LED Headlight Bulbs for 1992-2010 Dodge Viper! Made in USA! | Diode Dynamics - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 11 Old 05-23-2019, 11:45 AM Thread Starter
Diode Dynamics
Sponsor
Diode Dynamics's Avatar
Quoted: 1 Post(s)
SL1 LED Hi/Lo Beam LED Headlight Bulbs for 1992-2010 Dodge Viper
Diode Dynamics is pleased to offer the USA-made SL1 LED High Beam Headlight bulbs for 1992-2010 Dodge Viper
If you're looking to improve your 1992-2010 Dodge Viper’s visibility at night, you've probably seen plenty of aftermarket LED headlight bulb options. There are plenty of “high performance” LED lights on the market, but they all have their shortcomings. They're too big to install, have no hotspot in the beam pattern, or they simply stop working after just a few months!
With its compact size, optically correct output, thermally-modeled cooling, and boost-mode electrical circuit, Diode Dynamics SL1 LED Headlight Bulbs are truly the best LED headlight bulbs on the market.
Diode Dynamics SL1 Low Beam LED Headlight Bulbs for 1992-2000 Dodge Viper
Diode Dynamics SL1 Low Beam LED Headlight Bulbs for 2001-2004 Dodge Viper
Diode Dynamics SL1 High Beam LED Headlight Bulbs for 1992-2010 Dodge Viper
Street Legal Output. Don't be fooled by high lumen numbers or "projector specific" bulbs. Your 1992-2010 Dodge Viper’s headlights are designed to focus light. If the light source is out of focus, it doesn't matter how bright it is - you won't have a focused hotspot of light to shine down the road - just more glare. Some generic options have such a poor optical design, they might leave you wondering “how are LED headlights legal?!”
To correct this, the Diode Dynamics' SL1 LED Headlight Bulb was engineered with advanced optical design software, to perfectly match the halogen filament location. This allows the SL1 to focus light just like the original halogen headlights, preserving the focus and hotspot, with no added glare. It produces a functional beam pattern with zero glare, which we call Street Legal.
Tested to Perform. We test the SL1 in factory car headlights and measure the entire beam pattern using specialized equipment. The entire beam pattern is mapped, and we compare the total output to the original equipment, confirming that the SL1 headlight bulb shines more light in the hotspot, without adding extra glare on the road. The test results speak for themselves: in most lamps, there is 30-70% more light output in the critical hotspot, with zero glare. Thanks to optical engineering, testing, and validation in the application, the SL1 is the #1 LED headlight bulb for reflector and projector headlights.
Staying Cool. You might’ve seen LED headlight kits that use large straps for cooling, or fans that just make noise. These light bulbs run hot, resulting in degradation of output after a few months. When it comes to cooling, proper engineering is required to efficiently remove heat from the bulb. In the SL1, a copper core board, thermal phase-change material, and thermally-modeled zinc casting get heat to the base, where base fins release it, designed for aerodynamic performance in conjunction with the flow rate and pressure of the Sunon bearingless micro fan. The result is a highly effective and reliable cooling system, keeping the SL1’s LED chips running at maximum potential.
Fitment. With its patented design, installing the SL1 LED headlight bulb is simple and straightforward, requiring NO cutting or modification. There's no hanging metal straps, just a compact bulb that plugs right into your 1992-2010 Dodge Viper, with a nylon-reinforced shroud. Only slightly larger than a standard halogen bulb, it fits behind dust caps and in tight spaces. The base sizes are keyed specifically to fit your vehicle, not one-size-fits-all! And the compact driver easily tucks away.
Reliability. Every part of the Diode Dynamics' SL1 LED Headlight Bulb is engineered with more expensive OEM-grade features to assure quality, such as the Sunon MagLev fan and PCB wire connectors" In short, these are designed, tested, and built to a much higher standard than your average imported led headlight conversion kit. The Diode Dynamics' SL1 LED Headlight Bulb will keep performing in your 1992-2010 Dodge Viper for years, and is backed by a three-year warranty.
Specifications
Measured Lumens: 1630 (per bulb)
Color Temp: 5700K (cool white)
Power (watts): 20.2
Operating Voltage: 5-16V
Current (amps @ 13.2V): 1.58 Polarity:
Polarity Specific LED Emitter: Luxeon Z ES
Connector(s): OEM-Size Plug and Play
Driver Features: External, Waterproof, Constant Current
Materials: Copper PCB, PP-TD30 Base, Zinc Heatsink
Cooling: Active, Mag-Lev Microfan
Compliance Ratings: FMVSS108 Beam Pattern, SAE J575 Durability Test
If you have any questions, please don't hesitate to post, PM, email [email protected]
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Jake H.
Diode Dynamics
Click here to learn more:
Diode Dynamics is offline
Quote Quick Reply
post #2 of 11 Old 05-24-2019, 04:07 PM Thread Starter
Diode Dynamics
Sponsor
Quoted: 1 Post(s)
LED Focus: What you need to know!
Good optical focus means more light further down the road where you need without any glare. We put together this video to highlight what to look for when choosing an LED headlight bulb for your vehicle. Check it out! And don't forget to shoot us a PM for free USPS shipping on any U.S order!
Jake H.
Diode Dynamics
post #3 of 11 Old 05-29-2019, 11:39 AM Thread Starter
Diode Dynamics
Sponsor
Quoted: 1 Post(s)
Think having LED headlight bulbs shine light 360-degrees is a good idea? Think again! Check out this video to see why!
post #4 of 11 Old 06-03-2019, 05:33 PM Thread Starter
Diode Dynamics
Sponsor
Quoted: 1 Post(s)
Don't forget to shoot us a PM for FREE USPS shipping on ANY U.S order!
Jake H.
Diode Dynamics
post #5 of 11 Old 06-04-2019, 12:28 PM Thread Starter
Diode Dynamics
Sponsor
Quoted: 1 Post(s)
How hot an LED headlight bulb gets has a BIG impact on how bright it will be over time and how long it will last. Check out this video to see if your headlights are getting too hot!
post #6 of 11 Old 06-21-2019, 03:22 PM Thread Starter
Diode Dynamics
Sponsor
Quoted: 1 Post(s)
In our latest video, we answer one of the most popular questions about headlight upgrades: Which is better, HID or LED? Check it out!
Jake H.
Diode Dynamics
post #7 of 11 Old 07-01-2019, 04:22 PM Thread Starter
Diode Dynamics
Sponsor
Quoted: 1 Post(s)
Don't forget to shoot us a PM for free USPS shipping on any U.S order!
Click Here To Shop Now
Jake H.
Diode Dynamics
post #8 of 11 Old 07-05-2019, 05:50 PM Thread Starter
Diode Dynamics
Sponsor
Quoted: 1 Post(s)
July 4th sale! 20% off all diode dynamics products!
Jake H.
Diode Dynamics
post #9 of 11 Old 07-09-2019, 02:03 PM Thread Starter
Diode Dynamics
Sponsor
Quoted: 1 Post(s)
Measuring Headlight Output | Diode Dynamics
How are headlight output patterns measured at the factory level? How do you test to see if a headlight is meeting SAE and DOT beam pattern requirements? Here at Diode Dynamics, we've invested in a goniometer to accurately measure and map the entire beam pattern and ensure our products are adding light output without adding extra glare.
Check out the video to see how it works!
Click Here to learn more about our SL1 LED Headlight Bulbs
Jake H.
Diode Dynamics
post #10 of 11 Old 08-30-2019, 11:40 AM Thread Starter
Diode Dynamics
Sponsor
Quoted: 1 Post(s)
Jake H.
Diode Dynamics
post #11 of 11 Old 10-16-2019, 11:38 AM Thread Starter
Diode Dynamics
Sponsor
Quoted: 1 Post(s)
https://www.youtube.com/watch?v=3cGyEA8gtKA
We're proud to be one of the only manufacturers of LED headlight bulbs in the U.S.A! By engineering, testing, and manufacturing our SL1 LED Headlight Bulbs at our headquarters in St. Louis, we're able to ensure maximum quality and performance. Check out how they are made in the video above!
And be sure to shoot us a PM for FREE USPS shipping on any U.S order!
Jake H.
Diode Dynamics
Diode Dynamics: SL1 LED Headlights for Dodge Ram! USA Made! See Install Video! Diode Dynamics Diode Dynamics 20 10-16-2019 11:32 AM
Diode Dynamics: SL1 LED Headlights for Dodge Charger! USA Made! See Install Video! Diode Dynamics Diode Dynamics 15 10-16-2019 11:30 AM
Dodge Challenger Fog Light LED Bulbs! USA Made SLF! Match OEM-HIDs & Halo DRLs! Diode Dynamics Diode Dynamics 24 07-05-2019 05:27 PM
Diode Dynamics Universal RGBW™ Multicolor LED Demon Eyes! USA Made! Diode Dynamics Diode Dynamics 31 07-05-2019 05:25 PM
Diode Dynamics: Dodge Charger Reverse/Backup LED Bulbs! Plug & Play Install! Diode Dynamics Diode Dynamics 2 07-05-2019 05:23 PM
You may not post new threads
