Why do my valves rattle when i floor it? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 10 Old 11-26-2005, 12:20 PM Thread Starter
camaro 22
camaro 22's Avatar
Just as my title says. My valves ratter when I floor it at times, and when going up steep hills? Is something wrong? I use the cheap gas. Think it's 87. But if I recall, I think I read in the manual a while back that it says not to use anything higher than 87. Could something else be the problem?
1999 Durango SLT 4x4 5.2
1997 Camaro Z28 Vert Modded
2003 Yamaha R1 Silver
Mods so far. Flowmaster 40 series D/O muffler
Ram air cowl hood
Full body kit
20in chrome wheels
White faced gauges
CAI
camaro 22 is offline
post #2 of 10 Old 11-26-2005, 12:27 PM
B1G BLEU
WORLD'S GREATEST TRUCK
B1G BLEU's Avatar
You sure it's not knocking from the gas? I'm sure the manual said not to get lower than 87 and that you may not need more than 87.
Paul
02 Durango (build 11/01) SLT┼ AB/BLACK INT 4.7L NGC 45RFE PT3.55 LSD 4X4 - Superchips 3715 Performance - Sensatracs - Chrome Nose - Carriage Works Billet Grilles - APC Clear Corners - Infinity 6022i's w/stock tweeters - - Hidden Hitch - Silverstar 9007ST's - K&N high-flow 33-2175 air filter- TFP Chrome Handles - 33K Miles - (MB Gunner Chrome Wheels + General Grabbers wintering in basement) Hammered blue factory rims
Wife's Ride : 2006 Grand Caravan SXT INFERNO RED
Work Ride : 2009 Ford Edge SEL
Daughter's Ride : 2011 Jeep Compass Latitude
Son 1's Ride : 2012 Nissan Altima S Coupe
Son 2's Ride : 2006 STi Stage 2 Grandma Gray (kinda mine, too
B1G BLEU is offline
post #3 of 10 Old 11-26-2005, 02:39 PM
DurangoDude
Big, Blue & Bad A$$!
DurangoDude's Avatar
That's pinging for sure. You need to run higher octane gas, which is ALWAYS better for your motor. The higher the octane, the more efficient the fuel burns and you'll get better gas mileage to boot.
If higher octane doesn't do the trick, switch to a colder spark plug such as Autolite 3923's or Denso IQ22's.
Hope this helps!
John
a.k.a - DurangoDude
To-The-Show Driver:
2001 Durango R/T - Paxton Supercharged Fastman Stroker 408 (6.7L).
Daily Driver:
2004 1500 Quad Cab "Thunderoad" Hemi
Personal E-mail:
Progress reports on the D can be found on my web site:
DurangoDude is offline
post #4 of 10 Old 11-26-2005, 02:44 PM Thread Starter
camaro 22
camaro 22's Avatar
I owned the truck for 2 years now, and never tuned it up or anything. Do you think I should just change the plugs anyway? They're prob original being i bought the truck with 50K miles on it.
Ram air cowl hood
Full body kit
20in chrome wheels
White faced gauges
CAI
post #5 of 10 Old 11-26-2005, 03:06 PM
DurangoDude
Ummmmmmm Hell Yes! You should change plugs every 15-20k or so, IMHO. Then after you change plugs, get it serviced.... oil change, get a K&N drop in filter, etc etc., get better plug wires. I think even after just changing the plugs and going to higher octane you'll see the pinging go away, but the other stuff is also needed.
John
a.k.a - DurangoDude
To-The-Show Driver:
Daily Driver:
Personal E-mail:
post #6 of 10 Old 11-26-2005, 04:24 PM
rockadaous
Keystoner
rockadaous's Avatar
sounds like marbles in a can right? JW's hit it on the head
rock
99 SLT+ 4X4 (5.2/318 & 44RE trans)
Patriot Blue (3.55 axle ratio)
Interior mods
APC rev glow gauges*Lotek Gauge Pod w/APC gauges*Nu-Image A/C & light panel*Redline shifter*Pilot titanium mesh pedals*Nu-Image gauge bezel*dodge logo door sills*blue jel light covers*Phoenix imaging interior
Exterior mods
Keystone kit*Cervinis SS Hood*Keystone Spoiler*Billet gas door*Altezza tail lights*Diamond cut euro headlights & parks*SS speed grille*3A Racing fog lights*APC M3 mirrors* MB Motoring Smoothies 20X10*Goodyear Eagle GT II 275/45/20*Pilot billet antenna*chrome differential cover*shaved roof rack*vent visors*APC bulbs*smiley grill*reflex shocks*drilled & slotted rotors*hawk HPS pads*TFP handle covers*2" drop"debadged
Engine mods
Intense performance stage II CAI w/9" big mouth filter*mopar valve covers*TD billet engine caps*180 T-stat*IAT Sensor Mod*GSport radiator hose*Goodyear gatorback S-belt*Flowmaster 40 series muffler*Dual exhaust*synthetic fluids*yellow loomz*brass cap & rotor* BP billet fuse cover*AL 3923 plugs*
rockadaous is offline
post #7 of 10 Old 11-28-2005, 11:16 AM
Rick99
I had the same problem. I kept my plugs and wires stock (not that those aren't good mods) and gave it a treatment with SeaFoam engine cleaner in the intake. It fogged up the neighborhood with thick white smoke for a few minutes, but I haven't heard any pinging since. (I told the neighbors I was testing the smoke-screen.) I've also started adding an injection/valve cleaner to the fuel tank with every oil change just to keep things clean. I still run 87 too-- no need to pay more for gas if you use SeaFoam to get the carbon out of your engine. (There are other engine cleaning products-- that just happens to be the one I used.)
2003 Durango SLT
AWD, 4.7l
Mods: Remote Start
Just got a new set of BFG All-Terrains
Planning retrofit to 4WABS
1999 Durango SLT+
4x4, 5.2l
Mods: B&M Supercooler, Ford OEM Remote Start/Keyless Entry/Alarm, Heated Seats
01 T&C Limited 3.8l
Rick99 is offline
post #8 of 10 Old 11-28-2005, 06:32 PM
dagray1
dagray1's Avatar
I quit using high octane due to poor gas mileage and increased cost. If the engine is tuned for regular it shouldn't ping. May have been tuned with premium at some time in the past.
99 Durango SLT+ 4X4
Infinity Sound System
Leather Interior
5.9 L Engine
Full time FWD
31x10.50x15 BF Goodrich All Terrain T/A tires
dagray1 is offline
post #9 of 10 Old 11-28-2005, 07:29 PM
Neil F.
Neil F.'s Avatar
Yes the stock durango engine is tuned for 87 octane. There are factor that may cause a need for higher octane such as a need for tune up (plugs, wires, cap rotor) leaking plenum gasket (common failure) and in general worn engine. The only way to "tune" the engine for premium is to change the PCM or increase the compression ratio.
99 Durango 5.9, FT 4x4, IP stage III w/ K&N air hat, M1, MOPAR PCM, Fastman TB, 1.7 RR, JBA headers, Borla cat back, Martin Saine valve body, Hotchkis swaybars, Blistein shocks, lowered 2" Black Rhino Kenya wheels, 246. 7 RWHP, 319 TQ
Neil F. is offline
post #10 of 10 Old 11-28-2005, 09:09 PM
B1G BLEU
B1G BLEU's Avatar
Mopar sells 'top engine cleaner' which I was recommended to buy for my old Caddy. It did wonders (besides the black smoke which turned white). Ran much better but still neded prem.
Paul
B1G BLEU is offline
    Rattle in the rear gavinl Dodge Caravan General Talk 3 10-25-2005 12:52 AM
    Rattle, Rattle, Rattle JohnnyD 1G Dodge Durango - Interior/Exterior 5 09-01-2005 04:33 AM
    Rattle is driving me NUTS! ddn 1G Dodge Durango General Talk 4 08-14-2005 12:07 PM
    318 RATTLES. Timing rattle? Help. JAFO 2G Dodge Ram Performance Talk 7 08-02-2004 08:36 AM
    Rattle, rattle, rattle shortredone 3G Dodge RAM - Interior/Exterior Talk 5 11-03-2003 01:53 PM
