fog light jumper mod - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 4 Old 11-06-2005, 04:26 PM Thread Starter
ppp1182
ppp1182's Avatar
I am going to do the fod light jumper mod. Should I put an inline fuse in the jumper? If so, what amp rating should i use? Also, what gauge wiring should I ise for the jumper? Thanks!
2000 Ram 1500 SPORT 4x4 5.9L (360) in BLACK (it looks bigger)
BFG All-Terrain T/A KO 285/70r17 from Michigan 4 x 4
Port-matched MP1 Intake Manifold from The Fastman
17x8 Off-Road Edition rims (Thanks Tazz411)
Gibson swept-side stainless single exhaust
SCT custom tuned by Hemifever
Gibson ceramic coated headers
Fastman 52mm TB
Volant CAI
3.92 LSD
Next up (
better brakes
Flex-A-Lite efan
408 stroker with stage 3 Eddy heads
4.56 gears
ppp1182 is offline
post #2 of 4 Old 11-06-2005, 06:46 PM
Meierznutz
Older, but no wiser.
Meierznutz's Avatar
Are you setting the fogs to stay on with the high beams? If so, use 14 ga wire and a relay. Fuse the power from the batery to the relay and then run a wire from the highbeam to trip the relay. This way you dont pull voltage from the headlight circuit and melt the harness or the switches. Also, if you want your low beams to stay on with the Highs, you can install a 5 amp 12 volt diode from the high to the lowconnector at the lamp. A diode is a one way valve that once installed will let the lows come on with the highs but the highs will only work in the hi position. Good luck... Chris
'02 2500 Quad Short Box, HO Cummins, 6 speed,Fast Cooler and filter kits, Con-OFE clutch, 3:55 limited slip, Banks exhaust and Brake, K&N, Autometer Lunar series gauges, Air Dog 100gph, Adrenaline chip SOLD :-(
Current ride: 95 2500 2wd with a P-pump
90 Miata LS-1, 6 speed, 8.8 Cobra IRS
5-21-93 married, cost $15k
4-29-02 bought my Ram, cost $28k
3-15-99, 8-8-05 sons are born PRICELESS!
Meierznutz is offline
post #3 of 4 Old 11-06-2005, 07:14 PM Thread Starter
ppp1182
ppp1182's Avatar
What amp rating on the fuse?
Fastman 52mm TB
Volant CAI
3.92 LSD
Next up (
better brakes
Flex-A-Lite efan
4.56 gears
ppp1182 is offline
post #4 of 4 Old 11-06-2005, 09:25 PM
Meierznutz
Meierznutz's Avatar
Go by the wattage of the lights you are running. If they are the factory fogs, I think 15 amp would do. I'd rather go low and blow the fuse than high and burn the harness.
    CupHolder Light Mod mattspenc 3G Dodge RAM - General Talk 22 08-03-2005 12:13 AM
    Fog light help, please mulsanne Dodge Neon - General Talk 4 03-28-2005 08:54 AM
    1997 Ram Fog Light Question 1997TODD 2G Dodge RAM - General Talk 0 04-02-2004 07:50 PM
    fog light mounting help J_C 1G Dodge Durango General Talk 7 01-22-2004 12:31 AM
    fog light inserts ??? dodge_parts_man 3G Dodge RAM - Interior/Exterior Talk 15 07-09-2003 07:37 PM
