1995 trouble codes
- Posted: 04-17-2006, 09:37 PM
Post #1
I can't get my mil to flash codes light does not come on exept when the voltage to the sensors drops. the light is good
| Sponsored Links |
Posted: 04-17-2006, 10:37 PM
Post #2
So MIL won't come on when you first turn the key on? Interesting. I'm gonna double check to make sure it does on my '94....just for a reference.
Nate the skate ![]() 1994 B250 Ram Van Conversion by Elk 5.2L Magnum 1972 B200 Royal Sportsman Maxiwagon 318/2bbl. 1985 B150 318/2bbl. Click HERE to view the complete signature... |
Posted: 04-18-2006, 10:42 AM
Post #3
My engine light (MIL) does come on for about 2 seconds after start-up and then shuts off. If your MIL doesn't come on during this time, I'd say that either there is a ground problem, a power supply problem, or maybe the ECM is bad. A good way to check is to see if a code scanner will communicate with the ECM. Autozone or possibly Advance Auto Parts can connect a code scanner for you.
mil
- Posted: 04-18-2006, 07:34 PM
Post #4
I have to check to see if my mil light comes on like yours, it does light up but I wasn't paying attention. I just got an Actron(?) scanner and sometimes it doesn't link up it only shows o/d and a/c codes. I was told if you have a bad pcm in some cases the scanner won't pick it up. I am going to get another pcm (any suggestions for a reasonably priced one?) and keep mine and fix it. I have all the equipment to do this. Thank you for your help..The pcm for these years only has one problem so if anyone has a problem with it don't change the cam and crank sensors, I can almost guarantee it is the 8v output to these sensors.(orange wire) so a pin can be stuck in the insulation and with a vod you can check the votage to ground. Mine pulls in the two relays at about 5.5v.
| Sponsored Links |
Posted: 04-19-2006, 07:01 AM
Post #5
I don't recommend a used PCM, but I would try places like Autozone, Advance Auto Parts, NAPA, etc.
| Thread Tools | |
| 1995 Dodge Ram 2500 CTD (TROUBLE WITH FUEL FLOW) | Pipes95 | 2G Ram Diesel Talk | 5 | 02-23-2006 03:34 PM |
| trouble codes | Jmw132001 | Other Dodge Vehicle Talk | 0 | 01-30-2006 03:02 AM |
| 1995 chrysler concorde engine codes | ranlyn | Other Dodge Vehicle Talk | 1 | 10-31-2005 10:34 AM |
| Dodge Cummins Trouble Codes | DLDJR | Diesel Tech | 3 | 12-29-2004 08:08 PM |
| Dodge Trouble Codes | rickj | Other Dodge Vehicle Talk | 2 | 09-27-2004 10:30 PM |
| Sponsored Links |
