4 wheel on the fly shift question - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 15 Old 03-19-2003, 08:30 AM Thread Starter
mikiepeters
I have a 2001 1500 slt 4x4. When trying to shift on the fly to 4 high, anything over probably 5 miles per hour is not good...
you give it a light tug, and the synchro's don't appear to synch (if there are synchros). If you are just at a rolling start, it is ok. Going from 4 high to 2 high, no big deal at 20, 25...
I thought nothing of this, just thought that was the way it was supposed to, but a friend told me that with their 1500, they can shift on the fly "no problem".
Just wanted some feedback from the group.
To clarify... I do take my foot off the gas when shifting, just that if more than say, 5-7 mph, I will most probably get a gear grinding noise. (obviously I have been very careful with this... first time I was pretty freaked. ) I just want to find out if this is normal.
Thanks
mikiepeters is offline
post #2 of 15 Old 03-19-2003, 08:36 AM
GlassBlower
got beer?
GlassBlower's Avatar
I'm not sure, but that doesn't sound right. I can shift mine in at any speed, as long as I take my foot off the gas.
Hopefully someone else here can help more!
'98 Black Sport S/B-R/C 4x4 5.9, 180°, 3923 plugs,8.5 wires, CAI, Duals
3.55 Gears, Rear LSD, Rancho 5000s, Hella 500s, Truck Tec tonneau,
Kicker all around, 5x7 woofers in doors, tweets in posts, 5 1/4 mids in the rear posts,
Kenwood sub amp KAC-719, One a/d/s 308rs.2 sub, Sony head unit
Leather, Sliding rear window, 265/75/16 Hoosiers, Bed Rug, B&M 24000 GVW tranny cooler SOLD
2004.5 Polaris Sportsman 500 H.O. RED w/ plow, brushguard, and Warn 2500 K&N
Tampa Bay Buccaneers and New York Mets Fan
GlassBlower is offline
post #3 of 15 Old 03-19-2003, 08:50 AM
Painless
Me Likey me HEMI!
Painless's Avatar
i use to have a 2001 QC 4X4 with the 5.2 in it. it use to do the same thing. i took it to the sand dunes quite a bit. i always thought it was normal.
03 1500 QC HEMI 4X4-Stock (for now)
00 VW Jetta VR6 (wife's car)
Project 11's
89 Supra Turbo
T3/T4 Hybrid (Muahahahaha!!)
shooting for 450-500 RWHP
Painless is offline
post #4 of 15 Old 03-19-2003, 08:56 AM Thread Starter
mikiepeters
I'm still thinking normal, and maybe they have made an improvement to the synchro's over the years???
Thanks again
post #5 of 15 Old 03-19-2003, 09:18 AM
Rusty
Rusty's Avatar
Check your owners manual. You should be able to shift into 4-hi up to 45 mph. No problems with this in any of the three Ram's I've had.
Rusty
'02 Quad Cab SLT - 360, 4x4
Leer Topper, BedRug, K&N Air Filter
ICI Nerf Bars, Xtreme Floor Mats
Python 1400 Remote Start/Keyless Entry
LT285/70R-17 BFG All Terrain
Rusty is offline
post #6 of 15 Old 03-19-2003, 09:45 AM
Jeff_Taylor
On both of my Rams ('96 and '03) I could shift into 4HI at any speed, no grinding. The transfer case on the '96 was a little harder to shift, but still would not grind.
Sounds like your transfer case might need some attention.
Jeff
'10 Ram 1500 QC
TRX4, Hemi
Jeff_Taylor is offline
post #7 of 15 Old 03-19-2003, 12:14 PM Thread Starter
mikiepeters
Folks,
I called my Dealer...
there apparently are two types of transfer cases. (Service rep called them the solid one and the candy ass one!). What he said is that there are some transfer cases that will allow you to shift on the fly up to 40, but they have a pile of synchro's and brass bearings etc. to make that happen. He stated that this type has repair problems and is less reliable.
He also said that the type that I have (via luck only as I am obviously ignorant and blissful!) is much more reliable, and that the gear noise is normal. He stated that you could grind the gears all day and not hurt it at all. (I don't think I would recommend that). He said he recommends a rolling shift (walking speed), so that there are no noises, but that you could not really hurt it.
Guess I should have called them right away...
thanks for your input.
post #8 of 15 Old 03-20-2003, 09:53 AM
Jeff_Taylor
I'm havin' a hard time with that explanation.
How much warranty you got left?
Jeff
'10 Ram 1500 QC
TRX4, Hemi
post #9 of 15 Old 03-20-2003, 09:57 AM Thread Starter
mikiepeters
I've got 3000 miles left... what do you think?
post #10 of 15 Old 03-20-2003, 10:32 AM
Rusty
Rusty's Avatar
http://dodgeram.org/tech/specs/tranfer_case.htm
I agree with Jeff. Sounds like a line of BS.
Rusty
Rusty is offline
post #11 of 15 Old 03-21-2003, 04:16 PM
Jeff_Taylor
Get that puppy in to the dealer complaining about the transfer case. If they do nothing, at least it has been documented that you reported a problem. That MAY help if it fails after the warranty expires.
I have engaged 4wd at 55 MPH. No grind, no noise. I think you are correct when you say that it sounds like syncros are toasted.
Jeff
'10 Ram 1500 QC
TRX4, Hemi
post #12 of 15 Old 03-21-2003, 05:09 PM
spirit-dodge
CHROME
I think that if you have a button for 4 x4 its ok at most speeds. Manual shift seems like it needs to be at slow speeds. With my luck if I shifted into 4 high at 40 i'd find my tran. fallen behind me. Mine grinds about half the time,I usually shift below 10MPH.
spirit-dodge is offline
post #13 of 15 Old 03-21-2003, 05:46 PM
Sport97
Got a 97 Sport 1500 with manual shift and as long as my foot is off the gas I can throw it in to 4H at the higher speeds (never tried it over 45 tho). One thing that did have to get repaired was a broken shaft clip but that was an entirely different story. I say you got a problem and agree with the others that you take it to the dealer and tell them "fix it".
VRRROOOOOM!
Sport97 is offline
post #14 of 15 Old 03-21-2003, 11:52 PM
Seth
Seth's Avatar
Mine seems to go thru phases on my 97 Sport 1500. Sometimes it grinds and sometimes it doesnt. I have been able to switch into it at 55 mph, but the next day i couldnt do it unless under 10 mph without grinding. Even if it does grind, I usually will give it a fairly hefty pull and then it will go in, but you just have to use some force. I have never had a good transfer case in the first place, because ever since it went out the first time it grinds a lot (never did when it was under warranty). It seems almost every year, no matter how easy I am on it, my transfer case goes out. It really sucks and its my biggest complaint about my truck.
97 Dodge Ram 4X4 5.9L Sport
Add-ons:
Grill Guard, Roll/Light Bar, Nerf Bars, Hood Scoops, Dodge bed-liner
Tires:
Goodyear Wrangler MT/R's - The best off-roading tire out there!!
Performance:
K&N FIPK, Magnaflow cat-back exhaust, MSD 8.5mm wires, NGK V-Power Spark Plugs, Accel Brass Cap and Rotor, Accel Super Coil, Fastman 52mm TB, 180* T-stat
Seth is offline
post #15 of 15 Old 03-23-2003, 03:41 AM
quadfan
quadfan's Avatar
My 96 and now 99 Rams both were able to go back and forth from 4wl to 2wl at any speed. Even hitting icey overpasses at 75mph on the interstate. Once in a while it would make a slight grinding noise,but nothing like my old Chevys when shifting from 4lo to 2hi while racing corvettes stoplight to stoplight!!!!!
'99 Ram Quadcab 1500 4x4
$50 CAI (Ebay special)
Home-ported throttle body(as per fast4x4 instructions)
shorty headers with Flowmaster 2.5" stainless cat-back duals
Hypertech module (Ebay $75!!)
Magnacore plug wires
Champion Truck plugs
Pioneer DEH-p7400mp CD head unit
6x9 Blaupunkt 3ways in the front doors
6 1/2" Pioneer Subs in rear doors
250x4 Pyle amp(under passenger seat)
Billet grill
Custom silver stripes
quadfan is offline
    Wheel question 1 ton 'ner' 3G Dodge RAM - General Talk 0 02-19-2004 07:48 PM
    Factory Wheel Question MtnMan 3G Dodge RAM - Tire and Wheel Talk 2 12-05-2003 03:42 PM
    Shift into 4 wheel drive DandC 2G Dodge Dakota General Talk 5 05-08-2003 12:37 PM
