turn signal wiring - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 6 Old 01-15-2006, 07:42 PM Thread Starter
spfitter
turn signal wiring
turn signal stopped working, ive replaced relay, checked fuses and bulbs and replaced turn signal switch, I have hazards any help would be appreciated.1998
spfitter is offline
post #2 of 6 Old 01-16-2006, 12:14 PM
mr.nobody
mr.nobody's Avatar
Quoted: 3 Post(s)
did you replace the flasher unit?? it should be in the fuse box.
CHRIS
mr.nobody is offline
post #3 of 6 Old 01-16-2006, 03:16 PM
Roadblock
Canadian Mopar Man
Roadblock's Avatar
I don't know how the Durango works with the signal wiring ( have never had to fix anything electrical yet) but I know in my 1991 Aerostar I used to own if one of the bulbs blow the whole system would stop working, just like a set of Christmas tree lights..
As She Stands Now
2000 Durango SLT Plus Full Time 4X4
- Tow Package
- 4.7L
2001 Grand Caravan Sport
- 3.3 L
Roadblock is offline
post #4 of 6 Old 01-17-2006, 04:01 AM
Chump
Chump's Avatar
Did both turn signals stop working? If you have a trailer towing connector at the rear, you might have some problems there like corrosion,etc.
Chump is offline
post #5 of 6 Old 01-17-2006, 06:44 PM
Roadblock
Canadian Mopar Man
Roadblock's Avatar
How would corrosion cause this problem? You thinking a short maybe?
As She Stands Now
- Tow Package
- 4.7L
- 3.3 L
post #6 of 6 Old 01-17-2006, 08:08 PM
Chump
Chump's Avatar
Yes corrosion can cause a direct short. The metal particles break down in a connector from exposure to a foreign substance like road garbage-salt, anti-freeze, oil, battery acid, etc. These metal particles can actually form a bridge from one terminal to another and short. A wire splice can dissolve from the same action or become highly resistive, this will force the electricity to take a different path and it don't car where, just as long as it's the easiest route. Those 3M quick connectors were commonly used to hook up trailer wiring as well as other things. The original ones do not have any dielectric grease in them to combat corrosion and the connector itself may actually cut a few strands of the wire making a weaker mechanical connection.
You can also see this same type of problem when a battery starts to get a parasitic drain, although not corrosion, when there is a path to ground caused by excessive acid fumes/fluid mixed with contaminates this gives a very small path for current to flow to ground. This battery drain may be just enough on a newer computer controlled vehicle to cause a no-start or other strange problems. I just was helping a lady in Canada with a 95 Caravan that her park lights would stay on all the time, turns out it was the trailer connector and the Dodge dealer fixed it for her. I'm in Colorado. Since I don't really know what the turn signal problem is in this thread, I threw out the trailer connector corrosion idea as an option, before I forget about it. To help reduce the corrosive effects of mother nature, use some dielectric grease on all your wining connections. This will help keep the bad fluids out.
Chump is offline
    2002 Durango turn signal problem DDurango28 1G Dodge Durango General Talk 3 06-30-2005 07:43 PM
    turn signal problems etnsfdny 1G Dodge Durango General Talk 2 05-27-2005 11:41 AM
    Newbie with strange turn signal problem dorkdvr 3G Dodge RAM - General Talk 1 05-25-2005 05:17 PM
    M3 Mirror turn signal wiring 99RT 2G Dodge Dakota General Talk 7 06-06-2004 12:24 AM
