weird random issues - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 14 Old 06-03-2017, 11:20 PM Thread Starter
Mopar2You
Quoted: 1 Post(s)
Send a message via AIM to Mopar2You
weird random issues
Having a few odd issues with the truck.
Water pump was bad, so i changed it and the thermostat. Was having issues with the upper rad hose collapsing, ended up bleeding the air a lot and then finally having to change out the rad cap which seems to have fixed the issue.
The temp is fluctuating a lot though when moving slow or stopped and idling. It will sit at the halfway mark, but can go up almost to the 3/4 mark to the H, then swiftly drop back down. Im not sure why. is this normal?
Truck died driving down the road, was essentially coasting down a hill, then didnt want to stop (had to crank for 2-3 seconds to start it). Im thinking possible IAC sensor? Already reset PCM and did the throttle reset (APPS).
Wouldn't start this morning at all, just turned over about 1 time then stopped. Finally got it to crank, and then it just cranked without starting. Released key after about 4-5 seconds of cranking, tried again and it popped right off this but ran slightly rough for about 10 seconds and I could smell fuel in the exhaust.
Any advice would be greatly appreciated. It runs down the road fine, runs great, sounds fine etc.
2004 Hemi Ram 1500 4wd qc sb.
Mopar2You is offline
post #2 of 14 Old 06-03-2017, 11:35 PM
03hemiNorthIL
Quoted: 3 Post(s)
Is there any codes to help diagnose this? It may be the pcm needs to be reflashed by a stealership. My 03 has been flashed three or four times, I think it time to go back again. It just really bad coding from Chrysler.
Sent from my VS987 using Tapatalk
03hemiNorthIL is offline
post #3 of 14 Old 06-03-2017, 11:36 PM Thread Starter
Mopar2You
Quoted: 1 Post(s)
has the p0300 code both confirmed and pending. multiple cylinder random misfire.
how much does that cost?
post #4 of 14 Old 06-03-2017, 11:42 PM
03hemiNorthIL
Quoted: 3 Post(s)
Check this out, it a 04 2500 hemi sounds like your problems. It probably valve springs.
I got this from ram forum, I can't link for some reason
*************/f54/multiple_random_misfire-68039/
post #5 of 14 Old 06-03-2017, 11:47 PM Thread Starter
Mopar2You
Quoted: 1 Post(s)
link didnt work.
post #6 of 14 Old 06-03-2017, 11:48 PM
03hemiNorthIL
Quoted: 3 Post(s)
You have to go to the ram forum website, then add the part of the link that isn't blocked.
post #7 of 14 Old 06-03-2017, 11:51 PM Thread Starter
Mopar2You
Quoted: 1 Post(s)
thanks, they also mentioned fuel injectors. hm.
post #8 of 14 Old 06-04-2017, 12:00 AM
03hemiNorthIL
Quoted: 3 Post(s)
No problem, hope this fixes your hemi. I have never had a mechanical issue with mine, surprising. It just the computers that glitch out like my tranny controller used to shift into neutral while going 70mph on I 70 to Indy, and won't shift back into gear.
post #9 of 14 Old 06-04-2017, 02:18 PM Thread Starter
Mopar2You
Quoted: 1 Post(s)
and today I checked the codes (cleared the p0300 the other day)... and now it has p0335 and p0340 (crankshaft pos a and camshaft pos a). but starts/runs fine. any ideas?
post #10 of 14 Old 06-04-2017, 02:47 PM
03hemiNorthIL
Quoted: 3 Post(s)
Bad sensors are known in these dodges so that could be that. It also maybe a bad crankshaft which I think could cause the multiple misfire code. I would check your sensors first though. While doing that look at pictures of a new crankshaft compare with yours same with cam.
post #11 of 14 Old 06-05-2017, 10:11 AM
dizzyD
Registered MOPAR User
dizzyD's Avatar
Quoted: 26 Post(s)
if your temp gauge is acting funny, double check the sending unit on engine. either the connector loose or the plastic housing fractured.
2012 Challenger SXT+ 220ci 5 speed, blackberry pearl, FM xxMM, diablo in-tune I1000, Carbon fiber pedal covers, 11% tint
1999 Durango SLT+ leather, 360ci 4x4, hughes plenum rebuild, superchips 3865, tow pkg, 3.55 LSD, rear tail light guard, K&N CAI, FM 50MM TB, crystal clear headlights, Torsion/shackle lift, Rancho RSX's, Pacesetter headers, dual trans & oil temp a-pillar pod, chrome deep trans pan, drilled & slotted rotors, 10 disc cd changer.
2004 Ram 1500 SLT 2WD QC LB 345ci, FM 84MM TB, slotted brake rotors, step bar, diamond plate pedals, locking gas door, tow package w/ 3.55 lsd, Hellwig LP-15, shell and carpet kit, 18% door window tint, Magnaflow 12641, Slammed1's 3" spindle lift and 2.5 coil spacer, rear lift shackles, Airraid MIT, superchips 3815, 6K front winch & custom Winch Plate, Autometer phantom trans gauge mounted in Mopar SRT A-Pillar single pod, lumber/roof rack, Rancho 9000X shocks, ATS fender flairs, 1" BL, gap guards, black grille, silver painted bezel
2005 Dodge Magnum RT- Midnight Blue -Vroom Lakewood front strut bar, K&N Filter
Gone but not forgotten 93 factory freak CC dakota lifted 4x4 318
dizzyD is offline
post #12 of 14 Old 06-05-2017, 01:23 PM Thread Starter
Mopar2You
Quoted: 1 Post(s)
Will check that. Also did a pressure test (held 16# for over 10 minutes) several times. No water in the oil either (had thought head gasket).
Going to see if there is flow issues with the radiator. Upper hose is hot after a drive, lower hose is just lightly warm.
post #13 of 14 Old 06-05-2017, 11:45 PM Thread Starter
Mopar2You
Quoted: 1 Post(s)
so after some more looking into it... its been eating water(thought it was a leak initially). think i saw water vapor/steam(it was faint) coming out the tailpipe today. also know it was pushing water out the overflow tank, it was down a half radiator in amount on my drive to work with some idling as well in my driveway while I checked temps with a infrared thermometer(temps seemed okay overall). so i'd say its a headgasket or a cracked head.
how do you tell if the heads have the bad valvesprings or not? about how much are they, and what part number do I need to order since I will have the heads off to do a headgasket anyways. also, should I have the heads checked at a shop, and any idea what that should cost approximately?
post #14 of 14 Old 06-11-2017, 10:49 PM Thread Starter
Mopar2You
Quoted: 1 Post(s)
changed my plugs today. first of all, what a pain lol (the drives side back set). had 2 boots rip off inside the tube. Quite a few were barely more than hand tight, one plug WAS hand tight. Most looked fine. 6 on the drivers side did not. They had a orange/rust tint on the porcelain area by the electrode. Posting pictures... please let me know what you think it is.
Also... the crankcase vent tube has a NASTY amount of oil/gunk buildup (the air filter had a lot of gunk in it from what Im assuming is the crankcase vent as well, which went into the intake/tb etc). . Also changed the pcv, which was nasty and old. The TB was very dirty, VERY VERY dirty on the inside (i had cleaned the outside before quickly). Any idea what that is or is from? Should I change the crankcase breather to a filter instead so Im not sucking up all that gunk/crap or whatever it is?
I did NOT clean inside the manifold, didnt want to go that indepth or get stuff inside the engine.
7 pin trailer issues rthunt 4G Dodge RAM - General Talk 1 04-18-2017 11:51 PM
Electricals Issues With the Caravan RyuKim 4th Gen Caravan Talk (01-07) 2 03-31-2017 10:33 PM
Simultaneous issues with wipers, brights, and turn signal Moose3145 3G Dodge RAM - General Talk 5 01-15-2017 10:51 AM
98 Ram 1500 4x4 Need Help with 2 Issues KenS999 2G Dodge RAM - General Talk 5 11-19-2016 08:58 PM
