How to find the ratio for my rearend - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 6 Old 07-08-2019, 05:13 AM Thread Starter
TheNerd
2003 dodge ram 1500 4x4 I dont see a plate or anything on it it has a clicking noise and a vibration I changed the fluid but was told it probably needs to be replaced. After changing the fluid the vibration is better but still there so I would like to prices another one.
TheNerd is offline
Quote Quick Reply
post #2 of 6 Old 07-08-2019, 09:16 AM
67Cuda
Tape On
67Cuda's Avatar
Quoted: 19 Post(s)
There might be a sticker in the glove box that has the differential ratio.
2004 Hemi RAM Quad Cab 4X4 (Big Horn Edition)
SuperChips 3865
Borla Single Out Exhaust w/new y-pipe
Firestone Rear Bags
Hellwig Swaybar
Bilstein Shocks
Step Bar
Push Bar w/LED's
All Terrain T/A KO2 285/70R17
67Cuda is offline
post #3 of 6 Old 07-09-2019, 05:31 PM
mikec041
Quoted: 1 Post(s)
Try this link. SHOULD give the build sheet that shows the rear as originally equipt.
https://fcacommunity.force.com/RAM/s/equipment-listing
mikec041 is offline
post #4 of 6 Old 07-09-2019, 09:05 PM
aircommuter
Quoted: 2 Post(s)
Could be stamped on the differential cover or next to it if so equipped. Not always shown as a ratio but number of teeth on each gear like 41 10. You could jack it up and count turns but sometimes difficult, if one wheel off the ground will allow you to turn the driveshaft then it is not limited slip and you count the number of turns of the driveshaft that it takes to make one wheel revolution then divide by two.
aircommuter is offline
post #5 of 6 Old 07-09-2019, 10:40 PM
HemiLonestar
Red Trucker
HemiLonestar's Avatar
Quoted: 60 Post(s)
You may have a metal tag under one of the diff cover bolts, but most times they end up missing. As long as it has the original rear that link is your best bet.
03 Hemi Ram, 05 Magnum R/T, 06 Charger R/T
HemiLonestar is offline
post #6 of 6 Old 07-10-2019, 11:05 AM
Mikey13
1973 Dodge B100
Mikey13's Avatar
From the internet... (google "How to find the ratio for my rear end")
Turn the wheel TWO revolutions and count the number of driveshaft turns. The number of driveshaft rotations will help you determine your rear axle ratio. For example, if it turned 3 and a half times, it's a 3.50:1 ratio. If it turned 4 and a quarter times, it's a 4.25:1 ratio.
Mikey13 is offline
