1983 d150 wont start - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 22 Old 03-21-2006, 12:01 AM Thread Starter
Dodge_convert
Dodge_convert's Avatar
I have 1983 ram D150 one day while at the store it started just fine and when I went to back it out it staled on me and would not start again. I coasted it down the hill and tried to jump start but nothing. I changed the plugs, wires, cap, rotor, fuel filter, fuel pump, Checked the Ignition coil (checked out just fine) Check the Voltage regulator (also fine). The battery is good i still have lights and the truck turns over but it just wont start. 1 more thing the guy at the parts store said to check the ignition control module and told me where to look its supposed to be on the drivers side wheel wall as pictured in the Haynes manual and it is nowhere to be found in my truck.. I am stumped at this point.. Any ideas?
Dodge_convert is offline
post #2 of 22 Old 03-21-2006, 07:43 AM
Dodgevanman
Do It In A Van
Dodgevanman's Avatar
Here's a pic of what the ignition module looks like and a picture of the ballast resistor, which could be giving you a problem.
Nate Breece
5.2L Magnum
2008 Grand Caravan SXT
3.8L
Member of:
Dodgevanman is offline
post #3 of 22 Old 03-21-2006, 08:27 AM Thread Starter
Dodge_convert
Yeah both of which are pictured in the Haynes manual but they are not in the spot indicated in the book I looked the engine compartment over a number of times and can not find them. I just went out and pulled a plug and it is dry and no spark..
post #4 of 22 Old 03-21-2006, 09:06 AM
andy2
if your plug is dry it means no fuel is getting to the carb and to the engine. dis connect the fuel line from the carb, roll the engine over with the coil wire disconnected. if no fuel shoots out of the fuel line your fuel pump is shot or your fuel filter is plugged. if no spark, check relays on drivers side fender well under hood. also on drivers side fenderwell there are 4 to 5 wires taped together which are fuseable links. peel back the tape holding them together and inspect each wire. if one is melted, swap wire out with one of the same size. you also need to find out why the link melted.
andy2 is offline
post #5 of 22 Old 03-21-2006, 09:13 AM
bherder
Mopar Madness - Get it...
bherder's Avatar
The ballast resistor should be (Unless someone has moved it) on the firewall, tucked into the driverside corner....
The ignition module should be pretty darn close to it... Mine is on the firewall on the drivers side, right below the bulkhead...
They've GOT to be there somewhere!
[IMG]
"There's been a DODGE in my garage since 1974"
bherder is offline
post #6 of 22 Old 03-21-2006, 10:24 PM Thread Starter
Dodge_convert
Here are a couple Pictures of my firewall and fender wall on the drivers side where these 2 parts are to be located, as you can see they are not there. Could they be somewhere else. I looked the whole engine compartment over and even looked inside the cab with no luck. In the Haynes it says some models had a Spark Control Computer (SCC) and the picture looks alot like what I have on my Ram but its reads Electronic Fuel Control System (EFCS) could this be the SCC they are talking about Thanks again for all the advice. The 3rd picture down shows the EFCS attached to the air cleaner.
post #7 of 22 Old 03-21-2006, 10:55 PM
swami2806
swami2806's Avatar
I have an '87. My ignition module is on the other side of the engine, closer to the passenger side. I don't remember seeing my ballast...but I keep going by mid-70's setups, and they are in different places. I assumed if it was ESA it didn't have a ballast so didn't really look to hard...
*DodgeTalk.com
Member#37*
If Fords were the last cars on earth, I'd ride a horse.
1987 D-100
318 , A999, Quadrajet 4bbl. (came on truck).
Spring '07--Restoration has begun! Suspension and steering from Performance Suspension Technology. Front end apart and ready for install...more to come!
swami2806 is offline
post #8 of 22 Old 03-22-2006, 07:12 AM
Dodgevanman
Do It In A Van
Oh no man! You have the Electronic Lean Burn system on your truck. Those were very problematic and unreliable. That's probably your no-start problem.
How good are you at wiring? I ask because I would ditch that system and put in conventional electronic ignition.
Nate Breece
5.2L Magnum
3.8L
Member of:
post #9 of 22 Old 03-22-2006, 03:09 PM Thread Starter
Dodge_convert
If the directions are good I could wire it I'm sure. Do you know how much is involved in changing it over? I have a buddy coming over in a few days who lives dodge and he is going to take a look at it for me.
post #10 of 22 Old 03-22-2006, 04:11 PM Thread Starter
Dodge_convert
Oh by the way here are a few pictures of my D150. These will be the before shots. I guess I'll get the electrical and engine work done and then move on to the body work this summer and hopfully by the new year I'll have one sweet ride.. The best part is I picked it up for $500.00...
post #11 of 22 Old 03-22-2006, 04:39 PM
vestpuzzle1
"LUV 'EM OLD"
I like it. I have a shortbox. It is easy to switch anything on that truck. Have fun...R.V.
vestpuzzle1 is offline
post #12 of 22 Old 03-22-2006, 09:12 PM
red83150
You can order a conversion kit from Summmit racing. It has the dist, wiring harness, orange box ecu, and ballast resistor. The Mopar performance one is 197.00 and the Summit brand is I think 169.00. Or you can always change it to points. You'll need a points dist and ballast resistor. Lean burn set ups are junk when they get old, very undependable.
red83150 is offline
post #13 of 22 Old 03-23-2006, 12:47 PM
vestpuzzle1
"LUV 'EM OLD"
Lean burns are JUNK. Its real easy to switch to a normal setup.....R.V.
post #14 of 22 Old 03-23-2006, 08:43 PM
Dodgevanman
Do It In A Van
The Mopar Performance kit for slant sixes has been discontinued. However you can buy all the goodies from your local parts place. Just get distributor, ballast resistor, ECU, for like a '73 Dodge pickup w/slant six. It's not hard to switch over, but if you you have an electronic feedback carb. and oxygen sensor you will have to eliminate these. Summit Racing does have the electronic ignition harness, part no. MPP-3690152 or like 20 bucks.
Nate Breece
5.2L Magnum
3.8L
Member of:
post #15 of 22 Old 03-23-2006, 11:35 PM Thread Starter
Dodge_convert
I think I will switch over. I called my local yard and they have 4 old rams that I could go thru. Should I try them 1st or just go with the new parts?
Maybe I could just get the 318 out of my friends old Ramcharger. Major rear end damage so the front end is in great shape and should have everything I need for the switch.
post #16 of 22 Old 05-13-2006, 06:00 PM Thread Starter
Dodge_convert
Ok I finally got it going and its running better then before. It turns out it was a fusable link. (thanks andy2) I didnt pull the wire wrap far enough to see it but everything is working great and with the tune up it runs very nice. It still has the lean burn system on it. Im going to leave it for now. If it works dont mess with it thats what I say. Thanks for all the input guys....
post #17 of 22 Old 05-14-2006, 11:37 AM
Speed Dragon
Aka Force Fed Mopar
Speed Dragon's Avatar
Glad you got it running. I would start gathering up the parts for the elec ignition conversion, cause sooner or later that ESA system will crap out on you.
Rob M.
'93 D150 RC SWB, 5.2 Magnum, NV4500 5-spd, 9.25" diff
'72 D100 RC LWB, PT project
Speed Dragon is offline
post #18 of 22 Old 05-14-2006, 01:47 PM Thread Starter
Dodge_convert
Yeah I do have all the stuff for the switch over. It is all instaled but the dist and it needs to be wired but I'm gonna wait til I find a carb that will work with it. The one I got has a few too many vacuum ports.
post #19 of 22 Old 05-14-2006, 03:18 PM
swami2806
swami2806's Avatar
Just pick up some rubber caps for the ports at NAPA or somelpace. There is a variety pack they sell that should fit any port you need plugged. $2 vs. $200+
*DodgeTalk.com
Member#37*
1987 D-100
post #20 of 22 Old 05-14-2006, 05:14 PM
dodge318rulez
yea my truck did the same thing. those fusable links seem to give trouble...I shut my truck off and when i went to start it, no go. 1st the alternator wire jumped off, then it burnt a wire to the switch. It would start but wouldnt keep running. A couple weeks later another wire burnt in the same spot and it wouldnt keep the battery charged. just like the alternator wasnt there at all. Hooked that wire up and away it goes. Wiring on these old trucks is something else. Especially when its been tampered with 100 times. It starts to look pretty nasty under there. lol.
1983 Ram D-150 318 4 speed on the floor, Leather bucket seats, JVC head unit, 700 watt amp,Kenwood door speakers, (2) 12" Ultimate subs behind the seat, Oil pressure, RPM, water temp gages, Crome spoke wheels, Chrome valve covers, Windshild visor, Chrome pushbar, Interior lights, neons, 5% Tinted rear windows, Nos Floormats
dodge318rulez is offline
    1983 D150 belt bigdougydoug 1972-1987 Dodge Ram Trucks (D, W-series) 3 12-31-2005 05:36 AM
    Timming On 1983 D150 2 Barrel dirt420ba Dodge Ram Truck 1st Gen (88 - 93) Forum 7 10-09-2005 06:59 PM
    Command Start Lights Stay On Shelby_Daytona Dodge Dakota 1st Gen (87 -96) Forum 1 02-26-2005 07:49 PM
    1993 intrepid cold start problems hans Dodge Intrepid 1st Gen (93 - 97) 6 01-28-2005 05:53 PM
    94 Caravan, weird electrical, won't start arobinso Dodge Caravan General Talk 1 09-01-2004 07:46 AM
