Go Back   Dodge Talk Community Forum > Dodge Vehicle Forums > Stratus Talk > Stratus 2nd Gen (01 - 06) > 2G Stratus - Performance Talk
chrisl62
  getting the harmonic balance off of a 2000 stratus - Posted: 01-08-2006, 03:06 PM
Post #1
I have a 2000 dodge stratus with the 2.4 liter engine and need help getting the harmonic balance off i have tried to pull it with the puller autozone suggested but the pulley has no bolt holes other than the center bolt so i tried a wheel puller and it is pulling the pulley apart what can i do to get this pulley off. thanks chris
fligger3
  Removing the crankshaft balancer - Posted: 04-05-2006, 05:53 PM
fligger3's Avatar
City: Germany
State: OTHER
Post #2
I am doing my head gasket and timing belt. You need a three jaw puller to grab the inside of the balancer, not the outside, you will just seperate the pulley. You also need the insert that goes where the crankshaft bolt normally goes. This way the puller has a place to push from. I just used a long punch, but you have to be careful not to damage the threads inside. After you get that far, you might realize that to get it the whole way off, you will have to pull the engine. It doesnt say that in the book/alldata, but Im dealing with that now. Hope this helps.
aaronc2.4
 Posted: 07-21-2006, 09:58 AM
Post #3
No the engine does not have to be pulled, if you place a jack with a block of wood on it under the engine and take the passenger side motor mount off, the engine will swing down enought to get the balancer off. I just finshed a head gasket and timing belt on my 2.4L it's not to bad of a job.
Need Help 2000 Stratus Fuel Guage /loud noise jk12 Stratus 1st Gen (95 - 00) 0 09-06-2005 01:55 PM
2000 stratus running awful robccx Stratus 1st Gen (95 - 00) 1 02-07-2005 11:46 AM
2000 Stratus Transmission Problem - driving me insane! dave_echidna Stratus 1st Gen (95 - 00) 0 12-01-2004 01:47 AM
2000 stratus: fan on the motor not coming on temp. gage doensnt read hot though boxx Stratus 1st Gen (95 - 00) 2 05-25-2004 06:10 PM
2004 Dodge Car Highlights RAM MAN Chrysler LLC Press Releases 0 08-01-2003 03:38 PM
