How to clear Check Engine light on 1992 Ram d50 - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 2 Old 01-19-2006, 05:10 PM Thread Starter
mpeteritas
Hey all,
This is my first post. Perhaps the first of many... I have a 1992 Mitsu Mighty Max (Ram d50) and it has a replaced fuel tank. This causes the gas gauge to be very inaccurate.
Long story short... I ran it out of gas. When I got it towed and put gas in it, it fired a check engine light and it won't go off (and it ain't running right...low idle). Have tried removing battery cables over night and it didn't clear the check engine light. Wondering if there is an additional procedure to clear the check engine light? Please advise...
Since I ran it out of gas, the idle has changed...from a cold start it no longer idles high for a minute or so like it used to. It now idles so slow it will stall if I don't warm it up manually. I attributed this to the ECU trying to compensate for whatever fault was fired. Might something else be causing this? Would running it out of gas potentially cause some part of the emissions system to fail? Any advice/comments?
I will try to get the fault codes tonight with the key turning procedure mentioned in other posts in this forum.
Thanks in advance!
-mark
mpeteritas is offline
post #2 of 2 Old 01-20-2006, 07:43 AM Thread Starter
mpeteritas
To follow up on this, I tried the Key-turn test to try to get the fault codes...no go on this vehicle. I turned the key on/off on/off on. The check engine light didn't flash at all, it just stayed lit. Any advice?
    Gas Milage Mods pkitzman 3G Dodge RAM Diesel Talk 49 01-08-2006 02:51 PM
    Starting at $21,700, New Dodge Ram Offers Truckload of Value HankL Rumor Mill & Gossip Talk 0 09-01-2005 10:13 AM
    2006 Dodge Ram 1500, What's New for '06 RAM MAN Rumor Mill & Gossip Talk 4 07-19-2005 09:31 AM
    Legendary Dodge Ram Power Wagon Returns RAM MAN Rumor Mill & Gossip Talk 4 10-02-2004 05:44 PM
