What temp does everyones Ram run at? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 20 Old 01-19-2006, 02:49 PM Thread Starter
jmh
jmh's Avatar
Mine seems to bounce from around 200 to 215. Is that cool enough? Would a lower temp tstat make any diff to benefit me?
How about Redline Water Wetter? Anyone used this stuff? is it worth the 8 bucks for the 18oz or so?
[2003 RAM 2500 Manual HEMI] - SOLD Sept 2016 w/ 149k miles - I Rebuilt my Tcase, added front driveline- 4wd worked GREAT after.
[1996 RAM 2500 v10] - SOLD Dec 2013 - Bought 5/30/2013 w/ 174k miles. Needed a ton of work.
[2004 RAM 1500] - SOLD Feb 2013 w/ 157k miles.
[2005 Durango SLT] - Bought June 2011 with 65K miles. Wife's HEMI grocery getter/kid hauler. Still own with 179K miles as of Mar 2017.
[1997 RAM 1500 SLT] -- SOLD 6/25/2012 w/ 193k miles
jmh is offline
post #2 of 20 Old 01-19-2006, 03:06 PM
Dodge318
Mine used to run at about 200 all the time. It dosen't any more it was stolen last night.
1995 Club Cab 1500 4x4 SLT laramie 5.2 Auto
297,000 miles and one theft under it's belt.
1997 Club Cab 1500 Sport 4x4 5.9L Auto
143,000 and doesn't run as good as the 1995
Dodge318 is offline
post #3 of 20 Old 01-19-2006, 04:17 PM
Big Joe SS/T
GROUNDED
Big Joe SS/T's Avatar
mine is 180-190 with my 180* tstat. It makes the truck run a little richer which also helps keep you from pinging.
Big Joe SS/T is offline
post #4 of 20 Old 01-19-2006, 07:10 PM
99ram_4x4
99ram_4x4's Avatar
my 360, and 2 other rams in the family, both with 318 run in the range from 195-200 with the factory 195 degree stats.
jhm...i wouldn't think that with the stock stat the engine should run as hot as 215. Have you done a coolant flush? When I flushed my cousings truck, his temp lower about 5 degrees. Just depends how dirty the coolant was.
1999 DODGE RAM 4X4 SPORT 5.9L
Mods Done
Hypertech Power Programmer III
Fastman 52mm Throttle Body
Custom Cat Back Dual Exhaust with 3.5" Chrome Tips
Mopar Round Air Cleaner
Autolite 3923 Spark Plugs
All Sales Aluminum 4x4 3rd Brake Light Cover
Factory Matched Window Tint All Around
285/75/16 Mastercraft Courser MT's
Magnaflow Cat
99ram_4x4 is offline
post #5 of 20 Old 01-19-2006, 07:36 PM
crazys182003
Quoted: 5 Post(s)
mine runs about 200 solid all the time.
crazys182003 is offline
post #6 of 20 Old 01-19-2006, 08:02 PM
98QuadCabV10
EPA's Worst Nightmare
98QuadCabV10's Avatar
215 is too hot for the winter time, unless it's loaded down. Check your coolant level. Your thermostat might be starting to stick also. If the cooling system test good then replace your thermostat and flush your cooling system. Don't forget to pressure test your cap.
Does it hit 215 when driving or sitting?
I run 185 all the time. I allmost hit 200 once when I was driving through extremely deep snow but then the fan clutch kicked in and went back to 185.
1998 Ram Quad Cab 2500 Short Bed V10 4x4
C.A.I.
Headers.
SCT Tuner
3" SRB Lift
Fast Man TB
GM Push Rods
2" Leveling Kit
1.7 Roller Rockers
Exhaust: No cats, Flowmaster 50
Best Runs
60': 2.27
1/8th: 10.23 @ 68.56 MPH
1/4: 15.93 @ 85.7 MPH
0-60: 7.9sec
V10 Ram Club #1
98QuadCabV10 is offline
post #7 of 20 Old 01-19-2006, 08:24 PM
ChevyEater360
I own your ass ;D
ChevyEater360's Avatar
mine runs about 200-210...seems to run just fine
ChevyEater360 is offline
post #8 of 20 Old 01-19-2006, 09:59 PM Thread Starter
jmh
jmh's Avatar
Thanks all.
Thats horrible about the stolen Ram. Its hard to have anything nice anymore.
Well, I have a leak in my radiator. I tried Bars Leaks, but no go.
I will be getting a new radiator, so, I will be flushing, replacing hoses and thermostat.
What is a good water/antifreeze mix?? And what is the easiest way to remove the transmission coolant hose? And Do I need to remove the fan, or will it be possible to get the shroud off without removing the fan?
Thanks all!!
jmh is offline
post #9 of 20 Old 01-20-2006, 12:24 AM
98QuadCabV10
50/50 mixture is the best. If the temp gets below -30 where you live then you might want to have more coolant than water. Sometimes you need to use distilled water instead of tap water. It all depends where you live. I have well water and have a lot of minerals and stuff in the water so I used distilled water.
You will probably need the quick disconnect tool for the trans lines. I used a pick and small screwdriver since I couldn't find the tool.
On my truck I unbolted the fan shroud and slid it to wards the engine block. Then lifted out my radiator. But that was on a V10 I would think you could do the same on your V8.
Make sure you get one that is made in USA not china, I replaced 4 of those great china quality products in 2 months. The good thing is my cooling system was flushed real good last year.
C.A.I.
Headers.
SCT Tuner
3" SRB Lift
Fast Man TB
GM Push Rods
2" Leveling Kit
1.7 Roller Rockers
Best Runs
60': 2.27
0-60: 7.9sec
V10 Ram Club #1
post #10 of 20 Old 01-20-2006, 01:18 PM
redwingedram
redwingedram's Avatar
hey 98quad whats it matter with the minerals? i use well water too should i use distilled?
1999 Ram 1500 Ext. Cab Short Box 4X4 Auto.
3" Lift
Hypertech Programmer III
K&N Cold Air Intake
Gibson Headers
3" Dual exhaust
Alpine Deck
redwingedram is offline
post #11 of 20 Old 01-20-2006, 01:38 PM
Silver_DodgeRam
Mmmmmmmmm, beer.
Silver_DodgeRam's Avatar
Quoted: 2 Post(s)
My truck runs really cool in the winter when it is cold outside. Take this morning for example. I doubt my gauge went over 145 or 150 the entire way to work. In the hot summer, I average about 180-190.
2009 Dodge Ram 1500 4x4, 5.7 Hemi, Crew - work in progress
2008 Chrysler Aspen 4x4, 5.7 Hemi, Loaded
Silver_DodgeRam is offline
post #12 of 20 Old 01-20-2006, 04:34 PM
sgillett
Love my 66 monaco 500
sgillett's Avatar
Quoted: 1 Post(s)
My '96 V10 runs at 195°F all the time unless I am pulling a steep hill at full throttle with 10,000# behind it, then it goes up to about 220°F.
V10 Ram truck club member #3
Toys:
'96 Ram 2500 V10 4X4 extended cab, long bed for towing my 28-foot 5th wheel Alfa toy house.
1966 Monaco 500 with a 365 horse power 440 and almost all options, my project car.
'07 Nitro R/T
My son has a '69 Dodge Coronet 440 with a warmed up 318 4bbl
Economy vehicle: Yamaha FJ1200
sgillett is offline
post #13 of 20 Old 01-20-2006, 08:32 PM Thread Starter
jmh
jmh's Avatar
I read in another forum that the 180 tstat caused the fuelmix to run rich. If that occurs, wouldn't carbon buildup be more likely? Anyone have any problems at all or noticed and performance increase/decrease w/ the 180tstat?
jmh is offline
post #14 of 20 Old 01-20-2006, 08:40 PM
ppp1182
ppp1182's Avatar
I run at 200 year-round, even when pulling a 5000lb boat/trailer combo. As for the minerals, they can deposit in your cooling system and eat the water pump.
2000 Ram 1500 SPORT 4x4 5.9L (360) in BLACK (it looks bigger)
BFG All-Terrain T/A KO 285/70r17 from Michigan 4 x 4
Port-matched MP1 Intake Manifold from The Fastman
17x8 Off-Road Edition rims (Thanks Tazz411)
Gibson swept-side stainless single exhaust
SCT custom tuned by Hemifever
Gibson ceramic coated headers
Fastman 52mm TB
Volant CAI
3.92 LSD
Next up (
better brakes
Flex-A-Lite efan
408 stroker with stage 3 Eddy heads
4.56 gears
ppp1182 is offline
post #15 of 20 Old 01-20-2006, 08:51 PM
98QuadCabV10
They can cause the cooling system to rust quickly if not properly mixed. PH also has an affect on it. My PH is usually around 5.0 (acidic) or lower (which is bad). Well water sure tastes a lot better than the city crap. If you properly maintain your cooling system it shouldn't rust as long as you have a 50/50 mixture. I would change over to distilled next time you flush your system.
C.A.I.
Headers.
SCT Tuner
3" SRB Lift
Fast Man TB
GM Push Rods
2" Leveling Kit
1.7 Roller Rockers
Best Runs
60': 2.27
0-60: 7.9sec
V10 Ram Club #1
post #16 of 20 Old 01-20-2006, 10:55 PM
01Drift
Changed thermostat back to factory 195F since some moron before me had a 180F piece in it. After major tune-up (overhaul TBI/IAC; spark plugs and high tension wires plus cap/rotor), and a new water pump, new accessory drive belt (and after thorough flush and fill to factory mixture spec; also added 8-ozs RMI-25) dealer scan tool showed 200-203F with MAX A/C on a 100F day, after getting off of highway and idling 5-minutes.
Dead stock with 110,000 miles (have owned 1-year/25,000 miles) and a muffler MORE restrictive than stock. 87-octane, meets EPA mpg figures. Never pings, loaded or empty, highway or city . . . and no death flash. Has not had plenum gasket replaced, but that finally blew since the above reading.
As I recall, Ph should be 9.0; some one correct me.
2004 2WD Quadcab NV-5600 Longbed
Cat Scale: 7,320# 19-22 mpg solo 13-16 tow
01Drift is offline
post #17 of 20 Old 01-20-2006, 11:12 PM
ppp1182
ppp1182's Avatar
ph 7 is neutral. basic (higher) is better than acidic...less stress on the metal
Fastman 52mm TB
Volant CAI
3.92 LSD
Next up (
better brakes
Flex-A-Lite efan
4.56 gears
ppp1182 is offline
post #18 of 20 Old 01-20-2006, 11:20 PM
ppp1182
ppp1182's Avatar
forgot to add this...bear with me...chemist speaking...the coolant solution passing through the engine under high heat will eventually go acidic because the water reacts with the metal in the block.
Fastman 52mm TB
Volant CAI
3.92 LSD
Next up (
better brakes
Flex-A-Lite efan
4.56 gears
ppp1182 is offline
post #19 of 20 Old 01-20-2006, 11:24 PM
jdr1234
David-2001 Ram Off-Road
jdr1234's Avatar
Mine runs here:
2001 Dodge Ram Off-Road,360 ci and 4.10's, Rough Country 5.5" Suspension Lift
35x12.50x17 Nitto Trail Grapplers, 17x9 Black Moto Metal Wheels,Tow Mirrors,Cab Lights, Fender Flares
jdr1234 is offline
post #20 of 20 Old 03-15-2006, 11:07 AM
01Drift
A link to a thread about pH and about electrical resistance
http://theoildrop.server101.com/ubb/...=000413#000000
http://theoildrop.server101.com/cgi/...;f=37;t=000401
01Drift is offline
    All-New 2006 Dodge Ram Mega Cab Dually FreeLantz Rumor Mill & Gossip Talk 18 01-31-2006 09:59 PM
    Starting at $21,700, New Dodge Ram Offers Truckload of Value HankL Rumor Mill & Gossip Talk 0 09-01-2005 10:13 AM
    2004 and Select 2005 New Vehicle Pricing RAM MAN Rumor Mill & Gossip Talk 0 03-21-2004 09:42 AM
    2004 Dodge Truck Highlights RAM MAN Rumor Mill & Gossip Talk 2 08-06-2003 11:46 AM
