high idle after hitting water puddle on roadway - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 5 Old 04-27-2019, 04:27 PM Thread Starter
kevaug
Arrow high idle after hitting water puddle on roadway
Hi All - 2004 Ram 1500 SLT 4x4 MANUAL Tran with 4.7L
last night we had some major rain and flash flooding.
It was dark and I couldnt see very well and hit a puddle that came up to my step rails. Needless to say it threw and stuffed my truck pretty bad.
Shortly thereafter my RPMs were idling around 1500 and if I pressed the clutch in it went up to 3000 rpms.
Any idea on what could have got wet or disconnected going through this huge puddle?
Thanks
kevaug is offline
Quote Quick Reply
post #2 of 5 Old 04-28-2019, 07:51 AM Thread Starter
kevaug
Yesterday I disconnected the battery hoping to "reset" the computer as no DTC codes were displayed other than a P0563 (Battery/Syetem Voltage High) which I had to hunt for as the CEL was NOT on. I reconnected battery and took it for a test drive and the CEL came on with a P0068 (MAP/MAF -throttle position correlation).
So could the blast of water somehow ruin my TPS? or maybe a vacuum hose was detached?
Any thoughts?
kevaug is offline
post #3 of 5 Old 06-04-2019, 09:37 PM Thread Starter
kevaug
So far Ive swapped out the MAP, TPS, IAC, and installed new spark plugs.
removed and cleaned TB and installed a new gasket.
Compression test indicates all cylinders are fine.
Still have high idle. Could not find a vacuum leak.
Could the PCM be bad, and if so how could I test that?
kevaug is offline
post #4 of 5 Old 06-05-2019, 08:28 PM Thread Starter
kevaug
I checked vacuum today and at idle i was getting about 19.5 inHg.
I think this means my vacuum is excellent and I guess that would indicate no vacuum leaks?
kevaug is offline
post #5 of 5 Old 06-05-2019, 08:34 PM Thread Starter
kevaug
Also I found a melted piece of plastic from an evap line. It appears a line coming off the evap canisters is a vent to atmosphere. I think the force of the water must have broken the bundle ties of this line and allowed it to drop down and come in contact with the exhaust and melt. Its a little "mushroom" looking vent cap but I dont think this is effecting the idle.
I did order a new vent cap and I will have to tie it back up to something to avoid this one melting.
Does anyone know the importance or operation of this vent?
kevaug is offline
Stalling and high idle 92dak89 Dodge Dakota 1st Gen (87 -96) Forum 1 08-25-2018 03:47 PM
high idle dybeepvw 3G Dodge RAM - General Talk 0 10-08-2017 06:18 PM
Code list slingin_mudd 3G Dodge RAM - General Talk 0 08-27-2017 08:39 PM
High Idle in Nuetral AlReset 4th Gen Caravan Talk (01-07) 3 05-31-2017 10:04 PM
Very high idle in park, won't pass emissions guerajj77 Dodge Ram Truck 1st Gen (88 - 93) Forum 1 01-30-2017 12:42 PM
