Turn signal wont quit - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 4 Old 11-22-2016, 11:18 AM Thread Starter
donthelegend
03 ram. Right turn signal came on by itself And wont quit. Cleaned then replaced mfs.( multi-function switch) No change now it's on even with the switch unplugged. Replaced pdc ( fuse box) and fcm ( front control module)with junkyard ones no change. Pulled headlights and tail lights checked ground and power wires no change. Anybody had this problem? Right turn blinks even with mfs unplugged. Sometimes with mfs unplugged it doesn't blink until I drive a while then starts blinking again.
donthelegend is offline
post #2 of 4 Old 11-22-2016, 11:47 AM Thread Starter
donthelegend
I forgot to add that all bulbs function correctly and when the mfs is plugged in and I turn on the right signal the left comes on. Left works correctly but when it cancels it goes back to right blinker constantly on
post #3 of 4 Old 11-23-2016, 02:26 PM Thread Starter
donthelegend
Checked every wire and connection in turn signal circuit. All look pristine. Pulled instrument cluster and dis-assembled , looks perfect. Guess I'll pull the pcm and dis-assemble to look for corrosion .
post #4 of 4 Old 11-29-2016, 04:06 PM Thread Starter
donthelegend
Pcm or pdc (fuse box)clean as a whistle inside. No corrosion or broken circuits. Not sure what to do other than buy a new fcm
Turn Signal - 'left only' not working javapop 3rd Gen Caravan Talk (96-00) 2 03-08-2017 05:39 PM
Electrical low beam headlights, horn, front turn signals and radiator cooling fan Rstudy 5th Gen Caravan Talk (08-Up) 0 11-21-2016 03:44 AM
