is 46RE same as A-518 - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 9 Old 11-30-2004, 05:15 PM Thread Starter
indyram02
Hey guys, ya this might be a stupid question, but is the 46RE tranny the same as the A-518...seems like one of them is the dodge name and one is the chrysler name...but i can't remember, i have the 46RE and i'm looking to get a transgo shift kit but 46RE wasn't a choice and 518 was so i figured i'd make sure...thanks
indyram02 is offline
post #2 of 9 Old 11-30-2004, 09:48 PM
Dodgevanman
Do It In A Van
Dodgevanman's Avatar
Yes they are the same.
Nate Breece
5.2L Magnum
2008 Grand Caravan SXT
3.8L
Member of:
Dodgevanman is offline
post #3 of 9 Old 11-30-2004, 09:54 PM
gouge93
gouge93's Avatar
Isn't there somekind of difference though? I know they're basically the same. My old '93 318 had the A-518 I believe and my '97 318 had the newer 46re, both 318 magnums.
2002 Dodge Ram 1500 rc 2wd 360 Black Sport
Stock Options
-EVERYTHING available except side air bags
Mods
-1"/4" drop courtesy of Slammed1-Belltech Nitro Drop shocks-20" KMC Zodiaks w/Toyo Parada Spec-X 305/50/20 on rear and 275/55/20 on front-Magnaflow 3" High Flow Cat-Borla xr-1 exhaust - dumped-Superchips Performance Tune-Fastman 52mm tb-ASP underdrive crank pulley-14" x 3" K&N air cleaner-180 t-stat-Ignition(Taylor 8mm SP wires, Indexed NGK 2262 plugs, brass cap&rotor)-MSD SS Blaster Coil-MSD 6A Ignition-Zirgo 16" Electric fan w/adj. temp. control-SRT Hood-SRT Front Bumper -Sir Michaels Rollpan-Mopar Billet Fuel Door -RAM 3rd Brake Light Cover-Flamed Taillight Covers-Painted Stock Billet Grille and RamHead-Custom blacked out headlights-Mopar Fiberglass Tonneau Cover-Power Sunroof-Silverstar lights
2012 Dodge Avenger R/T Black
Mods
-Mopar CAI
gouge93 is offline
post #4 of 9 Old 11-30-2004, 10:10 PM
Dodgevanman
Do It In A Van
Maybe...my A-518 trans. in my '94 B250 is also known as the 46RE.
Is it possible that since the A-518 is a totally hydraulic unit, but the 46RE has some electronics? I don't know....I think it's just new-age technical jargon for a Torqueflite A-518.
Nate Breece
5.2L Magnum
3.8L
Member of:
post #5 of 9 Old 12-01-2004, 01:31 AM
BVRmonger
I think the 46RE just means 'electronic' but wasn't there a 46RH (hydraulic) before there was the 46RE? About the 518/46..it may just be a name change. Gm used to have the 700R4 and then the same tranny became the 4L60 and then the 4L60E
BVRmonger is offline
post #6 of 9 Old 12-01-2004, 11:28 PM Thread Starter
indyram02
ok well heres another question for you transmission people, i've heard(thought i don't know for sure) that parts, like floor shifters, that fit the torqueflite 727 will also fit the A-518/46RE, i know they are very similar but is that true, because i'm also looking for a floor shifter and i can't find anything except ones for the torqueflite 727 and 904. thanks again
post #7 of 9 Old 12-03-2004, 03:31 AM
2000R
I think you are right about the 46RH, I belive that is what is in my 95 Ram.
2000R is offline
post #8 of 9 Old 12-03-2004, 04:15 AM
AP
USAF MOPAR MILITARY BRAT
AP's Avatar
I've posted this once before, I think this should answer your questions. More info at www.smrtrans.com.
My first new vehicle: 2003 Dodge Dakota Stampede 4X2 short bed
Graphite Metallic Clear Coat
4.7L. Magnum V8
5-45RFE auto, 3:92 gears anti-slip diff.
Mods: K&N filter, and MBRP performance exhaust,
stainless steel " Cuda Style " dual cat-back with roll
pan with exhaust openings, Jason bed cover, and alot of exterior acessories!NEW JUST ADDED AN AWSOME SHAKER HOOD!!
My second vehicle : 1998 Dodge Durango SLT Plus 4X4
Deep Amethyst Pearl Coat
5.2 L. Magnum SMPI V8
4 speed auto
Mods: none so far.
Previously owned cars:
1) 65 Dodge Polara 4 door 383 ( my first car )
2) 72 Plymouth Golden Duster 318
3) 73 Plymouth Cuda 360 ( my summer toy
4) 75 Plymouth Sport Fury 318
5) 88 Dodge Ram LE 150 318 FI
6) 92 Plymouth Sundance 4 cyl.
AP is offline
post #9 of 9 Old 12-03-2004, 07:14 AM
Dodgevanman
Do It In A Van
Ahhhh I was incorrect...the A518 has two versions. Electronic and hydraulic. Well I know for sure my 94 B250 is the 46RH non-electronic.
H=Hydraulic
E=Electronic
2 + 2 = 4
Wow how bout that! LOL!!
Nate Breece
5.2L Magnum
3.8L
Member of:
