Tach signal wire to Neg on coil?? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 6 Old 02-18-2006, 01:10 PM Thread Starter
Mopar Guy
2wd Dak, 4X4 soon
Anyone know were I need to hook up my signal wire fo my tach?
91 4X4 Dakota on 31" mudders
87 2 wd Dakota, 3.9, auto (soon to get 360/727)
(\__/)
(")_(")
Mopar Guy is offline
post #2 of 6 Old 02-19-2006, 11:58 PM Thread Starter
Mopar Guy
2wd Dak, 4X4 soon
Nobody knows?
(\__/)
(")_(")
post #3 of 6 Old 02-21-2006, 02:47 AM
Chump
Chump's Avatar
87 or 91? Is this a new tach and what brand? Have you tried their website or Tech Support phone line?
Chump is offline
post #4 of 6 Old 02-21-2006, 11:23 AM Thread Starter
Mopar Guy
2wd Dak, 4X4 soon
91 Dak V6 TBI
The tach is used (unknown brand) but worked fine on my 76 Buick with HEI before I took it out of the car.
I just can't find out where to hook it up. Someone said the neg on the coil? Sound right.
(\__/)
(")_(")
post #5 of 6 Old 02-21-2006, 02:16 PM
BDL
BDL's Avatar
Quoted: 9 Post(s)
Yes. That's correct. The positive on the coil should come from a switched positive voltage off the ignition (or from the computer) and the negative comes from the distributor (or from the computer). Basically, your tach is measuring how many times a spark is thrown in a matter of a minute. The output will change depending upon whether the tach thinks it's connected to a V8 or a V6 or a 4cyl. engine.
So, as long as your 76 Buick had a V6, then everything will work correctly. However, if your Buick had a V8, then you will need to find a brand name and find instructions on the Web. There will be an additional change in wiring with the unit if the number of cylinders changes. Usually, it's a matter of cutting the "green" wire if it's one thing or leaving it connected if it's another. The color may change and the specifics may differ slightly. However, I can't think of an instance where an easy wiring change would not be required.
1950 Dodge Panel Van (2002 5.9L Magnum V8)
1966 Dodge Charger (318 C.I. Poly-head V8)
1977 MGB (2005 3.5L V6, NSG370 6-speed manual trans, BMW E36 IRS and front spindles, Mustang II IFS, etc.)
2004 Dodge Ram 2500 (5.7L HEMI - My Daily Driver)
2006 Jeep Commander (4.7L Magnum V8 - Wife's Daily Driver)
Among other past vehicles, this one stands out...
BDL is offline
post #6 of 6 Old 02-22-2006, 02:52 AM Thread Starter
Mopar Guy
2wd Dak, 4X4 soon
Hey, thanks a lot for the tips. The tach has a switch on it so I just switched it to V6 from V8. It work fine now, I just need to get it mounted properly but thats easy. It's a 2" tach so it will fit fine on the column. I can't believe they made a manual truck without a tach!
Anyway BDL, your truck is really cool. Way to go!
(\__/)
(")_(")
    Tach signal wire?? Mopar Guy Dodge Dakota 1st Gen (87 -96) Forum 0 02-11-2006 08:23 PM
    Anyone know the tach signal wire on a 2004 Ram Hemi ? RigorMortis 3G Dodge Ram Performance Talk 4 01-27-2005 01:12 PM
    Tach signal wire for RS or tach ddn 1G Dodge Durango General Talk 4 11-15-2004 01:27 PM
    tach signal wire? four 2G Dodge Stratus - General Talk 1 11-11-2004 12:08 PM
