ABS & Prk Brake light stays on,speedo went out same time? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 6 Old 06-21-2008, 08:53 PM Thread Starter
rutankslappin
Had my truck sitting a couple weeks,started it up and drove it a little. Noticed the parking brake light and ABS light stayed on for no reason. Looked at my speed and it was out at the same time. Anyone ever had that problem? What can I do to fix it with out going to the dealer? Maybe sensor's that control all three out? If someone has knowledge please let me know.
RG
rutankslappin is offline
post #2 of 6 Old 06-21-2008, 09:07 PM
tctwg
tctwg's Avatar
Send a message via Yahoo to tctwg
There is a sensor, I believe on the top of you rear axle that is part of the speedo, and makes your parking brake/abs light come on if its bad. Its pretty easy to replace. Heres the part number from Dodge in case you decide to buy it. Its call a wheel speed sensor P/N 56028187AE
Military Truck Club Member #6
Dodgetalk.com 345 Enthusiast Member #41
Black Truck Club Member #131
"Off-Road" Package Club #35
HID Club Member #30
Twiggy HID Club Member #1
D2S Infiniti Bi-Xenon Projectors 6000k
D2S Projector Fog Lights 6000k
H3 KC Lights 6000k
SINGLE BEAM, DUAL BEAM, BI-XENON, BI-XENON4
tctwg is offline
post #3 of 6 Old 06-21-2008, 10:52 PM
tazman66
Right on.....Had an exhaust pipe hit mine and killed it....same issues....replaced sensor and all was well
tazman66 is offline
post #4 of 6 Old 06-21-2008, 10:58 PM Thread Starter
rutankslappin
Thanks guys for the help, I will chck it and see about ordering a replacement.
post #5 of 6 Old 06-22-2008, 01:10 AM
dmcelhannon
Admin - David Mack
dmcelhannon's Avatar
Quoted: 270 Post(s)
Mine has done the same thing; it because the battery was a little too low when you started the engine. After you drive it around a-bit, it will recharge the battery and the lights will go out after you have made three or four starts-n-stops. The longest it has ever taken for me was about three hours of running errands.
dmcelhannon is offline
post #6 of 6 Old 06-22-2008, 10:06 AM Thread Starter
rutankslappin
Recharge batt
Thanks, I will try that first. If no success thhen I will replace the part mod.
Brake and ABS light stuck on millerlte 3G Dodge RAM - General Talk 7 12-28-2007 04:11 PM
abs and brake light comes on stoney 2G Dodge Ram Diesel Talk 2 11-26-2007 08:01 PM
ABS and Brake Light jmrussell2003 1G Dodge Durango General Talk 38 01-07-2005 06:16 AM
abs and brake light stays on shaggs 1G Dodge Durango - Tire/Wheel/Susp Talk 8 11-13-2004 03:28 PM
ABS / BRAKE light on periodically speed_skating 2G Dodge RAM - General Talk 2 09-07-2003 01:17 AM
