quality inject-molded 921 terminal, with a sturdy base connector and proper pin alignment, designed for exact replacement of your factory 921 bulb. You will not need resistors for backup lights. Just replace the factory bulb.
2011-2014 Dodge Charger Model Years (3156) use a quality inject-molded 3156 terminal, with a locking base connector and proper pin alignment, designed for exact replacement of your factory 3156 bulb.
Included in your order is TWO BULBS.
COLOR
These LEDs illuminate in a crisp, cool, bright, white hue for maximum light output.
BRIGHTNESS
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
921 Bulb Size:
HP5: (92 lumens) Slightly lower brightness than OEM bulbs, but still provides the crisp, modern instant on/off of LED technology.
HP36: (210 lumens) Slightly higher brightness than OEM bulbs.
XP50: (410 lumens) Much brighter than OEM bulbs.
3156 Bulb Size:
SMD27: (205 lumens) Slightly lower brightness than OEM bulbs, but still provides the crisp, modern instant on/off of LED technology.
HP11: (310 lumens) Slightly higher brightness than OEM bulbs.
XP80: (510 lumens) Much brighter than OEM bulbs. These are bright!
Lumens. BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures.
QUALITY
LED Components. Diode Dynamics uses only the highest quality LED chips in the production of its bulbs. This means only brand-name suppliers such as Epistar, Cree, Osram, and Samsung.
While Diode Dynamics bulbs may look the same as others on the market, most copycat bulbs use economy-grade LED chips in order to reduce costs. This greatly reduces the reliability and overall brightness of the bulb when you compare it to Diode Dynamics.
Construction. Although LED technology allows for extremely long bulb life, the market is flooded with cheap LED bulbs that fail prematurely due to inferior construction. The worst enemy of LEDs is excessive heat, and when bulbs are not designed properly, they do not disperse heat as well, leading to premature failure.
Off-brand, cheap bulbs exhibit poor solder uniformity, high levels of flux in the solder, uneven chip placement, low-gauge terminal wires, poor assembly, and bulbs held together with inferior adhesives. At best, solder joints will crack and fail on low-quality LEDs after a few weeks of use. In the worst case, these bulbs can damage housings as the extra flux and adhesive evaporates and creates a residue on the lens of the housing.
Diode Dynamics bulbs are produced with modern, computerized equipment, and only the best materials, to ensure complete uniformity, high quality, and long bulb life. All Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited replacement warranty.
Questions? Feel free to ask here, PM, email [email protected] or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thank you!
Nick C.
Diode Dynamics
Diode Dynamics is offline
Quote Quick Reply
post #2 of 3 Old 07-07-2016, 09:00 AM Thread Starter
Diode Dynamics
Sponsor
Quoted: 1 Post(s)
Looking For Product Install Videos? Subscribe to Diode Dynamics YouTube Channel
post #3 of 3 Old 07-05-2019, 04:23 PM Thread Starter
Diode Dynamics
Sponsor
Quoted: 1 Post(s)
July 4th sale! 20% off all diode dynamics products!
Don't forget to shoot us a PM for free USPS shipping on any U.S order!
Click Here To Shop Now
Jake H.
Diode Dynamics
Dodge Ram Fog Light LED Bulbs! Upgrade your lights! Plug & Play Install! USA Made SLF Diode Dynamics Diode Dynamics 7 07-05-2019 04:30 PM
Dodge Challenger Fog Light LED Bulbs! USA Made SLF! Match OEM-HIDs & Halo DRLs! Diode Dynamics Diode Dynamics 24 07-05-2019 04:27 PM
Diode Dynamics Dodge Challenger Backup LEDs! Plug and Play Install! Diode Dynamics Diode Dynamics 14 07-05-2019 04:21 PM
LED backup bulbs Grayson 3G Dodge RAM - Interior/Exterior Talk 1 07-22-2007 12:57 PM
You may not post new threads
