Wanted to know if anyone else has/had developed an exhaust leak near the header. I had exhaust work done 6 months ago, but in the last 2 months, an exhaust leak has developed and its getting pretty annoying. Hopefully the gaskets havent went. Anyways, was curious if this was normal.
Well have two broke manifold bolts on the passenger side. BTW, those bolts are only available through dodge. The specs are M8-1.25 x M6-1.00 x 83mm Thats if you want to go with the stud nut concept if not, Autozone carries some M8-1.25 x 60mm bolts that will work also.
I've got the same problem. Just found out today. We've basically got the same truck mechanically speaking.
2005 Ram 1500 5.7 4x4
Related Threads
DodgeTalk Forum
4.7M posts
290.1K members
Since 2002
