Thread Tools |
94 dodge spirit: wont start
- Posted: 02-05-2006, 08:48 AM
Post #1
Hi, I have a 94 spirit that won't start. It rolls over fine but no spark. The fuel pump doesn't work either. I have replaced the coil, auto shut down relay, and the computer with a salvage yard part. The haynes manual is very vague on testing procedures but I can take a test light and put it from battery ground to the blue wire on what I beleive is the asd relay and the fuel pump will fire. It will also fire if I put a jumper wire across the fuel pump relay. I cannot however get juice to the coil no matter what I try. I don't have a factory wiring diagram and the one in my manual doens't seem to match what I'm seeing on the car. any ideas would be greatly apreciated.
Kevin |
| Sponsored Links | |
Advertisement |
Posted: 02-05-2006, 09:34 AM
Post #2
ok so then you are grounding out the fuel pump relay and the fuel pump works.
Justin Resigned July 19th 2011 COIN HOLDERS ASSOCIATION MEMBER # 88 Beta tester for online games. 1998 Dodge Ram 1500 qc sport 360 4x4 208,300 original miles (as of 9-25-10) new transfer case, brakes, shocks, radiator, water pump(twice cause of faulty parts), front balls joints, trak bar, front u-joints, tires, heater core. |
Posted: 02-05-2006, 10:17 AM
Post #3
Yes but still no power to the coil. Also this is a 3.0 engine
Posted: 02-05-2006, 10:54 AM
Post #4
have you checked the ground wires inside the car.
Posted: 02-06-2006, 04:17 PM
Post #5
cleaned and reattatched all grounds in the engine compartment. no help. not sure what grounds inside the car you are talking about. please respond.
Posted: 02-06-2006, 04:33 PM
Post #6
ok inside the car their is a ground wire that runs inside the car under the carpet on the front drivers side under the dash. it goes to the fuel pump and the dash and if you do not get a good connection on it then it will mess up alot of different things.
Posted: 02-06-2006, 04:35 PM
Post #7
ok i'll go clean that right now. thanks alot
Posted: 02-06-2006, 05:05 PM
Post #8
looked ok, cleaned the ground inside the car anyway. no good
Posted: 02-06-2006, 05:12 PM
Post #9
Hmm... Have you checked the HEP? Those die ALL the time in these vehicles....
Additionally, have you tried pulling codes? (Key goes On-Off-On-Off-On, watch for flashing CHECK ENGINE light)?
1999 Dodge Caravan 3.3L "Purple People Eater" 1994 Dodge Spirit 3.0L |
Posted: 02-06-2006, 05:27 PM
Post #10
not sure what the HEP is or how to check it. tried to pull codes but got no check engine light, flashing or otherwise.
Posted: 02-06-2006, 05:33 PM
Post #11
ok, no let me make sure i got this right. the coil is not getting juice,correct. also is the wire to the actuall coil getting juice.
Posted: 02-06-2006, 05:39 PM
Post #12
no to both
Posted: 02-06-2006, 05:48 PM
Post #13
ok so then the wire that is going to the coil is not even getting juice. also the fuel pump is not getting juice. if that is the case i would check the wires that are coming into the autoshutdown relay and make sure they get juice when the car is first turned on. if not then you know it is farther back in the wiring.
Posted: 02-06-2006, 05:54 PM
Post #14
ok, I'm working with a bad wiring diagram. the large blue wire has juice to it, also the 2 red with white wires have juice with the ignition on. do you know what side of the computer the asd relay is on?
Posted: 02-06-2006, 06:10 PM
Post #15
well if i remember right, when you are standing in front of the car the battery is on the right side and so is the computer. the first little box behind the battery should be the asd relay.
Posted: 02-06-2006, 06:40 PM
Post #16
yes, but does the juice flow from the asd to the coil or into the computer? Also what is the HEP?
Posted: 02-06-2006, 07:28 PM
Post #17
i have no clue what the hep is. yes the juice should flow from the asd. asd is the relay that if something is wrong ir will shut down so nothing gets tore up. good luck
Posted: 02-07-2006, 12:13 PM
Post #18
HEP stands for Hall Effect Pickup... it's the sensor underneath the distributor that helps in determining timing... Although if you're getting no juice further up the line, that's probably not it...
On the other hand, if you're not getting ANY check engine light, the bulb for it may be burned out... when you turn the key to ON does it even light up? If not, that sucks... DCX's key-turning trick to get codes is a HUGE help when it comes to diagnosing a car
Posted: 02-07-2006, 02:51 PM
Post #19
I'm not getting a check engine light at all. I thought it might be connected to my problem. Maybe not? the haynes manual says this car uses a photo-electric sensor in the distributor. Any idea how to test the auto shut down relay off the car? I can jump a wire from the power input for the asd relay to the output going to the coil and I get juice at the coil. so I'm starting to suspect that I got a bad one from my dodge dealer.
Posted: 02-07-2006, 03:08 PM
Post #20
well i would go ahead and pop the dash out and make sure their is a bulb in the socket for the check engine light. you are probably getting codes but may not be able to see them.
| Thread Tools | |
| Dodge in Hot Pursuit of Police Car Market with HEMI®-powered 2006 Dodge Charger | FreeLantz | Rumor Mill & Gossip Talk | 42 | 06-04-2006 04:22 PM |
| 2006 Ram 1500 Info | FreeLantz | 3G Dodge RAM - General Talk | 120 | 02-20-2006 12:09 AM |
| Interior | Nosf3ratu | Dodge Charger (06-Up) - Interior/Exterior Talk | 37 | 10-10-2005 09:39 AM |
| '05 SRT-10 Quad and 2500 HD Power Wagon unveiled today! | FreeLantz | 3G Ram Power Wagon Talk | 1 | 06-15-2004 10:18 PM |
| Press Kit: 2004 Dodge Car Product Line-up | RAM MAN | Rumor Mill & Gossip Talk | 0 | 08-01-2003 02:42 PM |
Privacy Statement | |
