Front Blower stuck on high. - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 10 Old 11-29-2005, 12:02 AM Thread Starter
intrepid_es
I have a 2001 T&C. I hope nobody will mind that I am using this forum for information. The front blower is stuck on high. It does not matter how I set the controls (even turning off the climate control), it remains on high. When set to a particular temperature, it seems to blow the right temperature air. I think that it is probably the switch, but it might be the rheostat. The dealership say that the switch (which is part of the control head) is $300 and the rheostat is $99. So, here are my questions:
Can someone tell me if I have thought this through correctly and, in particular, which part needs replaced?
Whatever part needs to be replaced... is it a pretty easy job?
intrepid_es is offline
post #2 of 10 Old 11-29-2005, 01:05 AM
dodges 3
dodges 3's Avatar
I'm not sure of the name of the part. On my '95, it's located on the firewall, passenger side in the engine bay. Theres a flat plate about 2" high by 1" wide with a group of 4 or 5 wires plugged into it. Its this that controls the blower motor speed. I don't know what they are worth new, I had a parts van that I used to change mine. You could try local scrap yards also for the part. It might also be its wiring harness going into part, that is faulty. Good luck....
2000 Dodge Caravan 91,500kmm, 3.3V-6, Quad
1991 Dodge 150 Ram Van V8-318, 144,000miles, purchased may27/06 $980. cert. and e-tested, Bosch wires, MOPAR coil, Eagle Alloys with Cooper Cobra GT's, Power Accoustics DVD, CD Player
1989 Dodge 150 Ram Van, V-318, now a trailer.
1982 Dodge Ram Maxi 1 TON V-8 360, 3spd. Soon dually.
1986 Dodge 250 Ram Van 318 4spd. standard.
1991 PV 3.0l parts van now a trailer
*DodgeTalk.com Ram Van/Wagon Member #(3)*
*DodgeTalk.com 318 Enthusiast Member #(86)*
dodges 3 is offline
post #3 of 10 Old 11-29-2005, 01:36 PM
gas28man
This is the blower motor resistor. It's a dealer-only part, but only runs about $16-$19. Just go get a new one and don't fuss with a used one.
Good luck.
Rick
gas28man is offline
post #4 of 10 Old 11-29-2005, 05:26 PM
donald7150
donald7150's Avatar
chances are an '01 town and country has automatic temperature control and if thats the case it doesnt use a resistor, but uses a power module that uses pulse-width modulation to vary the speed of the blower motor, kind of like a computer controlled blower resistor that can allow the blower motor to run at any speed, not just the 4 or 5 settings
donald7150 is offline
post #5 of 10 Old 11-30-2005, 08:24 AM Thread Starter
intrepid_es
Thank you
All who replied -
Thank you for your input. I will let you know how the repair job turns out.
post #6 of 10 Old 11-30-2005, 03:59 PM
Rick99
Had the same problem on my wife's 01 T&C. The above is correct, the fan speed control module is the problem. It cost me $60 for the part at the dealer and took me about 2 minutes to replace it. It is located behind the glove box. Squeeze the glove-box sides to release it and let it fall out of the way-empty it first of course-- the fan speed control will be right there.
2003 Durango SLT
AWD, 4.7l
Mods: Remote Start
Just got a new set of BFG All-Terrains
Planning retrofit to 4WABS
1999 Durango SLT+
4x4, 5.2l
Mods: B&M Supercooler, Ford OEM Remote Start/Keyless Entry/Alarm, Heated Seats
01 T&C Limited 3.8l
Rick99 is offline
post #7 of 10 Old 12-08-2005, 11:56 AM
okanagan
I had the same problem as well. 23.00 CAN$ 3minutes to change. All is good !!
okanagan is offline
post #8 of 10 Old 12-12-2005, 06:32 AM
HeadlessHorsemn
New Milford, Connecticut
HeadlessHorsemn's Avatar
It definitely sounds like a blown Resistor Block - they are available at your dealer for about $14 or http://www.rockauto.com for around $16 + $6 to ship it. You may also want to check this out for handling the most common AC/Heater Blower issues (additional parts are listed)...
http://www.automotiveforums.com/vbulletin/t340871.html
HeadlessHorsemn is offline
post #9 of 10 Old 12-13-2005, 02:46 PM
rayzian
3.3L
rayzian's Avatar
Anyone know where these resistor thingies are located on a 93 GC? I have the same problem. (heater and AC only work on high, nothing else works)
rayzian is offline
post #10 of 10 Old 12-13-2005, 03:00 PM
dodges 3
dodges 3's Avatar
It's under the hood, on the passenger side firewall. It will have a harness, with 5 or 6 wires coming out. It is screwed on to the firewall, with 2 screws.
dodges 3 is offline
    1996 Dodge Grand Caravan LE AC/Heater Blower, Relay and Resistor Block Problems 101 HeadlessHorsemn Dodge Caravan General Talk 2 01-23-2006 03:28 PM
    front A/C blower stopped working.. beerdude 1G Dodge Durango General Talk 16 08-22-2005 01:09 PM
    2005 Dodge Magnum Engineering Press Releases RAM MAN Rumor Mill & Gossip Talk 0 03-03-2004 09:55 AM
    05 Chrysler and Dodge Minivan Specifications RAM MAN Rumor Mill & Gossip Talk 0 12-12-2003 08:37 AM
