Go Back   Dodge Talk Community Forum > Dodge Truck, SUV and Van Forums > Van and Cargo Truck Forums > B-Series Vans 1971 - 2003
pk89
  Battery Isolator - Posted: 04-20-2006, 12:56 PM
Post #1
I want to install a battery isolator in my 89 B250 camper van and not too sure what amperage rating I should go with.
The altenator is rated at 120 amps and I will be using a auxiallary deep cycle that will be connected to a 1000 watt invertor which is used on a small fridge.
The most common isolator I can find is a 95 amp and the next one available is 130 amps.
There is a large price difference between the two isolators. Would the batteries ever require anything more than 95 amps? Sounds like quite a bit of currant that anything above that would be unsafe.
Thanks !
Brown79
 Posted: 04-20-2006, 07:00 PM
Brown79's Avatar
City: Vancouver
State: BC
Post #2
I am also running a 95 amp isolator in my van. I also opted for the cheaper 95 amp version since the 120 amp was much more expensive.
I dont think the alternator would ever actually push out that much amperage in an everday situation. Your standard accesories; lights, fan, ignition and the draw from your slightly drained batteries should never cause that much load to be put on the alternator.
Soon after I spent the $60 on the new isolator, I saw them at swap meets all the time. Most of them were basically brand new and I bought a handful for $5-10 each. I figured it's a good price and will no doubt find someone who'll need one.
Optima Red Top Battery? NEED SOME HELP! blkramlb22s 3G RAM - General Talk 10 03-15-2006 10:41 AM
Adding a second battery. Rob Mobile Audio & Electronics Talk 4 02-26-2006 10:56 AM
Low battery & truck wants to stall Dogu 2G RAM - General Talk 7 02-03-2006 06:42 PM
Battery draining? Robbiesan Neon - General Talk 2 10-09-2004 12:41 PM
2 Batteries? 6Charger9 Ram 1st Gen (88 - 93) Forum 1 12-12-2003 10:18 PM
