Engine Woes - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 8 Old 04-08-2019, 09:44 PM Thread Starter
pjnagel
pjnagel's Avatar
Quoted: 3 Post(s)
Engine Woes
Well, I'm absolutely sick right now.
I re-ringed, resealed, and installed a mild cam into my 360. Added fuel injection, and a few look-pretty parts.
Tonight I fired it up for the first time, and it sounds like there are a dozen ball bearings banging around in there.
I guess this weekend I get to rip it out again, but I have no idea what I'm even looking for...
pjnagel is offline
Quote Quick Reply
post #2 of 8 Old 04-10-2019, 06:29 PM
Moparite
Moparite's Avatar
Quoted: 389 Post(s)
Pistons hitting the valves would be the first thing. Are you sure you got the timing chain marks on the sprockets correct?
Moparite is offline
post #3 of 8 Old 04-10-2019, 10:23 PM Thread Starter
pjnagel
pjnagel's Avatar
Quoted: 3 Post(s)
I turned the engine over by hand enough times that I think I would have noticed if the valves and pistons were hitting I would have noticed it earlier.. and aren't these non-interference engines?
I haven't had gauges wired yet, so this weekend I will verify I have oil pressure.
pjnagel is offline
post #4 of 8 Old 04-10-2019, 11:20 PM
reek
Quoted: 11 Post(s)
keep us posted on what you find. in the meanwhile, that there is a pretty looking motor.
reek is offline
post #5 of 8 Old 04-10-2019, 11:34 PM Thread Starter
pjnagel
pjnagel's Avatar
Quoted: 3 Post(s)
Pretty looking boat anchor right now...
pjnagel is offline
post #6 of 8 Old 04-13-2019, 01:30 AM Thread Starter
pjnagel
pjnagel's Avatar
Quoted: 3 Post(s)
So I'm going to sleep well tonight!!
A friend stopped by the shop today and I made small talk with him about my engine problems. He helped me confirm I had oil pressure, then said he thought the noise was coming from below the engine, rather than up high.. I guess I just don't have an ear for those kinds of things.. Anyway, my whole dilemma was nothing more than a bent inspection cover hitting the torque converter bolts.
I feel pretty foolish for letting my mind jump to the worst case scenario right away, but I'm glad it's all taken care of with about 15 minutes of work.
pjnagel is offline
post #7 of 8 Old 04-13-2019, 10:29 PM
reek
Quoted: 11 Post(s)
so you won't be holding your boat in place with it?
ha! glad to hear all worked out well. I think the "doh!" moments are just part of tinkering with cars/trucks.
reek is offline
post #8 of 8 Old 04-17-2019, 09:18 AM
mongoman
mongoman's Avatar
Its OK, Many times I've done exactly the same thing. As much as we may not like it, were only human. Your post helps us all . I love your picture. I own a "73 W-100 with a 360. Mike (retired Mechanic)
1973 W-100 O/H 360' engine, w/a Edelbrock :1406 carb,2176 intake manifold, 2177 performer cam/ lift kit, Lokar cables, Dana 44 front axle ,A-727 auto-trans.Np-205 trans-case, Chrysler 8 3/4"SF rear axle ,All drum Brakes. Classic Auto Air-conditioner package.
mongoman is offline
2005 Caravan SXT leaking coolant behind engine Kameen Avery 4th Gen Caravan Talk (01-07) 6 09-22-2017 02:09 PM
2003 Quad Cab 1500 4.7 Engine Suggestions Revvv 3G Dodge RAM - General Talk 2 08-30-2017 11:55 PM
Code list slingin_mudd 3G Dodge RAM - General Talk 0 08-27-2017 08:39 PM
Magnum engine. The bastard of the market. CbtEngr01 2G Dodge RAM - General Talk 10 06-14-2017 08:32 PM
Big Block Freeze Plug Woes MTP0ckets 1972-1987 Dodge Ram Trucks (D, W-series) 4 12-04-2016 01:27 PM
