Driveshaft torque specs? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 2 Old 01-09-2006, 12:46 AM Thread Starter
adamsredlines
Dodge Fanatic!
Anybody know what the torque specs are on the 3 (or 4) bolts that join the differential to the driveshaft? Its on the front of the differential, behind the universal joint, there's two plates that meet up held together with 3 or 4 bolts....
adamsredlines is offline
post #2 of 2 Old 01-09-2006, 07:38 AM
kenihemi
kenihemi's Avatar
INSTALLATION
(1) Slide slip yoke onto the transmission/transfer
case output shaft.
(2) Align and install center bearing on crossmember,
if equipped and tighten nuts to 54 Nm (40 ft.
lbs.).
(3) Align reference marks on propeller shaft and
pinion flange or pinon yoke.
(4) Install new bolts and tighten to:
(Fig. 14) Companion flange bolts 15 Nm (85 ft.
lbs.)
(Fig. 15) Yoke clamp bolts 29 Nm (22 ft. lbs.)
NOTE: Companion flange bolts incorporate a LoctiteT
patch, new bolts should be used. If bolts are
not available, clean bolts and apply LoctiteT 242 to
the threads.
'04 Hemi Ram 1500 QC, 4X4, 4.56 gears, STS turbo = 450+RWHP, SCT Tuner, B&M MegaShifter.
kenihemi is offline
    Intrepid Tie Rod/Steering Rack Torque Specs anderc1 2G Dodge Intrepid - General Talk 0 05-18-2005 10:00 AM
    Wheel nuts Torque Specs rmcqcc 2G Dodge Intrepid - General Talk 1 04-15-2005 07:29 AM
    torque specs for front lower shock bolts EricB 2G Dodge RAM - General Talk 2 03-02-2005 01:00 PM
    aps converter RAMBS 3G Dodge Ram Performance Talk 86 01-29-2005 10:48 PM
    Torque Specs for Lug Nuts cbrenn71 1G Dodge Durango General Talk 9 01-02-2005 02:40 PM
