calling all ECM experts
- Posted: 04-09-2006, 12:36 PM
Post #1
OK so who's the computer wiz here?...I have a 92 b350,5.9,ecm number is 5602 7158, bad ECM. I have an ecm from a 91 b350 5.9..identically set up..the ecm is 5602 7157..they tell me they won't interchange..does anyone know for sure?, and is there anything I can "adjust". to make it work?....thanks
| Sponsored Links |
Posted: 04-10-2006, 12:51 PM
Post #2
Well..there probably isn't anything you're going to able to "adjust" really. It's either going to work or it isn't. Have you tried plugging it in to see if it's going to work? Eventhough you think you have an identical setup, slight variances from year to year may cause the '91 ECM not to work with your '92 engine.
Nate the skate ![]() 1994 B250 Ram Van Conversion by Elk 5.2L Magnum 1972 B200 Royal Sportsman Maxiwagon 318/2bbl. 1985 B150 318/2bbl. Click HERE to view the complete signature... |
Posted: 04-10-2006, 12:57 PM
Post #3
In 91 the fuel injection system was throttle body. The 92 was multi port . If this is the case it will not work.
Later Chris 79 Lil Red Supercharged V10 89 Lebaron 2.2 Turbo 13.1 @108 1/4 mile |
Posted: 04-10-2006, 12:58 PM
Post #4
THanks..No I didn't mean adjust in the literal sense, Was more like thinking if there is only a circuit difference, that I could disconnect or a jumper that I could solder, that's all..thanks
Posted: 04-10-2006, 01:02 PM
Post #5
92 is throttle body as well..this is the 5.9...didn't go magnum until 93..only the 5.2 and 3.9 went magnum in 92.that's why I'm questioning it
Posted: 04-10-2006, 05:05 PM
Post #6
Ok then I would plug it in and give try. Alot of the time it is just a small calibration change.
| Sponsored Links |
Posted: 04-10-2006, 06:10 PM
Post #7
That's what I was hoping for....these two are identical...Maybe the 90 didn't have abs, I don't have that van for reference, but all else is equal, thanks guys for all your help
Posted: 04-17-2006, 12:24 AM
Post #8
Here's what the parts book lists...
5602 7157 B 1992, 360 Eng, A-518 Trans., w/o RFI 5602 7158 B 1992, Auto. Trans., w/RFI |
| Thread Tools | |
| What's your ECM and TCM? | revdoctor | Magnum - Performance Talk | 15 | 04-30-2006 11:10 AM |
| Calling all photoshop experts.. | 4xfreak | Concept/Modified Vehicle Talk | 4 | 02-28-2006 01:25 AM |
| Engine Codes P0336, P1693 ?? | kg1216 | Diesel Tech | 12 | 04-21-2005 10:24 AM |
| Stalling hot - is mechanic right? Swap ECM? | 8writer | Dakota 1st Gen (Pre-1997) Forum | 2 | 09-25-2004 04:38 PM |
| calling all experts...... | FRQ FLYR | Magnum - General Talk | 2 | 09-06-2004 03:47 PM |
| Sponsored Links |
