Crankshaft Pulley Bolt Size - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 8 Old 03-31-2006, 05:19 PM Thread Starter
mbret2004
I have to change a forward crankshaft seal (on the timing chain cover) is that a 32MM bolt on crank pulley? It's a 96 with a 360. Thanks
mbret2004 is offline
post #2 of 8 Old 03-31-2006, 07:12 PM
sysengr1
sysengr1's Avatar
I think it's a 35. You local auto parts dude can verify. you have a pulley puller?
1998 5.2 SC/SWB - AEM CAI, Custom 52mm Throttle Body, Hypertech III, JBA Titanium Coat Headers, Random Tech Cat 3'' in/out, 3'' s/s Catback w/Flowmaster Super 40, 4.56 Precision Gears, Powertrax no-slip, Hellwig Traction Control Leaf Helpers. Worth the price for ~$70 and even the Titan guys like em'
(yes, I do sneak onto the Titan forums from time to time, gotta see what the enemy is doing, right? Have to admit, I've liked those trucks since they came out, ugly body and all):
20'' MB Predators, 285/50R20's (F), 305/50R20's (R) General Grabber UHP's.
Crower 1.7 RR's/Magnum Performance valve covers purchased - (thanks Steve00ram,dodgeforum). Belltech 2'' drop spindles/1'' coils (f) and Belltech 4'' drop leaf springs/Hellwig rear sway bar (r) purchased.
sysengr1 is offline
post #3 of 8 Old 04-01-2006, 08:42 AM Thread Starter
mbret2004
yes, I have a puller for the balancer.
post #4 of 8 Old 04-02-2006, 05:29 PM
Coop
Coop's Avatar
A 32mm 6 point will work.
Coop is offline
post #5 of 8 Old 04-02-2006, 06:44 PM Thread Starter
mbret2004
Ya, I was actually at Sears today, and the closest I could find was a 32MM. They didn't have a 31MM in stock. The 32MM seemed a little oversize. I'm wanting to try a 31MM. I just don't want to even think about rounding off a corner on this particular bolt. Anyone else help, this seems awfully odd..............
post #6 of 8 Old 04-04-2006, 10:34 AM
Coop
Coop's Avatar
I could turn the motor over through the compression stroke with the 32mm without a problem.
Coop is offline
post #7 of 8 Old 04-04-2006, 12:09 PM Thread Starter
mbret2004
Thanks, with that in mind I'll use the 32MM. I appreciate the input.
post #8 of 8 Old 04-15-2006, 04:19 PM Thread Starter
mbret2004
Just for the record, the correct bolt size on the 360 Ram crank pulley is a 31 MM.
    Avenger Timing Belt ? avengerboi2950 Vintage Dodge Car Forum 12 07-22-2006 07:15 PM
    If You Have An 4.7l Asp Pulley Remove It Now! AIR_RAM 3G Dodge Ram Performance Talk 87 01-26-2006 07:54 PM
    Need seat bolt thread size cavuu Dodge Magnum - General Talk 2 11-15-2005 07:42 AM
    Aluminum crankshaft pulley...? Mostro750 1G Dodge Durango Performance Talk 10 07-27-2005 09:49 PM
