2007 5.7 HEMI Ram 1500 4wd - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 4 Old 09-23-2018, 07:23 PM Thread Starter
ruggeri5054
Quoted: 1 Post(s)
Hello, I am coming to this site because I have had zero luck on another site. My 2007 Ram 1500 5.7 has had a weird issue..
160k... 545rfe trans
So I will give a chronological timeline of how a drive will go..
Park to drive 2.5 sec delay till engage..
drives fine, upshifts very smooth and quick
once 45 mph hits, OD seems to engage and all is good. The problem is when I accelerate from that point, or even if I slow down ANY decent acceleration will result in a harsh downshift (more throttle more flare)
IF I turn overdrive off it downshifts totally fine.
SO I hooked my scanner up to it and noticed that there was erratic behavior with the UD pressure switch and LR pressure switch. LR would turn on and off a few times when Park to Drive was selected. Once engaged, switch was normal.
Same thing when the flare would happen upon downshift from OD. When OD was disabled, all was normal.
I changed the solenoid pack and both filters with OEM dealer parts, upshifts seemed to improve but nothing else changed.
Scanner also shows ECT sensor WAYYYY high .. so the coolant temp was 240 degrees on a 60 degree day before starting overnight. When driving, the first sensor reading is over 600 degrees Coolant Temp! The second display (gauge) is reading 201 degrees usually. The gauge shows normal reading and the second sensor reading was normal as well. I changed the ECT twice and it still is showing the same issue. Seems to be a short in the two wires, I understand that colder equals more resistance and hotter will decrease resistance. It seems that the wiring is shorted and the PCM thinks there is no resistance period. Would this affect the shifting, schematic shows that ECT is in sync with OD operation.
Also, the trans will shift hard from 3rd to 1st when slowing down around 10 mph or so.. that is when underdrive switches also underdrive is erratic when the downshift from overdrive occurred.. on off on off.. when it finally engages, behavior stops.
When I dropped the pan, magnet had almost no clutch material on it, no shavings and no metal chunks. Fluid was still red and smelled like regualr trans fluid.
I am thinking there is an electrical issue that is causing OD and UD to interfere or stick.
Please help, I have tried trans shops and of course they said Rebuild without even looking at it and that is all good and I know it will fix it (maybe) but lets be honest, I am a firm believer of DIY and the most satisfying thing is when you fix the issue without doing a blanket rebuild to fix a small issue.
so ultimately, all upshift is fine, downshift is hard and delays from OD only, OD off equals no problem.
SIDE NOTES, the low oil pressure code is showing as well, been that way with two new sensors installed. Idle PSI is 30 or so and acceleration usually is over 50. no knocks or noise. Been that way for a while. Seems to be weird electrical issues throughout the vehicle, I have inspected the harness and did not see any smashed or grounded wires yet. Maybe a bad ground?? I tried jumping ground and it did not do anything.
Could the PCM be faulty or needing flashed? Anyone ever see this issue?
Please Help!!!! and Thank you in advance!
I know that I can check ground and continuity for the ECT I just have not had time yet.. Ill get there!
ruggeri5054 is offline
post #2 of 4 Old 09-24-2018, 03:41 PM
67Cuda
Tape On
67Cuda's Avatar
Quoted: 19 Post(s)
How old is the battery? Sometimes batteries that appear fine maybe having issues and causing problems.
I just had one die. Started up fine like usual, got to work. Tried starting it to go home, had a bad cell. Couldn't even jump it, got new battery.
Battery went from good to bad just sitting there.
2004 Hemi RAM Quad Cab 4X4 (Big Horn Edition)
SuperChips 3865
Borla Single Out Exhaust w/new y-pipe
Firestone Rear Bags
Hellwig Swaybar
Bilstein Shocks
Step Bar
Push Bar w/LED's
All Terrain T/A KO2 285/70R17
67Cuda is offline
post #3 of 4 Old 09-24-2018, 06:25 PM Thread Starter
ruggeri5054
Quoted: 1 Post(s)
Battery is stamped 2017, just under a year old. On that note, i was receiving a voltage too high dtc but it went awayand didnt come back yet.
post #4 of 4 Old 10-01-2018, 10:02 PM
guyonearth
Quoted: 18 Post(s)
The long delay when shifting into drive would concern me. You could have a worn valve body with leaking valves. The harsh shifting could be the result of excess oil pressure triggered by leaking bores causing the transmission to "think" pressure is too low, because it is too low where it's being measured, and as a result it's ramping pressure up too high, or just all the way up, what's called open loop mode. You'd have to replace the valve body to resolve this. I'd suggest resetting the transmission adaptives to see what happens, the clutch volume indexes could be learned wrong now. Other guys have reported that resetting the adaptives and doing a relearn has smoothed things out, at least temporarily, but ultimately you would be looking at a mechanical fix here. You may have multiple issue going on here with that temperature sensor. As far as your oil, you're OK with 30 at idle. If your gauge is sitting around the middle at highway speeds you're fine.
guyonearth is offline
A True Long Term Review - 2012 Ram 1500 SaddleUp 4G Dodge RAM - General Talk 1 04-22-2018 09:17 PM
2004 Dodge Ram 1500 5.7 Hemi ShakinBlake DodgeTalk New Member Welcome 2 05-26-2017 02:03 PM
05 ram 1500 5.7 hemi dies when coming to a stop dwittig33 3G Dodge RAM - Drivetrain Talk 4 03-11-2017 08:20 AM
desperate in need for a tire suggestion 2004 ram 1500 hemi qc on factory 275/60/20 aliaj00 3G Dodge RAM - Tire and Wheel Talk 2 02-16-2017 09:12 AM
Immaculate 2006 Dodge Ram 1500, 4x4, HEMI, Colorado jermag24 For Sale - Dodge Trucks 6 12-24-2016 03:32 PM
