Get the very most out of you neon (secrets?) - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 38 Old 12-21-2005, 04:34 AM Thread Starter
n-gin
n-gin's Avatar
Thumbs up Get the very most out of you neon (secrets?)
Stage One -- The BasicsNeons ('95-'99) suffer from a poorly designed, from a performance standpoint, air intake system. Performance, for a relatively small amount of money, can be improved by installing a K&N Filter. They are available both from Mopar Performance and your local auto parts store. Usually found for about $30, its worth about a 3-4 hp improvement over the paper filter. Owners have reported an "aggressive" sound coming from the engine (by removing the top of the air box on 2000-up Neon). If you are thinking about any modifications, you should start here first. (Note: for '97-'99 owners, I would not remove the intake scoop from the engine compartment of your Neon, unless you like that "open element" filter noise. You don't gain any performance from removing it, only a filter that gets dirty faster)
For a 2nd generation Neon, the air intake resonator should be removed at this time. It doesn't hurt performance or cause anything to happen. Its main function is to reduce intake noise for non-enthusiast. If you're reading this page, you don't need it. I have personally gained 3hp over stock with a K&N filter and the resonator removed.
If your Neon has more than 60,000 miles, then you should also replace your plugs and plug wires. Stock OEM wires are 7mm, which isn't bad. You can replace them for around $25, but for a little more MP 7.5mm competition wires are a better choice:
P4876546 1995 2.0L SOHC
P4876510 1996-2001 2.0L SOHC
P4876511 All 2.0L DOHC
Magnecor wires are considered by many to be the best ignition wire you can buy. I would consider these if you don't mind paying a little more money:
PN#40223 - 1995-1998 SOHC (#45223 for 8.5mm)
PN#40381 -- 1999-2001 SOHC (#45381 for 8.5mm)
PN#40231 -- 1995-1999 DOHC (#45231 for 8.5mm)
Crane, MSD, Accel and Moroso are available for both SOHC and DOHC engines. Check with the manufacturer for availability.
There have been many debates over the years about which spark plugs work best in Neon engines. I suggest the OEM Champions (RC9YC) for anything but the highest boosted or nitrous injected engine. NGK FR series plugs seem to work well also, but tend to "die" quicker and need repeated changing. Good for boosted cars and nitrous oxide however.
For those that have a little more money to burn, the best upgrade so far dollar for dollar, is a CAI (short for Cold Air Intake). These are the best available on the market:
ICEMAN Competition Intake (All years)
AEM Competition Intake (All years and SRT-4)
Mopar Performance Cold Air Intake (ICEMAN, '95-'99 only)
K&N Generation 2 FPK kit ('95-'99 SOHC only)
Volant Cold Air Intake (2000-up)
Injen Racing Division Intake (2000-up)
All these intakes carry a CARB E.O number, which makes them legal for use on smog control vehicles. There are some others out there such as the Kirk that requires the relocation of your stock battery and doesn't carry a CARB number.
*If you're serious about performance stay away from those chrome-plated "hot air" intakes
SOHC owners, you can add about 8-10hp from changing your muffler to a high-flow unit. Straight-though type mufflers work well for this application. This muffler design produces the best hp and torque numbers. It shouldn't cost more than $120-$140 installed. Also make sure your muffler size is around 24" or roughly the size of your stock muffler. This will keep the sound low enough for you to enjoy your exhaust without the police ruining your fun. If you live in an area where you get a lot of snow and salt on the road, I would really consider a stainless steel muffler from Dynomax (Ultra-flow), Magnaflow or Edelbrock (RPM series). Those that live in a more weather friendly part of the US , I would also consider the Flowmaster (PN#42452) or any other high performance BRAND NAME muffler.
I suspect that an even bigger improvement can be gained from installing a high-flow muffler on 2000-up standard Neon. The factory reduced exhaust pipe diameter from 2.25 inches on 95-99 cars to 2.0 inches on 2000-up basic Neon models. This change was made in an effort to make the current Neon appear more mature than the previous generation (i.e. quieter).
Instead of running down to your local muffler shop, you can always order a simple bolt-on rear section exhaust. 15-20 minutes and you're done!
1995-1999 (SOHC/DOHC)Thermal R&D (PN#M501)
Ravin (PN#VP1706)
Borla (PN#14856)
Brospeed (PN#248-315)
Genie (PN#413194)
Vibrant (PN#1706)
Mopar Performance (PN#5249861)
2000-up SOHC (not including RT/ACR models)Ravin (PN#VP1718)
Brospeed (PN#112-262)
Vibrant (PN#1718)
Mopar Performance (PN#5007559)
* Thermal R&D, Pacesetter and Borla (also offered though Mopar) make a cat-back exhaust for 2000-up Neon. They all feature new 2.25 piping. R/T and ACR Neon already have a 2.25 exhaust system. ÊThermal & Borla (though Mopar as well) have rear section systems for these cars.
The reason I left DOHC owners out of this is because you already have a nice muffler from the factory; thank Dodge for wanting a good exhaust system for the stock classes in SCCA Showroom Stock competition. If you can find one, cheap, it's a nice upgrade for SOHC Neon also. DOHC owners should move on to Stage 2 upgrades before changing the exhaust.
For weekend warriors that drag race, Neons are known for suffering from wheel-hop during hard acceleration from a standing start. If you want to knock-off about .2-.3 tenths off your ET and another .3 tenths off your 60 ft. times, try the MP Motor mount (P5007027-All) and Bobble Strut (P5007028-All).
The new motor mount is stiffer than the OEM unit, but still can suffer from tearing. To combat this and to further stiffen your engine mounts you can install these inserts:
Prothane Motor Mount Inserts (The mounts are available in red or black):
PN#4-501 Front mount
PN#4-502 Right mount
PN#4-503 Rear mount
PN#4-1901 All three mounts
Engine mount inserts are also available from:
Energy Suspension
Rex Inserts
Your final option is to fill your mount(s) with various hard compounds. Click here to visit his instructions. Deyeme Racing makes filled motor mounts in varies stages of stiffness.
2000-up Neons don't suffer as badly as 1st generation Neons do. You can still get some wheel hop. To prevent this Energy Suspension and REX inserts are available.
This is by far the best low cost modification you can make to your Neon. Wheel hop is prevented and the stiffer mounts allow smoother, crisper shifting. You also gain a more "solid" feel under braking and cornering. The additional vibration is well worth the improvement in performance.
With these modifications, I've seen many SOHC and DOHC Neons in the low 15's in the 1/4 for less than $500!
Not bad, huh? Now go scare some 4.6L SOHC Automatic Mustangs ('97-'98) and some of those pesky imports! Up next is part two.
Stage 2 - bolt-on modificationsWith the stage one completed, you should be making around 118+hp at the wheels with the SOHC ('96-'99 will make slightly less in some RPM ranges do to the camshaft change after the '95 model year) and around 122+hp at the wheels with the DOHC. More importantly your torque should be over 120lbs at the wheels.
These modifications are a little more involved, but not beyond a good novice mechanic:
Adding a larger throttle-body from an automatic transmission Neon (52mm vs. 49mm) or boring your stock throttle body out will help boost output on a DOHC Neon by about 5 hp or more across the whole RPM range. RC Engineering and Howell Automotive can bore your stock throttle body out to about 57mm. You can also purchase billet throttle bodies from Modern Performance up to 60mm. Having a throttle body too big can hurt overall performance, so unless you seriously changed the air flow characteristics inside your engine, I wouldn't use anything bigger than 55mm throttle body.
Gary Howell wrote:
"49mm TB flows 252 cfm
52mm TB flows 283 cfm
55mm TB flows 317 cfm
60mm TB flows 377 cfm
At 8200 RPM a 122 cubic inch engine will need 290 cfm at 100% volumetric effiency, using the formula ((Max RPM/2)*Displacement)/1728. Rule of thumb is to go 10% over because a naturally aspirated engine can go above 100% volumetric efficiency because of cam overlap, header design, etc. Go above that and you kill low end because of reduced velocity, go below that you starve the engine for air at top end. 110% is volumetric efficiency is 319 cfm."
Based on this, 55 mm does seem to be the option for naturally aspirated (non-turbo) engines.
As for automatic Neon throttle bodies, you can find them easily at most junkyards for around $70 or less. When you perform this swap be sure to replace the new throttle body's sensors and cams with the ones from your stock unit, if you want to retain stock drivability. You also want to pay attention to placement of the throttle-body on the manifold. You might gain a little more if you push it closer toward the center of the intake manifold. Make sure you port-match the throttle body to your intake manifold for best performance.
In the past I have stated that this modification helps DOHC owners the most and should really be avoided by SOHC owners. I have recently learned that a 57 mm throttle body on a mostly stock SOHC Neon gained about 5hp overall. Again, you really need to port-match throttle body to the intake manifold for best performance. That seemed to make the difference from before when the average was about 1hp over stock.
*A full story and dynojet results are available at Sport Compact Car magazine
Under drive pulleys have been used on V8s with success for many years. No reason why it wouldn't also work on a Neon right? Using one of these releases drag causes by your water pump and other accessories. By slowing down your accessories you gain hp and torque. It's really noticeable off the line. The increase in horsepower and torque is dependant on how much power the engine was making in the first place. The more power you have, the more effective the pulley. On mostly stock SOHC or DOHC engines however, the increase is about 5-7hp depending on model year
Here are some under drive pulleys on the market:
Unorthodox Racing
A/FX
TTI Racing
Mopar Performance
RVM Performance Products
Auto Specialties Performance
For serious racers some of these pulleys are available for single belt use, which would only turn the alt. For those that want the best of both worlds can get an Unorthodox Racing convertible Street/Race pulley (PN#30100100). The center pulley comes off for racing and can be re-installed when you're ready to drive home.
Another area that can be addressed on the DOHC engine is cam timing. Seldom does the factory use the optimum centerline the cam(s) need when building the engines. You can index them yourself for next to no money with a simple degree wheel, but I've found that cam sprockets make life a lot easier. They are marked clearly and are easy to adjust quickly, unlike the factory cam sprockets.
Here are the available cam sprockets: (The SOHC sprockets work on 2000-up Neons)
AEM
Unorthodox Racing
Fidanza Flywheels
Crane
Speed Lab Racing
(Again for serious racers Unorthodox makes a lighter version of their sprocket)
AEM has tested their cam sprockets on a DOHC Neon, which also had the AEM cold air intake and a prototype of then new Mopar Performance exhaust system. Before the cam sprockets, this DOHC Neon made 124+hp at the wheels. After the sprockets were adjusted for 4 degrees retarded (on both cams), the Neon responded with 131+hp. But that's not all...
The DOHC engine instead of falling on its face after 6500 rpm pulls up to Redline strong! With this setting it made more power from 4750 to redline than the stock cam timing did. You might not get the same gains on your Neon, but it's worth looking into.
With your Stage One modifications and the few upgrades here, your DOHC Neon should be in the 130+ area and maybe as high as 140 hp at the wheels. That's about 150 hp, the factory rating.
*DOHC owners - Want 12hp the easy way? All you need is a stock automatic Neon throttle body and some elbow grease.
Starting with only new plugs and a K&N drop-in filter -- 114hp and 111ft of torque
We added the automatic throttle body and got -- 120hp and 113ft of torque
Finally we removed the AC/PS drive belt from the stock pulley. Result -- 126hp and 117ft of torque
If you gasket-match the throttle body to the intake manifold, you'll gain a bit more. See how easy that was?
*These are repeatable results and done in the heat of the day at SHO Shop in Huntington Beach , CA over 4 years ago.
I haven't forgotten about you SOHC owners... Being one myself (four times over), I searched for some easy and cheap gains for us too.
Installing a cam sprocket is only worthwhile if your stock cam timing wasn't correct to begin with. It should be set at 110 degrees straight up. The DOHC engine is more sensitive to cam timing. You might want to check to see if your OEM cam sprocket has skipped a tooth. I would only do this if I were going to replace the timing belt (DC recommends 100,000 miles).
Adding a header is the next logical step and is worth about 4-6 hp. Most of this power is added to the mid-range and top end of the rev range. Currently the only CARB legal headers on the market come from Mopar Performance (street header- P5249856 SOHC, P5249973 DOHC) Borla (2000-up) and Hedman (uncoated PN#36050-DOHC #36060-SOHC). Pacesetter also makes a header, but is not smog legal in some states. Check with your local smog inspection station before purchasing this header.
Most of these headers require a minor modification to the exhaust pipe, but can still be installed in about 3-4 hours.
A few Neon owners have opted to have their header ceramic coated by Jet-Hot or HPC, it's a worthwhile investment that saves headers from rusting and improves there performance. Hedman and Pacesetter also offer coated versions of their headers.
To take full advantage of your Stage 1 and 2 modifications, pickup a Mopar Performance PCM for about $200. These replace your OEM power train module, are emissions exempt in all 50 states and require the use of 92-93-octane premium fuel. The rev-limit is moved up (about 7200 in the SOHC and 7400 in the DOHC engine), along with more advanced timing that improves low-end torque and throttle response.
SOHC Manual Transmission P5007033 1995, P5007035 1996, P5007037 1997-99
DOHC Manual Transmission P5007034 1995, P5007036 1996, P5007038 1997-99
Kenne-Bell offers reprogramming of 2000-up Power train Modules for $395
*One 2nd Gen Neon owner has complained of not getting what he wanted for the price he paid. Kenne-Bell offers a money-back guarantee. But you should be COMPLETELY clear about the changes you are requesting. So changes may require the car to be present during reprogramming. If you want just a basic upgrade, I recommend you request the fuel curve modified, bump the rev-limiter to 7200rpm and adjust the timing for 91-93 octane fuel, depending where you live.
A/FX Manufacturing also sells reprogrammed PCMs for all years, except 1995. They are available at Howell Automotive, but are not smog-legal. It gives you all the features of the Mopar units and produces a little more hp in upper rpm range (mainly from even more timing advance). There are race only versions available with more advanced timing and ignition curves. They are available for '96-99 DOHC and SOHC Neons. The Race version is just that because it allows you to remove your catalytic converter and requires the use of a header for best results. Some people with the "street" A/FX computer say they have passes smog with the unit installed, but I don't think the extra 2-3hp the A/FX makes over the Mopar is worth the additional cost. But it's up to you….
*It is rumored that A/FX will release reprogrammed PCM for 2000 models only
All of these modifications could be installed in less than an afternoon. At this point SOHC powered Neons should fall around 125-130hp and DOHC Neons should fall between 130-135hp at the wheels. With some minor weight reduction and drag radials high 14's are not out of the question for DOHC Neon. For SOHC Neon however, you need a little more help.
The next roundFor your next round of modifications if you own a DOHC or '96 SOHC with an aluminum intake manifold, I would recommend having your cast intake manifold modified by GUDE/Bullfrog Racing or any competent cylinder head service. It should run around $200 for port-matching and smoothing out the casting as much as possible without cutting the manifold. If you haven't got your throttle body done yet, then you can get it bored and port-matched to the intake for an additional cost. This is good for those handy with a Dremel or similar tool and for those on a limited budget. You can also make some of the same modifications to the composite (plastic) SOHC intake manifold with less dramatic results.
The Extrude Hone process works great on cast aluminum Neon intake manifolds. Air flow testing of a stock intake should be around 810 cfm. That's with most of the casting "flash" taken out by hand. After the Extrude Hone process, that same intake pushed out 1013 cfm. What's so great about the EH process is that it can do what human hands can't, which is port/polish the entire intake manifold's upper runners and make air flow in each runner as even as possible. Before EH process, the manifold showed various cfm readings from each intake runner. Each runner varied as much as 10%. After the EH process, all runners where within 2-3cfm of each other or less than 2%.
Both types of modifications made to these manifolds give you much improved low-end torque and throttle response and allows more power (the hand ported manifold to a lesser degree of course) to be made beyond the original 6500rpm "flat spot" in DOHC Neons. With either manifold, the torque band was much wider and flatter. The DOHC engine now wants to scream on the top-end! You get strong pull right up to the fuel cut-off (7200 rpm). This is a very worth while modification for any DOHC Neon. A few cars with this and some of the modifications listed earlier are making well over 130 hp or 150+ hp at the flywheel (most falls into the 132hp -138hp area at the wheels).
This IS the "real" bottle-neck in the prevention of gaining additional hp from the DOHC engine. Combining Extrude Hone with traditional hand porting works even better!
The next roundThis is where the gains from bolt-on performance stop. Some of the parts or modifications mentioned here might be beyond the novice enthusiasts but are still considered Stage 2 modifications.
Changing the camshaft(s) is the next step. Stock Neon camshafts are very mild when compared to other engines in its class. More aggressive cam timing is needed to take full advantage of the 420a's well-designed DOHC cylinder head.
Crane makes excellent camshafts for both engines.
For internally stock engines I would recommend:
PN#158-0010 for SOHC engines
PN#180-0010 for DOHC engines
Crower makes excellent camshafts, but for DOHC engines only.
I would recommend this grind for internally stock engines:
PN#64450N
The other grinds require increased compression and additional work on the cylinder head. If you don't plan on any further modifications to your engine I would stick to these camshafts.
SOHC owners might be lured by the turbo grind specs. Please read this very carefully --
The SOHC engine makes most of its power between 4000 and 5600 rpm. The stock camshaft makes peak power around 5500-5600rpm and then falls rapidly. Crane's non-turbo cam adds power across the rev range and extends power pass the stock peak. It also makes more power from 5500 to 6500rpm where the engine needs it most. Even with the rev- range allowed by the Mopar or A/FX PCM, the turbo grind makes most of its power well pass 6500rpm where the cylinder head doesn't offer any additional flow. It's simply the wrong choice for your application.
DOHC owners have another option here. If you plan on using nitrous oxide injection, I recommend Crane's: PN#180-0012 or Crower's: PN#64451.
Both these camshafts require upgraded valve springs due to higher lift. I don't recommend Mopar Performance Springs for aftermarket camshafts. They are great for stock or mild aftermarket cams, but once you setup to more serious camshaft, heavier springs are needed. Both Crower and Crane make upgraded valve springs. This would also be a good time to upgrade the entire DOHC valve train with PT Cruiser spec replacement parts. These lashes and roller rockers are much stronger than what came in DOHC engines during its production run in the Neon. If you upgrade your camshafts, do this FIRST.
We are now running into the limits of the stock cylinder head, intake manifold and short-tube headers. SOHC engines at this point should be around 135-140hp with DOHC engines checking in around 140-145hp. You can pick up some additional power by cleaning and balancing your fuel injectors. This process will allow each cylinder to produce the most horsepower by equalizing fuel flow.
For East Coast Neon owners -- Marren Motor Sports
For West Coast Neon owners -- RC Engineering
You can pick up 4-5hp for about $100. Not bad!
Neons are tuned to run conservative for non-enthusiasts. To get the most out of your modifications, you need some control over fuel flow and ignition timing. Aftermarket PCMs are tuned more aggressively than stock, yet still aren't tailor made for your car and the changes you have made. You need the power of these tuning tools to get the most out your changes.
Adding a Crane or MSD ignition will increase ignition output, but you cannot advance the ignition timing beyond what the PCM will also. MSD also makes a programmable version of the DIS-2 with fully programmable ignition curves, but you're still limited by the PCM. The stock ignition will do fine with internally stock engines. Installing an ignition amplifier will increase power between 3-4hp overall, allow the engine to run smoother and use a wide spark plug gap.
*For drag racing and Solo 1/2 both basic ignitions offer Stage 2 rev control for better launches.
Adjusting fuel flow can increase power by decreasing or leaning out the fuel mixture. This can be done two ways -
Manually with a fuel pressure regulator
Electronically with a fuel management computer
Using a fuel management computer like the Apex'i Super AFC, HKS Super AFR or Split Second ARC1, you have far more control over tuning that what an adjustable fuel pressure regulator will give you. On average you can pickup 6-8 additional horsepower using one of these devices. It also leaves the door open for any modifications you might make later.
You can also use a piggy-back engine control unit such as the Perfect Power SMT-6, UNICHIP, or Split Second FTC-1. These offer MUCH more control than a simple Super AFC does and adds the power of full ignition control, within the parameters of the PCM. You won't have the 2 stage rev-limit of a MSD or Crane ignition, but you gain more tuning power. [Note: Mariano Torres wrote that the Greddy E-Manage did not do much for spark control and could do some damage.]
Kenne-Bell can not only re-flash 2000-up Neon PCM, but also 97-up Neon as well. ASE replaces your soldered e-prom with socket version and can program ANY parameter you see fit into the PCM. This might be a good option for those that aren't looking to make a lot of changes later to their engine. Some tuning from either company might require the car to be at these locations. Plan on spending some time on a dyno near your home town and phone calls between you can KB or ASE if you want your car tuned correctly. Or expect you spend your PCM back at least once for an adjustment. Tuning with the factory PCM can be a pain in the ass at times. But if you gotten this far maybe you should forget this and consider what's next.
Stage 3 - Advanced Engine PerformanceWith both engines were at the crossroads of performance...
Monitoring engine performance becomes more critical at this point. You're tuning closer and closer to the edge of detonation to squeeze the last ounce of power from your engine. There a few ways to monitor what's going on while the hood is closed.
If you haven't installed at least Water Temp, Oil Pressure & Fuel Pressure gauge you're asking for trouble. You need the proper gauges to aid in tuning and to let you know of a potential problem with your engine.
Auto Meter
Defi
VDO
Faze
That's not the only way you can monitor your engine and its many sensors. The age of mini-computing has allowed us to leave the laptop computer at home and give a PDA another use outside the office. Since all Neons are OBD-2 compliant, you can use OBD-2 monitoring software. Several are available for downloading and you only need to purchase a cable for under $70 in some cases.
Here are some of the available programs:
EASE Diagnostics
Virtual Dashboard
Auto Tap
CJ-2 (Package Includes a Handspring PDA with software pre-installed)
This is the most advance way for you to monitor your engine function and sensors. It allows you to data-log your PCM while on the race track, dyno and erase codes that might come up during the installation of aftermarket parts. By knowing what code comes up, you can easily solve the problem. These have become very valuable tools in high performance tuning. I highly recommend using this type of software.
Programmable Engine Management:To get the most out of any modification you for here on, you need control of the ignition and fuel systems. For some of the heavy modifications, it might be best to step beyond the piggy-back systems that I listed earlier. While you can almost totally override control of the stock or modified PCM with piggy-back units or even go as far as having a new e-prom burned for the PCM. You'll end up spending more money and still not have the amount of tuning power available in units such as Electromotive's TEC-3. These should be considered if you're looking to make the most horsepower possible and yet still have reliable transportation. However in the process, you might loose several functions of the factory PCM. If you don't mind loosing such functions, then using one of these units will reward you handsomely.
The TEC-3 is one of several units available. Choice should be based on which unit your tuner prefers or what functions you're looking for. I recommend the following ECUs *
AEM
Haltech
Injec
DTA (TTI Racing is SUPPOSE to have a direct-plug version available)
Naturally Aspirated:
Blueprinting alone will pick up a few more ponies, but with the additional cost of machine work, I don't think it's worth it alone. I would do this in addition to what other changes that would be made to the engine while it was apart.
Depending on how far you go, you might be reaching the point where your OEM fuel injectors are not supplying enough fuel. If you have installed a fuel computer to help dial-in your bolt-ons from Stage 2/3, then you can also use larger injectors and not cause a "rich" tuning condition. The biggest injectors any factory or aftermarket PCM are 24lbs or about 270cc.
You need to increase your compression ratio to run any of the "hotter" camshafts that Crane and Crower (for DOHC Neons) offer. Increasing compression is also a fairly cheap modification and is usually a win-win proposition. The only downside to higher compression is using higher-octane fuel. The stock compression ratio in the SOHC engine is 9.8:1 and it's 9.2:1 in the DOHC. 11:1 is a good compression ratio for either engine if you plan on running it mostly on pump gas. You might need to install an MSD or Crane ignition if you haven't already. Detonation is bad for any engine. Even a bad tank of gas can spell doom for your modified engine. These ignitions can prevent this by allowing you to retard the timing a few degrees. In most cases you'll only retard after 4000rpm in both engines and only about 2-3 degrees at the most. Using a Piggy-back control system or Stand-Alone engine management will give you more tuning options. You can always leave the Crane or MSD box for its 2 Step function.
For a really hot street engine, 12:1 compression is ideal. At this point I would consider replacing your stock pistons with better units from KB. Hypereutectic pistons are stronger and lighter than cast pistons, although not as strong as forged pistons. They also cost less than forged pistons or brand new replacement pistons from the dealer. This can provide a solid foundation for your high output engine. You also don't have to mill your head any further than .050 with a 10.8:1 piston. This will achieve close to 12:1 compression. You will now need either programmable engine management or an aftermarket ignition to fire your high compression engine. You'll have to run about 5-6 degrees of retard to keep your engine together, but for the money it's a solid power increase. Forged Pistons can be used also, but are a bit "loud" during cold start up and tend to burn more oil than cast or hypereutectic pistons. If you don't plan on turning your Neon into a track-only car, the KB's will do the job.
ÊElectromotive's Neon TPK system is no longer available. But you don't need individual throttle bodies anymore to get max power on the street. INDY Cylinder Head of Indianapolis , IN has come to the rescue of Neon owners everywhere and provides the final piece in the puzzle to ultimate Honda kill 'in horsepower. This brand new cast manifold fixes EVERY problem with factory Neon intake manifolds, short of the Magnum intake available with '01-03 Neon R/T and '01-'02 Neon ACR. You loose nothing with this intake and the only thing better is individual throttle bodies, which aren't really meant for the street anyway. Combined with a 60mm throttle body, I think you'll be hard pressed to find something that would outflow this combo. The best part this manifold is affordable! If you're serious about getting BIG power numbers get this intake! More details about this manifold in the next update as all versions are not available just yet.
SOHC Owners -
Once considered the "redheaded" stepchild in the world of Neons. The SOHC engine has had the last laugh. Besides the new SRT-4 turbocharged Neon, the SOHC engine is the only other engine available. The DOHC was axed for budgetary reasons. I've been trying to tell people for years that everything being equal, the SOHC can provide just as much power as the DOHC engine. The parts are now available to make 180-190hp without any additional machine work or cylinder head porting.
180+hp SOHC Recipe *
11:1 or 12:1 compression (aftermarket pistons needed)
Magnum SOHC Cylinder Head or Ported standard SOHC head
Crane 0014 or 0016 camshaft & matching valve springs
INDY Intake manifold or Magnum Intake manifold
Long tube header (Phatridz, Blackdog or Hytech)
Reprogrammed PCM combined with Piggy-back engine control or Stand-Alone engine management
More power is possible. On record there are at least 3-4 daily driven SOHC Neon making over 180hp at the wheels. I have seen only one dyno sheets to prove this, but Nate Greer has blasted 13.6@102! Very few DOHC have run faster trap speeds. This truly impressive and we have only just started to see the full potential of this engine. The revenge of the SOHC is on!
DOHC Owners -
DOHC Neon on the other hand doesn't really need a ported head to reach 180hp. Running 12:1 compression, Crane/Crower cams, INDY intake manifold and some tuning are all that are needed. You can reach 200hp a lot easier now that the INDY intake has come on the scene. You might need additional cylinder head work to get up to 200hp, but it can be done and still be very streetable.
*For the 2003 season Scot Mohler is a member of Darrell Cox Racing and Team Mopar! He took the 2002 NOPI Pro Stock title, finished 4th in the NHRA Pro Stock class and ran a limited schedule in IDRC and IDRA ( Battle of the Imports). He managed to win for the 2nd year in a row at the IDRC event in San Antonio . His Neon now features a custom Individual Throttle Bodies, Cold-Air induction, 2.7L DOHC DCR engine, alcohol injection, special Crane race grinds and a lighten chassis. His Neon is still overweight for the class by about 200lbs but an all-new car is coming sometime this season. Stay tuned because Scott is heading for the 9 second zone. Bow down to the World's Fastest and Quickest N/A Neon!
Exhaust Systems -Short-tube headers are not great horsepower producers. The Neon engine needs a real header. A properly designed long tube header for either the SOHC or DOHC engine is worth over 12hp on an otherwise stock engine. There are two on the market current. The Kirk Racing header is an older design but still produces good power numbers. However the Phatridz and Hytech header are the best choice.
*Some of maybe think, "How come you didn't suggest this earlier?" It's because NONE of these headers are smog legal and to get the most out of them, you really need to use some bigger camshafts and ported cylinder head. These are purely racing headers.
This is also where your stock 2.25" exhaust piping becomes an obstacle in the quest for horsepower. There are a couple of cat-back exhaust systems for Neons available.
Dynomax
Pacesetter
Rhino
Flowmaster
Unfortunately, these exhaust system come with outdated turbo style mufflers. The Dynomax cat-back is by far the most popular exhaust for Neons and uses I think the best of the turbo style mufflers (Super Turbo) but if you were serious about power output, I would use the piping (2.5) and use a better muffler like a Dynomax Ultra-flow, Edelbrock, Magnaflow or some other type of straight-though muffler.
For more information on building a high horsepower SOHC or DOHC engine --
Neon Specific Tuners:
CNNP Racing
Howell Automotive
Forward Motion
Modern Performance
Turbochargers -
There are a few Neon turbo kits available now. They are available for both SOHC and DOHC engines from -
Hahn Racecraft (95-99, 2000-up coming soon)
Turbo Performance (95-up)
Blue Ribbon (95-up)
CNNP Racing (95-up)
Turbo manifolds are available from Turbo Performance, CNNP and TTI Racing if you want to design your own turbo system.
You can run between 8-12psi on a stock Neon engine if the proper precautions are taken. If you buy one of these kits, slap it on your Neon and run 12psi, you'll sure to break something sooner if not later. At the VERY minimum, this is what I would add to my turbo system --
MSD or Crane ignition (to retard the timing under higher boost levels)
Electronic boost Control unit (Blitz, HKS, Apex'i or Greddy)
Clutchmasters Stage 3 clutch or something similar
Driveshaft Shop Stage 2 axles (Drag racing? Get Stage 3's!)
Dynomax cat-back intermediate pipe and straight-though muffler ('95-'99 Neons only)
Upgrade your blow-off valve if you're using a Hahn kit
Adding these will add to the life and performance of your turbocharged Neon.
Len Ayala's (first) Neon is one of the fastest in the world with a top time of 9.55@150 He still uses the same exhaust manifold from the Hahn kit only with a 20G turbocharger on his 2.4L DOHC engine. His Neon also features a unique induction/intercooler system. Now that his first Neon is no longer a street car, he purchased another Dodge Neon for street duty. After putting the finishing touched on his new street Neon he took it out to a local Import War event. He made it all the way to the final round. His best ET of the day was 11.97@121 making his new car one of the fastest street-driven Neon in the country! Great Work Len and Hahn Racecraft!
Darrel Cox currently owns the fastest and quickest Neon in the world driven by Mike Crawford at 8.56@163mph. He built the 2.4L DOHC turbocharged engine at his own shop, Darrell Cox Racing. The engine is controlled by F.A.S.T engine management system. He also built the 2.4L turbocharged engine found in former Ford Focus racer Shawn Carlson's New Mopar Dodge Neon.
Team Mopar is poised to BIG things this season. They will be running the whole NHRA schedule, so look for them at a track near you!
Nitrous Oxide -
Many people think using nitrous oxide as cheating. While I won't jump on my soapbox about this, I will say that more and more Neon owners are looking toward the "throttle in a bottle" for cheap performance. You can run anywhere from 50hp-100hp on a stock Neon engine in good running condition.
A 50hp shot on a 5spd stock SOHC or DOHC Neon will run high to mid 14's on street tires easy. If you could use it in first gear, you should be able to get low 14's. To do that, you need slicks. On a '96 and later Neon you'll need to upgrade the clutch to use slicks and nitrous together (when using more than a 75hp shot).
With only Stage 1 modifications and a 75hp kick from nitrous oxide, you can have a very quick car for less than $1,000 invested.
ÊJust to show you how effective Nitrous can be, Scott Kornish with an internally stock 2.4L DOHC engine, Stage 2 type modifications and Crane cams, makes about 160hp at the wheels and runs mid 14's at around 93-94mph in the &Mac185; mile. Add some slicks, Nitrous Express Maximizer progressive nitrous control unit and a 100hp shot of nitrous oxide, the results? 12.4@108mph. Not many turbo Neon run that quickly and just goes to prove that nitrous-oxide can be the answer in your quest for big horsepower.
Nitrous kits range from $400-$1300 and they come complete. But you need to add a couple of options to have a safe, yet very quick system. A Neon Nitrous FAQ is being constructed and will be available soon.
There are four Neon-specific nitrous-oxide kits available -
Nitrous Express Neon EFI kit
Nitrous Works Neon EFI
Nitrous Oxide Systems Neon EFI kit
Venom VNC-1000 and 2000
All things nitrous-related can be found here -- http://www.n20.org/
*Both of the world's fastest Neons use turbo charging and nitrous injection
Going 2.4L!Everybody thought it was possible. Everybody said it could be done, but nobody has tried to until about 8 months ago. Now it's one of the hottest topics on neons.org. Yes! You can swap a 2.4L DOHC cam engine into the Neon. What are the advantages? More cubic inches, more torque and almost all the 2.0L DOHC parts work making it one of the easiest engine swaps around. One of the best ways to get more power is to increase engine size. By adding almost half a liter to the 2.0L DOHC engine, it gained over 30 addition pound feet of torque and only lowered the rev-limit by a little.
Swapping in just a 2.4L DOHC engine into DOHC Neons will drop your ET's into the low 15-second area. All of the performance modifications that work in the 2.0L work even better in the 2.4L engine.
The 2.4L is also ideal for racing. Darrell Cox's 8-second turbo Neon uses a 2.4L engine. Scott Mohler uses a bored 2.4L DOHC engine in his ACR this season and with further tuning and changes from last year makes almost 300hp at the wheels.
Swapping the 2.4L is still fairly new, so if you're considering this swap, Dodge Specialist makes a kit making installation a snap. TTI Racing also offers the special passenger mount spacer needed to install the engine. Currently this swap only works in '95-'99 Neon with the DOHC engine. SOHC owners can make this swap also, but you need to find a DOHC PCM and all the other necessary bits needed to make the swap possible.
The 2.4L engine bolts right into the PL2000 (2000-up) Neon chassis! Just go to your local Dodge/Chrysler dealer and request a full set of Neon SRT-4 engine mounts. Then compare them with your current 2.0L SOHC mounts. Change what's needed and a PT style engine should fit without any problems. However, the new problem is how to control your new engine. You might be able to use a PCM from the same year PT Cruiser. This is still being researched. When a full answer is known, I'll post an update ASAP. I'm sure some would still rather opt for 2.4L DOHC power over the underdog SOHC engine. But given the extra weight Neons picked up with the 2000 year model change, it's understandable.
If you have any of these modifications, we would like to hear from you and so would many other readers of this page. You can contact either the Webmaster or me. So far I'm very disappointed. Nobody has sent in any suggestions or comments about the changes they have made with their car and share them with others. Please if you have done some of the things listed on this site, we would like to hear from you.
Next update I'll finally add that Suspension Tuning Guide I have been promising for awhile now. I might also be able to give you a look into what it takes to make a Dodge/Plymouth Neon competitive in Street Touring auto-cross Neon. I'll also add that Automatic Transmission build up guide. A lot of things have changed since I have started writing this page. I have had 3 Neons since then and I am currently without Neon again. Don't worry, though a final decision hasn't been made, there's a strong chance I'll be getting yet another Dodge Neon. I won't tell you what model or what year though.
Illustrationsallowen.gif shows Owen's DOHC ACR after all the mods listed on the dyno sheet
barryrun.gif shows the gain with the under drive pulley
scottsrun.gif is his first run (222 hp)
scottsrun3.gif is the 228hp run
Linkshttp://www.turbosystem.com/Neon/World_s_Quickest/world_s_quickest.html - Neon turbocharger kit
NeonSpeed
Swain Tech High Performance coatings
Jet Hot High Performance header coatings
Other Neon links with more performance info - investigate before you upgrade!
NavigationReturn to the Neon Page
Neon IRC (chat) page
DRIVE SAFE AND GOOD LUCK
Parma Heights, Ohio
2002 Durango 4x4, 4.7 w/tornado, K+N, 3.92 gears LSD, T/S lift of 2.5 inches. R\T rims Cooper tires.
2005 Neon Electric Blue w/SRT sway bars tint on front and side widows. 2 Rockford Fosgate 12 inch subs fiberglassed in the spare tire holder. JL Audio 6x9 in rear deck, Cadence 6.5 3 inch voice coils in front doors. Three separat apms for each pair of speakers. Fully insulated body with Rubberized under coating, Rammat and insolight. 149.8 SPL. Two 1200 Kinetic capacitor batteries.
2005 neon Flame Red w/tint on side
I also work full time with the state of Ohio Department of Transportation.
n-gin is offline
post #2 of 38 Old 12-21-2005, 05:33 AM
RadarLove
Ummm, a link to www.allpar.com/neon/performance.html would have been sufficient. A link to http://pages.cthome.net/rader/disclaimer.html would be better (even though it needs even more updating than Anthony Thomas' version)
RadarLove is offline
post #3 of 38 Old 12-21-2005, 01:08 PM
dodgeneonACR98
So whats UR excuse?
I thought that looked like an allpar site LOL.......I agree Radar BUUUUT !
I give n-gin mad props for his time and shit that he spent to help out some of the less Educated people on here.( Newbies that is). Most of us already have most of the bolt on's already and know where to go next but that is some god info non the less.
Squad member #53 [/url]
04 Neon SRT-4
98 Neon ACR-2.4 swaped with goodies
dodgeneonACR98 is offline
post #4 of 38 Old 12-21-2005, 04:57 PM
rice_eater
LOL I'm not makin fun of you n-gin. Its awesome that your out there diggin for info, its just that most (if not all) of us have already read through that particular site. Good job finding quality info though. Is it just me, or does anyone else think allpar's HP estimations seem a little low? Not so much the gains from the mods, but the WHP... I thought stock DOHC MTX neons put down close to 125hp to the wheels? or are they running they're tests on ATX cars?
'97 Neon DOHC MTX - Sold
'98 Neon DOHC MTX Turbo - Sold
'99 Neon DOHC MTX - The project begins...
rice_eater is offline
post #5 of 38 Old 12-21-2005, 05:42 PM
HoodooGuru
HoodooGuru
Whp rates look way low!
Look wrong to me. But hey Im prob wrong!
2001 Chrysler Neon SE.
Performance Mods:
Pedders Sports Ryder Lowered springs, CSA "Velocity" 15 inch alloy wheels & Toyo T1R-D low profile tyres, 2.5 inch cat back Lukey Turboflow exhaust, Highflow cat, Comp 200 Grind Camshaft, Race Spec P & P Cylinder Head with 3 Angle Valve Job & Decked 20 thou, Universal Polished Chrome Oil Catch Can connected to pcv valve, MPX 60mm polished aluminium throttlebody, Cold air intake, Cquence Motorsport Cross Drilled / Slotted Front Brake Rotors, Racing pod air filter, Quick / short shifter, Custom mid / long tube headers, Megan Racing underdrive pulley, Top Gun 8.0 high temp spark plug cables, NGK spark plugs, SPW Billet aluminium front strut brace, over bored 40 thou with 10:5.1 high comp pistons, lightened machined crankshaft, new conrods, ACL race spec bearing / rings kit, Fuelstar Fuel Catalyst, Nolathane front control arm bushes, Gripforce Sach Stage.1 racing clutch, Sparco fuel pressure gauge under the hood, Bendix "Ultimate" brake pads, dyno tuned with a Unichip piggyback ecu.
Future Mods:
Custom Box Style Intake Manifold & a Crane 14 camshaft / magnum valve springs.
External / Internal Mods:
Full viper body kit (As sold in Australia), Chrome mesh intake grille inserts, Sirius Plus 2000 55 watt driving lights, SCA Shift 55 watt spot lights, Boschmann 550 watt 6x9s, Roar RX-8 250 watt sub / amp cannon, Crack Hi / Low RCA Converter, Full tint, Autotechnica "Monza" leather gear shift, Isotta Taladega Race / Sports seats, 2x SRT4 turbo gauge pods with Splitfire oil pressure & air / fuel gauges, Splitfire volts & oil temp gauges mounted under the radio, Gold painted calipers, And a mighty MOPAR sticker!!
HoodooGuru is offline
post #6 of 38 Old 12-22-2005, 03:07 AM
dodgeneonACR98
So whats UR excuse?
I never thought one time that they were low.
You have to remember this. Your peak HP at the peak RPM isn't were most mods are going to put EXTRA HP. 125 ish to the wheels sounds kinda high to me for a stock car.My car came stock with 150 hp dohc mtx.(said so on window sticker) it also said that 93 octane or higher had to be used to obtain the whole 150 HP.Wish I could find that. It was the original dealer window sticker the one with the list of options/gas mileage and what not.PRICE TAG
BEFORE I am Hounded I know the 150 hp was to the FW.
Anyhow take the % of drivetrain loss and figure it out. 150 HP X some % or however the hell you do that shit.
Most modifications are just putting the horespower you already have to better use. They add hp to different rpms alittle here a little there, some does go to the peak but most of it is just helping you to get there faster.
04 Neon SRT-4
post #7 of 38 Old 12-22-2005, 04:15 AM Thread Starter
n-gin
n-gin's Avatar
Talking
That is an allpar site I got that from. I didnt see it mentioned in previous posts so I just thought I would hang it out there .
I've been browsing and you guys have done a lot to your cars. They look good too. I just bought my first neon 2 months ago. I'm looking for places to buy seats from a R/T, but no luck so far. If you guys have any ideas let me know.
Parma Heights, Ohio
n-gin is offline
post #8 of 38 Old 12-22-2005, 12:08 PM
dodgeneonACR98
So whats UR excuse?
N-GIN, Im not sure but NEons are all over the place they are everywhere, This leads me to believe that they should be in junk yards crashed just about everywhere.
Im not sure if the R/T's seats are like the ACR's or not but I like my ACR seats. Good luck finding an ACR in the junk yard tho. LOL
I don't know if your complementing my Car too or not but thanks for the props.
04 Neon SRT-4
post #9 of 38 Old 12-22-2005, 09:02 PM
rice_eater
DodgeneonACR98 - I'm going by the drivetrain loss as quoted by RADAR, 15%. That leaves you with 85% of your advertised HP hitting the ground. 150 (peak HP) X 0.85 (85%) = 127.5 ... MORE than 125. I just said 125 because most engines lose a couple HP over the years (2-5HP, depending on how it was maintained). So 120-125 HP would seem to be a very realistic dyno result on a stock DOHC neon, assuming Radar is correct on the 15% drivetrain loss.
Allpar says a DOHC neon will make 114hp and 111 lb/ft of TQ with new plugs and a new air filter (basically, a stock DOHC). That seems low to me, but they do have dyno charts to prove it. I'm just wondering if they were testing an ATX car.... (more drivetrain loss) or if neons have more than a 15% drivetrain loss, or if their particular car wasnt up to snuff.
post #10 of 38 Old 12-23-2005, 03:03 AM
dodgeneonACR98
So whats UR excuse?
RICE-------I was too lazy to look up that POST! LMFAO maybe I shouldn't tell that MMMMMM well.
I think different years may have had a little to do with it, different cams,tranny,ect.
Hell I don't know. It's possible it was an ATX. They do have higher rate of loss.
Sounds like it's time for RADAR to give us a sceintific explanation of this....YET ANOTHER INFORMATION PACKED POST. FULL OF TID BITS OF BRIAN SWELLING, GEAR JAMMIN, EAR SLAMMIN,BRAIN FOOD THAT FUELS OUR FIRE. laTeR !
04 Neon SRT-4
post #11 of 38 Old 12-23-2005, 09:46 PM
rice_eater
Yeah... RADAR! enlighten us please! cuz, heck... 114whp is like 22% drivetrain loss... last time i checked neons werent AWD, LOL.
post #12 of 38 Old 12-25-2005, 04:43 AM
RadarLove
Have to remember that the DOHC's were rated at 150 HP, but that doesn't mean they actually made 150 HP... Many had the cam gears set improperly from the factory and were coming off the line losing a good 5-10 HP because of it. Even then, 114 HP does seem a little low... Since most R/T's and DOHC ACR's were quite capable of running mid-15's off the showroom floor, I'd put them closer to the expected 125ish WHP range. 114 WHP on a loaded R/T would barely get it in the 15's... Don't know whose car Anthony was using on the dyno, all of his were SOHC's. My SOHC dynoed 111 HP to the wheels stock, right before putting on my first mod - a K&N FIPK. Last check (late 2004) was a little over 139 WHP on the best of 3 pulls, the other 2 were a smidge over 137 WHP, so that's what I go with.
AWD's can lose more than 22%... One of the guys up in NH got a new WRX, dynoed a little over 160 HP to the wheels bone stock, a good 15 Hp loss than his DOHC Neon at the time... That's closer to a 27% loss...
post #13 of 38 Old 12-27-2005, 04:09 PM
rice_eater
114WHP sound more like SOHC territory to me...
BTW... If I got to a Dyno, could i degree the stock cam gears, or would i need to buy adjustable cam gears? Just wondering... I suppose i should try and find a Dyno around here first....
post #14 of 38 Old 12-28-2005, 10:50 AM
RadarLove
You would need aftermarket cam gears, or you'd have to modify your stock ones (eliminate the key and slot the holes). Frankly, I'd rather go with aftermarket... and a modified timing belt cover...
post #15 of 38 Old 12-28-2005, 01:04 PM
rice_eater
My budget isnt allowing aftermarket gears, and modifying the stock gears sounds like a pain... I think i'll just hope mine are set decently from the factory. I know, I know, the budget racer cant afford to be lazy... oh well. Thanks for the info though Radar.
post #16 of 38 Old 12-29-2005, 03:08 AM
dodgeneonACR98
So whats UR excuse?
Hey: what Rice said in another post got me to thinking !!!!!!! YEAH OH BOY !
Thinking about the HP #'s. And WHY they seem low.
Didn't Radar say that the dynos were done with an ATX. Both sohc and dohc.
Didn't Rice say that the dohc mtx was at like 127. 15% of 150 right.
I think we can all agree that. The reason the Dyno's are so low on the for the dohc neon is becouse the ATX tranny is cutting it off well before PEAK hp is reached on the Dohc motor. 15-20 hp lossa depending.The motor is a 150 hp Dohc 2.0 but it cannot use the last 20 or so.Right Right???? So 114 hp to the ground on a Dohc ATX don't sound to far fetched does it. Makes secne to meeee. What do you ya'll think??
Later
04 Neon SRT-4
post #17 of 38 Old 12-29-2005, 03:53 AM Thread Starter
n-gin
n-gin's Avatar
Lightbulb
I believe you can pick-up a set of off set keyways for $10. All the adjustable gears do is give you the option of adjusting on the fly to suit your needs.
Parma Heights, Ohio
n-gin is offline
post #18 of 38 Old 12-29-2005, 07:35 AM
RadarLove
Don't know if the cars dyno'd were ATX or MTX...
post #19 of 38 Old 12-29-2005, 11:31 AM
dodgeneonACR98
So whats UR excuse?
Well if the cars were ATX's it would explain why the Dohc only made 114 hp to the wheels rather than the 125-130 that the MTX puts down.Just thought maybe I had an explanation for the seemingly low hp out put from Allpars tests.
04 Neon SRT-4
post #20 of 38 Old 12-29-2005, 01:01 PM
rice_eater
The cars were MTX and DOHC, i just checked the site. I know they are MTX cars because they list the ATX TB (52mm) as one of the mods. you wouldnt swap in an ATX TB if the car is already an ATX. and right above the paragraph it states, "DOHC owners, want 12hp the easy way"...
The only possible reason i can think of is that their cams were improperly set on the engine they tested and it was really humid the day they tested. (i think it says the tests were done in Huntington Beach, CA, so its possible) That combination is the only way I can see hp numbers being that low...
    Neon fades from view RAM MAN Dodge Neon - General Talk 0 09-19-2005 09:45 AM
    Lifting a neon? ExtremeODD Dodge Neon - General Talk 5 08-26-2005 08:40 PM
    neon question? Dude87 Dodge Neon - General Talk 22 09-29-2004 02:23 AM
    ... not your daughter's Neon RAM MAN Dodge Neon - General Talk 1 06-05-2003 02:17 AM
    '03 Dodge Neon info RAM MAN Dodge Neon - General Talk 5 09-20-2002 02:42 AM
