Go Back   Dodge Talk Community Forum > Dodge Truck, SUV and Van Forums > Van and Cargo Truck Forums > B-Series Vans 1971 - 2003
bocephus
  Angry 92 van no start - Posted: 04-05-2006, 02:55 PM
Post #1
HI guys..My 1992 b350,went dead..(last year pre-magnum for 5.9),just cranks..eng. light flickers and clicks like a machine gun...I traced a click to the asd relay, replaced it..she starts..later she dies again randomly could be 10 min. or an hour..sometimes I can pump the hell out of it and she'll start..thought fuel pump..but I am getting plenty of fuel when no start occurs..no ign..thinking maybe the ecm is bad..what do you think. there's a new coil,asd relay,dist. pickup...gettin me angry..Thanks
Registered users do not see this ad or IntelliTXT ads. Please Register today! Its quick, easy and free!
Dodgevanman
 Posted: 04-06-2006, 08:17 AM
Dodgevanman's Avatar
Do It In A Van
City: Baltimore Hon!
State: MD
Post #2
Could be a bad ECM or bad grounds.
Nate the skate
5.2L Magnum
1972 B200 Royal Sportsman Maxiwagon
318/2bbl.
1985 B150
318/2bbl.
Click HERE to view the complete signature...
bocephus
 Posted: 04-06-2006, 09:01 PM
Post #3
Yeah I've checked all connections/links..already.I will replace the ecm.....Thanks.What is the average life expectancy of the ecm anyway?
Dodgevanman
 Posted: 04-07-2006, 07:09 AM
Do It In A Van
State: MD
Post #4
Technically they're supposed to last indenfinitely, but ECM's are just like any other computer they just burn out sometimes.
Nate the skate
5.2L Magnum
318/2bbl.
1985 B150
318/2bbl.
bocephus
 Posted: 04-07-2006, 03:37 PM
Post #5
HA HA..technically..like technically,according to my dodge dealer manual, the cat is supposed to last the life of the vehicle !!..Thanks
Chump
 Posted: 04-17-2006, 12:35 AM
Chump's Avatar
State: CO
Post #6
http://dodgeram.info/tsb/1992/18-04-92.htm
bocephus
 Posted: 04-17-2006, 10:39 AM
Post #7
thanks..but there is no crank position sensor on a 92 5.9...the 5.9 didn't go magnum until 93..because of this there is some confusion in repair manuals
Chump
 Posted: 04-17-2006, 11:48 AM
Chump's Avatar
State: CO
Post #8
I would swap in another computer. You might find a used one but it might also have problems. www.car-part.com
Depending on the part# of the one you have, you may be able to find a rebuilt one but from what I see, some of the computers listed to your van are only available if you remove yours and send it in to be rebuilt.
What's the part number on your computer?
bocephus
 Posted: 04-17-2006, 10:00 PM
Post #9
thanks..number on mine is 5602 7158....will the diag. scan detect a bad ecm ?
Dodgevanman
 Posted: 04-17-2006, 10:39 PM
Do It In A Van
State: MD
Post #10
Sometimes a bad ECM will not communicate with a scanner.
Nate the skate
5.2L Magnum
318/2bbl.
1985 B150
318/2bbl.
bocephus
 Posted: 04-17-2006, 10:43 PM
Post #11
yeah I was afraid of that...guess I'll just install a rebuilt ecm, and hope I don't get stranded..It's ironic.. I have both a new ford and a new chev. van both 1 tons, but I rather be in my old dodge any day of the week
Chump
 Posted: 04-18-2006, 12:43 AM
Chump's Avatar
State: CO
Post #12
As Dodgevanman points out, it may not communicate. I have only heard of a few early vintage Chrysler computers that actually posted a controller failure error that could be scanned. Most normally a driver circuit goes out or capaciters might leak and cause board damage. This is OBD1 diagnostics which WAS state of the art, when art was old! The error codes were generic in nature and indicated a complete circuit that might be causing a problem, it is the job of the tech to eliminate all of the hardware in that circuit and if it's ok, then replace the computer.
w/RNS High Altitude Emissions w/OEM #56027158
Rebuild part# 79-7158(A1 Cardone Rebuilder)
Rebuild part# NEC XTP97158(NAPA)
www.rockauto.com might be your cheapest route after all is said and done.
53 Internal controller failure
Internal controller fault condition detected.
62 Controller failure
Controller failure EMR miles not stored
63 Controller failure
Controller failure EEPROM write denied
car54
 Posted: 04-28-2006, 01:24 PM
Post #13
I just fixed my pcm, if you need a hand, drop me a line
brinny
  did you fix this problem? - Posted: 10-31-2006, 03:52 PM
Post #14
I have a 92 with a 3.9l and am having the same problem. Did you get this fixed and if so, how?
thanks
94, 250 van v6, will not start every time, no spark photomanteg B-Series Vans 1971 - 2003 12 10-03-2007 03:45 PM
hard to start shagybruce B-Series Vans 1971 - 2003 4 06-24-2005 04:02 PM
2001 Caravan won't start in cold/wet weather lorrie Caravan Talk 7 12-28-2004 05:03 PM
Not wanting to start... Andy 3G RAM - General Talk 8 12-05-2004 03:45 PM
Bad Van? What to do? Scott in GB Caravan Talk 6 11-12-2002 04:55 PM
