pcm problems
- Posted: 04-06-2006, 08:19 PM
Post #1
hi all, my pcm isn't working I disconnected negative cable saturday after the clicking it started, was able to scan but it didn't send any codes except for a/c which I don't have and o/d which I also don't have. can pcm "relearn" if it is just cranking but won't start?only thing left is camshaft sensor but I am fairly sure is ok. I hate to get a new pcm but if I do it may still be screwed up. computer ground is good. no bad connections crankshaft sensor is new
| Sponsored Links |
Posted: 04-07-2006, 07:11 AM
Post #2
Well it certainly sounds like the PCM is throwing bogus codes....not a good sign I'm afraid.
Vehicle has to run in order for the PCM to learn.
Nate the skate ![]() 1994 B250 Ram Van Conversion by Elk 5.2L Magnum 1972 B200 Royal Sportsman Maxiwagon 318/2bbl. 1985 B150 318/2bbl. Click HERE to view the complete signature... |
| Sponsored Links |
Posted: 04-13-2006, 10:59 AM
Post #3
i have had the same issue and the same troubleshooting codes. Yesterday, my van would just crank and would not start. This guy walked over and said " I don't think your getting any spark". I responded that I have been having problems with the asd relay and pcm and that it was something along those lines. he begins telling me a story about a guy who broke down on the Manhattan Bridge and ..." i got a crescent wrench and tapped on the gas tank right under the fuel pump..." I told him that I just replaced the fuel pump. He gets down on a knee and: "If you have a hammer I'll just give it a few taps." He gave the fuel tank a few whacks and I gave it a try. It started right up. go figure.
Posted: 04-16-2006, 11:55 PM
Post #4
Posted: 04-17-2006, 12:00 AM
Post #5
Bad electrical connection at the fuel pump or the new pump is shot already. Some of the aftermarket fuel pumps will fail quickly...I had one friend that got 5 pumps from Autozone for a GM Truck. finally got his money back and bought an AC Delco(GM) pump and the truck has been running for 2 years without a burp! |
| Thread Tools | |
| Superchips damaged PCM?? | mullinax05 | 3G Ram Performance Talk | 110 | 04-09-2006 12:13 PM |
| Downsides of Mopar PCM?? | Haeusser | 2G RAM - General Talk | 28 | 04-29-2005 09:24 AM |
| pcm problems | wetbar | 1G Durango General Talk | 0 | 04-27-2004 05:48 PM |
| Pcm Needs Replacing | 99DODGEDRIVER | 1G Durango General Talk | 5 | 04-08-2004 02:27 PM |
| Sponsored Links |
