Top radiator hose pressure, how much is normal? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 1 Old 12-18-2018, 02:05 PM Thread Starter
Dodge318
On my 2003 Ram I recently bought I've a couple of instances when I've noticed coolant under the truck after parking overnight. Truck has passed a pressure test, and a block test with the chemical sniffer thing. I believe I've traced the source of the leak to hose that goes from the recovery bottle to ground. Anyway, I've always wondered why my top hose never had any pressure, but on a hunch I replaced the cap. No more leak, and the top hose is firm, not hard, but I can't squeeze it together and have the insides of the hose touch. So my question is, is this normal? I've never had a power tech engine before. I had 2 magnums, a cummins and a Hemi, but i've always managed to avoid the 4.7L. Truck runs normal, doesn't overheat. I guess I'm just paranoid after reading the horror stories of 4.7L blowing head gaskets.
Any help would be great.
2002 Dodge Ram QC 1500 4.7 auto
175,000
Dodge318 is offline
Low Oil Pressure Issues - Pull Pan/Replace Pump? sethmac 3G Dodge RAM - General Talk 7 08-20-2018 07:18 PM
1989 Dodge B250 5.2L V8 - Fuel Pressure Problem When Starting increa Dodge B-Series Vans 1971 - 2003 24 09-24-2017 09:24 PM
1989 D250 Ram Pickup - kickdown, throttle valve pressure linkage adjustment jwillis84 Dodge Ram Truck 1st Gen (88 - 93) Forum 5 08-23-2017 09:56 PM
No Oil Pressure? Argroft 3G Dodge RAM - General Talk 1 10-28-2016 08:41 AM
