Go Back   Dodge Talk Community Forum > Dodge Truck, SUV and Van Forums > Van and Cargo Truck Forums > B-Series Vans 1971 - 2003
car54
  1995 3.9l van pcm - Posted: 04-12-2006, 01:24 PM
Post #1
I have 2.8v on the input that is supposed to be 8v going to the sensors the voltage slowly rises to 4.9v (last reading) so I think there may be a bad resistor or connection anyone track thisw down further? may be a simple fix that these "rebuilders" are making a killing on.
Registered users do not see this ad or IntelliTXT ads. Please Register today! Its quick, easy and free!
Dodgevanman
 Posted: 04-12-2006, 07:23 PM
Dodgevanman's Avatar
Do It In A Van
City: Baltimore Hon!
State: MD
Post #2
What sensors are you testing?
Nate the skate
5.2L Magnum
1972 B200 Royal Sportsman Maxiwagon
318/2bbl.
1985 B150
318/2bbl.
Click HERE to view the complete signature...
car54
 Posted: 04-12-2006, 07:26 PM
Post #3
cam/crank/veh speed sensor
Dodgevanman
 Posted: 04-12-2006, 07:59 PM
Do It In A Van
State: MD
Post #4
8v is supplied to the cam sensor via the orange wire at cavity 7 at the PCM, the ground is cavity 4 at the PCM. A 5V reference signal is returned to the PCM at cavity 44 with the rotor facing towards the rear of the engine (according to the manual this how you test the cam sensor)
8V is supplied to the crank sensor via the same orange wire at cavity 7 at the PCM and the ground is also cavity 4 at the PCM. No reference signal info. is given however to test the crank sensor, disconnect the crank sensor connector and check for resistance across terminals B & C at the pigtail coming from the sensor....there should be 0 resistance.
Also according to the manual you should use cavity 4 as your ground source for the volt/ohm meter while testing for voltage.
Nate the skate
5.2L Magnum
318/2bbl.
1985 B150
318/2bbl.
1995 3.9l van pcm car54 B-Series Vans 1971 - 2003 2 10-31-2006 07:42 PM
Doing some mods, help me out guys. racerX_244 2G Dakota Performance Talk 27 02-28-2004 12:37 AM
Help: 1996 Ram Van PCM engine computer location? josrulz Other Dodge Vehicle Talk 1 09-05-2003 10:52 PM
Dodge Commercial Vehicle Sprinter Van RAM MAN Other Dodge Vehicle Talk 7 02-15-2003 11:25 AM
